Old 10-26-2012, 09:21 PM   #331
tete OP
clown shoes
Oddometer: 346
Ok I got the switch back together properly. But I follow the route and I believe the relay must be wired incorrectly. However I can't seem to find a diagram showing which female end goes to which male end. I wired it up the way it was and it did not work. The PO was obviously in there messing things up because there was electrical tape and messy connections everywhere.
So essentially I need a headlight switch relay diagram. Electrical is very frustrating. Especially when the information is not out there in the same way mechanical issues are.
1980 BMW R100RS -
tete is offline   Reply With Quote
Old 10-27-2012, 06:58 AM   #332
chasbmw
Oddometer: 2,121
There could be problems if the PO has replaced the LH switch unit. I understand that the later switch units have different wiring, if you can find a wiring diagram for a /7 round about 1977, then this might help. Does your LH switch unit have an on/off function? In the US legislation in the 70s ensured that bikes had to have lights on all the time, but I'm not quite sure when this was enacted. According to my wiring diagram a 74 R90/6 does not have a headlamp relay, though my bike has one fitted. I will go and check the bike and see, either today or tomorrow.
Euro bikes will have an on/off switch, so be careful as to which wiring diagram you are looking at. The function of the headlamp relay is to prevent the full headlamp current running through the headlamp switch.
The earth for the instrument lights runs via the brake fluid low level switch to an earth by the coils, if that is still present then you are OK.
Charles
Charles
1971 Commando Fastback
Old 10-27-2012, 02:32 PM   #333
tete OP
clown shoes
Oddometer: 346
Yeah my instruments light up fine as do my turn signals and brake lamp. Parking light and brights (if i push tht button down that is.) work fine it seems.
Just the "stay on" headlight won't happen or stay on bright wont happen.
1980 BMW R100RS -
tete screwed with this post 11-03-2012 at 05:06 PM
Old 10-28-2012, 01:24 AM   #334
tete OP
clown shoes
Oddometer: 346
About tires.
Question: With total disregard to handling as I am aware of the characteristics. Do we know if the firestone Deluxe tires will fit the typical size R90/6? I believe 18 x 4.00 and 19 x 3.25 ?
Im concerned with the rear swing arm rubbing and the front fender rubbing - the tires seem to be balloon like.
thanks in advance.
1980 BMW R100RS -
Old 11-03-2012, 05:04 PM   #335
tete OP
clown shoes
Oddometer: 346
Ok, so I have not installed my acewell because of issues I am having with my headlight not working.
I'm still dealing with that.
I got a new headlight switch and a new relay.
Here is the issue. My switch is slightly different.
Pictured in my old on the left and new one on the right. Fits perfect but the switch is different.
Also the wiring is different. Once again the old on the left new one on the right
Anyone deal familiar w this?
Which wires may go where? The new harness does not have a red, grey or solid brown wire?
1980 BMW R100RS -
Old 11-03-2012, 05:41 PM   #336
tete OP
clown shoes
Oddometer: 346
It looks like, according to clymer, my new switch is off a R100. Now I have to figure out a way to mate it to the R90 set up.
1980 BMW R100RS -
Old 11-03-2012, 05:43 PM   #337
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,204
It looks to me like your old switch is what I hear people calling a European switch, it has an on/off for the headlights. The switch on the right does not have an on/off so the headlights will be wired to stay on all the time.
You can probably figure this out if you look at two separate wiring diagrams that each feature one of these, maybe.
That's what it looks like.
---Albert Einstein
disston is online now   Reply With Quote
Old 11-03-2012, 06:54 PM   #338
tete OP
clown shoes
Oddometer: 346
Yep, You are right now I must figure out how I can wire the new switch in. I actually prefer always on.
Here is what I do know.
White = Brights
Yellow = Low Beam or regular beam
Brown is ground
Brown w White = horn
Green w black stripe= horn
So i need to figure out what the Yellow with White stripe is
Then I need to figure out f I can use my old relay or do I need a different one. Also need to figure out which goes where.
not fun. The best part is when I'm all done figuring this out I'll take it apart for the Acewell. One thing at a time.
1980 BMW R100RS -
Old 11-04-2012, 01:48 AM   #339
tete OP
clown shoes
Oddometer: 346
What can I connect the brown/white stripe wire / as well as the green wire to the switch? looking at this just makes me more confused. Can't i just go back to cleaning carbs and painting stuff.
For the record I have a R90/6 and am trying to retofit the R100 switch to work (this has always on headlight)
OK so here is how I look at it. According to clymer.
I should be able to connect the brown w white striped wire for the horn switch to the clutch switch one on the R90/6
The green/black striped wire I should be able to connect to the contact board.
That should take care of the Horn there is no horn relay on the R90/6 but there is on the R100 that the switch was designed for .
On the headlight side is where it gets tricky/confusing for me. because I have to use the relay. What if I simply match up the left over wires (4 of them) to the relay from the /6? here is the diagram
On the left is the R90/6 and on the right is the R100/7
There is no Red on the new harness but Perhaps I won't need that with the "always on" switch.. i dunno. ungh.
1980 BMW R100RS -
Old 11-04-2012, 06:33 PM   #340
tete OP
clown shoes
Oddometer: 346
Ok so I figured it out. Got to bridge the green over from the ignition. The plan for the horn didn't wrk out so ill just hook it up the same way it was originally. Gotta find those wires.
Ill draw up a diagram once I'm done for any future inmates that may find it useful.
1980 BMW R100RS -
Old 11-05-2012, 12:53 PM   #341
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 661
Cool. My light won't switch off at all, nor will my ignition. I see a rewire in my future and possibly and acewell..
Kt-88 is offline   Reply With Quote
Old 11-06-2012, 01:49 AM   #342
tete OP
clown shoes
Oddometer: 346
I can't say I'm all that excited about opening it up again and doing the acewell. But I'm going to. The one problem I have is w the always on headlight when I go to start it the headlight is on. Drawing power. But my bike starts so easily and I live on az so I'm not to concerned for it being on for a milli second.
1980 BMW R100RS -
Old 11-06-2012, 02:01 AM   #343
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 661
Similar story here, but it's starting to get cold in the mornings and this is my daily ride. Amperage matters a bit more then..
Old 11-07-2012, 12:36 PM   #344
tete OP
clown shoes
Oddometer: 346
Anyone recognize these mirrors?
1980 BMW R100RS -
Old 11-07-2012, 12:37 PM   #345
tete OP
clown shoes
Oddometer: 346
Don't mind the mannequin head. She keeps the birds away. Ha!
I have 4 of these that I found w all my bmw stuff I got w the bike.
1980 BMW R100RS -
Times are GMT -7.   It's 12:47 PM.
