Old 08-27-2012, 10:44 AM   #1
MItrnsplnt OP
PllnGs tillthey puke
MItrnsplnt's Avatar
Oddometer: 666
2 smoke DS's on pavement......?
Had a question for the masses....plan on buying a KTM 300 EXC or XWC and was wondering what the individuals with 2 stroke DS bikes do when they have to connect trails via pavement for 10-20 miles??? I know that there are a lot of people on here who ride 2 stroke bikes up in the mountains and have to do this....but was wondering how they preserve the life of the piston/rings (top end) when they have to use pavement to get to other places.....One guy just recently told me in CO that he'll pull the choke out on the pavement to give a richer mixture and lubricate the piston on pavement sections and not burn the rings out as quick, but wasn't sure if that was the case or accurate? What does everyone else do??? Thanks in advance for the advice!!
'09 KTM 530EXC (do-it-all workhorse)
'04 KTM 250EXC (ST switchblade)
'13 Sherco 3.0 (trials billy-goat)
Rocky Mountain Ride 2011: Aspen to Crested Butte and back
http://advrider.com/forums/showthread.php?t=723271
MItrnsplnt is offline   Reply With Quote
Old 08-27-2012, 01:55 PM   #2
Twin-shocker
Oddometer: 1,673
Pulling the choke out helps to stop bikes overheating when used at wide throttle openings on the road, and thus prevents motors seizing up. If you can just taking things a bit easier on the road is a much better idea, and will mean motors last longer.
Old 08-27-2012, 02:03 PM   #3
WVhillbilly
WVhillbilly's Avatar
Oddometer: 10,789
I've had to do 10-20 miles of 2 lane a couple times on my 200 EXC.
Not much traffic here, so I just took it easy. 40-50 mph except for a couple times.
The off road tires weren't much fun either,
WVhillbilly is online now   Reply With Quote
Old 08-27-2012, 03:35 PM   #4
miguelitro
Chuchaki
miguelitro's Avatar
Oddometer: 884
hitting the kill switch periodically works as well. on a 82 yz490 I had a cable rigged up to pull the choke for long flat baja dry lake bed crossings. pretty easy to do.
Mike
Team Mojados Spearfishing
Originally Posted by OnandOff
I'd rather be riding a 200 in Ecuador than any dream bike here.
miguelitro is offline   Reply With Quote
Old 08-28-2012, 03:01 AM   #5
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,754
I don't do anything.
I did a couple of hundred K on a highway to get home once...
She handled it without a problem.
But I'm going to look into the bar mounted choke lever.
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 08-28-2012, 11:14 AM   #6
FloridaSteve
FloridaSteve's Avatar
Oddometer: 2,082
Those bikes are very stoutly engineered especially compared to all the vintage stuff I ride. I don't see how this would be a problem. If you're concerned about holding a constant RPM for an extended period then don't. move it around a bit, hold the clutch in on looong downhill runs (a mile or more) and otherwise ride it like a normal motorcycle. Not sure what the mechanism is on the 300 but choking it will typically just get it way rich on a warmed up bike. I don't see how this will help if the bike is properly tuned jetted mapped whatever.
2 cents..
FloridaSteve is offline   Reply With Quote
Old 08-28-2012, 04:22 PM   #7
firecrotch
firecrotch's Avatar
Oddometer: 494
I gently roll the throttle on and off. Been fine for hundreds of miles now.
firecrotch is offline   Reply With Quote
Old 08-29-2012, 12:33 AM   #8
Twin-shocker
Oddometer: 1,673
The reason why its not a good idea to ride dirt bikes flat out on the road for any length of time, is due to the cooling systems not being designed to get rid of the amount of heat this is likely to mean, which makes seizure a distinct possibility.
Old 08-29-2012, 12:36 AM   #9
Forde
Forde's Avatar
Oddometer: 641
um, just dont ride it full throttle??
'06 CBR1000RR Fireblade and loads of small 2 strokes!
Forde is offline   Reply With Quote
Old 08-29-2012, 04:24 PM   #10
Shocktower
Shocktower's Avatar
Oddometer: 9,480
It is a water cooled bike, I am sure it is fine
Alexa Drew Nov 9 1995- Oct 28th 2004 Miss you baby
'08 KTM 530 EXC
79 RD 400 Daytona
Shocktower is offline   Reply With Quote
Old 08-30-2012, 07:57 AM   #11
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,335
I have put thousands of miles on the pavement on MX bikes, enduros, and 2 stroke street bikes and never had a problem with ring wear. On 2 stroke MX bikes I do vary the throttle a little to both keep it from surging and keep the vibes to a minimum.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 09-02-2012, 01:02 PM   #12
peter650
Oddometer: 422
Just jet it, so it will run on the road.
peter650 is offline   Reply With Quote
Old 09-02-2012, 10:56 PM   #13
Twin-shocker
Oddometer: 1,673
Fitting bigger jets might stop a dirt bike seizing when its ridden on the road, but it wont alter the fact that the cooling system isnt designed to dissipate the amount of heat resulting from wide throttle openings for long periods of time.
Old 09-03-2012, 06:08 AM   #14
peter650
Oddometer: 422
I had a air cooled kx500 {in rd 400 frame} that i rode on the road all the time. I ran 2 head gaskets on it, so it would not ping, it never over heated.
Old 09-03-2012, 11:45 AM   #15
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,754
All my bikes get much hotter doing slow stuff than they do on the highway.
I have never overheated a bike on the highway, but I have on slow stuff and waiting in traffic, so I really don't see a problem with cooling.
tEAM iDIOT.
Times are GMT -7.   It's 04:33 PM.
