Old 08-28-2012, 12:43 PM   #1
Chompa OP
Oddometer: 16
Finding the right tires
I love getting off-road and deep in the mud... however, because i live in the city I have to ride highway to get off road... I'm looking for good tires that are real aggressive off-road but also hold up to a lot of highway..
any suggestions or input would be appreciated.. thanks
Bike is a BMW 650 x challenge.. need something with an S rating
Chompa screwed with this post 08-30-2012 at 09:20 PM
Chompa is offline   Reply With Quote
Old 08-28-2012, 12:56 PM   #2
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,091
I'm in the same boat, trying to find a set of street legal knobbies for my Honda XL600. I'm a bit limited, because my front wheel needs a 110/80-18. Your choices might be less limited.
In my searches, I have found:
-Continental TKC-80 (durable for pavement, not the best for mud)
-Michelin T63 (similar to the TKC-80, but with different size selections)
-Pirelli MT21 (not very durable, but OK in the soft stuff)
-Dunlop D606 (pretty good all round off roader, 10% pavement)
High Country Herb is offline   Reply With Quote
Old 08-28-2012, 01:11 PM   #3
Chompa OP
Oddometer: 16
I'm not even sure what size tires I need because this is my first time getting new ones. Bike isn't with me right now and neither is my owners manual lol... Bike is a BMW X challenge though and definitely need something that is more street friendly than what I currently have :(
Old 08-28-2012, 01:12 PM   #4
CA Stu
CA Stu's Avatar
Oddometer: 47,613
Not an ad, moved to Thumpers.
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 08-28-2012, 01:21 PM   #5
Chompa OP
Oddometer: 16
looking for:
Front tire: 90/90-S21
Rear tire: 140/80-S18
This is the specs I pulled off line for the bike
Old 08-28-2012, 01:29 PM   #6
OrangeYZ
Oddometer: 598
http://www.youtube.com/watch?v=kw32fiasUSs
OrangeYZ is offline   Reply With Quote
Old 08-28-2012, 01:38 PM   #7
High Country Herb
Oddometer: 9,091
"Real aggressive" for mud, and "more streetable" are opposites.
Personally, I am too cheap to keep buying soft compound tires for partial street use. I figure I'll get a hard compound knobbie, and just deal with the less than ideal traction. I'm probably not a good enough rider to notice the difference anyway, so either way I'll end up tipped over in the mud.
Old 08-28-2012, 04:17 PM   #8
Grreatdog
Grreatdog's Avatar
Oddometer: 11,670
I found two serious dislikes for MT-21's even though I have been running them for years and they were my favorite tire. One: they are to soft for riding in rocks. I have gotten more front pinch flats with them than I have ever gotten on ever other tire combined. Two: they are too soft for 650 power. The rear evaporated on my LC4E.
The T63's are OK but I couldn't find a 140/18. I don't like any of the others. The ones I settled on as a replacement for my formerly favorite MT-21's are the Pirelli XCMH. I have a set in the mail right now. Not sure how they will hold up. But the MT-21's are definitely not suitable for big power and heavy bikes. They held up great on my smaller bikes though.
525EXC, 640 Enduro, XT200
Grreatdog is offline   Reply With Quote
Old 08-29-2012, 08:21 AM   #9
High Country Herb
Oddometer: 9,091
I think the TKC-80 and the Kenda Big Block both come in 140/18.
Old 08-29-2012, 08:49 AM   #10
LittleRedToyota
Yinzer
LittleRedToyota's Avatar
Oddometer: 2,232
you aren't going to find a rear tire that is good in mud and holds up to a lot of highway. i've tried.
the best i have come up with is the pirelli XCMH.
the front XCMH is a no-brainer, imho. it is the best DOT knobby front tire ever made. handles like a real dirt tire in dirt and, for some reason i don't understand, lasts a looooooong time on pavement (and actually handles decently on pavement as well)--twice as long as dunlop 606 (which do handle a little bit better on pavement, but are horrible in dirt and cup very quickly on pavement).
in the back, the XCMH is OK all around. it is not as good as the kenda trakmaster II in mud, but lasts wayyy longer on pavement. the TMII is the gold standard for DOT knobbies in dirt. but, they wear out very, very quickly on pavement.
the dunlop 606 lasts longer than the XCMH on pavement, but absolutely sucks in mud (or anything loose off road). it is a good hard-packed dirt tire, but sucks in loose stuff.
those are my experiences anyway.
LittleRedToyota is offline   Reply With Quote
Old 08-29-2012, 09:00 PM   #11
Kommando
Kommando's Avatar
Oddometer: 7,389
You can do what I did for the sand...Run a knobby up front, and a long-wearing DS tire out back...custom grooved.
That Pirelli XCMH front sounds interesting...good manners offroad, and long-wearing onroad. I'd try something like that up front, and a custom-grooved Kenda K761 out back. I get over 6K miles out of a rear K761, and it'll propel my DR through some pretty nasty stuff, while having limited lateral stability, with just basic grooving. With involved grooving, I can make it a bit better offroad, while giving up little onroad.
If you look at a pic of a rear K761, you can picture the grooving I do. Basically, what I do is cut the half-depth cross-grooves in the center to full-depth. Then I cut the half-length circumferential grooves in the center blocks the full length of the blocks. Then I make the left and right sides identical, and add an extra paddle channel in the center of each outer block. Air it up for pavement, but not too much or you'll square it. Air it down for offroad and the side lugs can assist better. The tire then has better offroad drive AND lateral stability than before, while still lasting a LONG time. It also works better in the rain onroad.
I use grooving blades that are about the same width as the original grooves of the tire. For the 130/80-17 size I run, I use #3, #4, and #6 blades. A different tire size may have grooves of different sizes, BTW. The K761 runs me about $60 in the 130/80-17 size, so it's typically a bit cheaper than the D606 or MT21.
Kommando is offline   Reply With Quote
Old 08-29-2012, 11:47 PM   #12
2handedSpey
bunned
Oddometer: 237
Originally Posted by LittleRedToyota View Post
The Dunlop 606 lasts longer but absolutely sucks in mud (or anything loose off road). it is a good hard-packed dirt tire, but sucks in loose stuff.
Wha...? Really? I had much better opinions of the D606. Coming from a metzler tourance to the D606 on a KLR was amazing in deep mud, deep water, snow, sand, dirt etc etc.
Fwiw, I thought it to be a decent off-road tire for mud. This is certainly not a full non-DOT mx tire but, geezers, for a heavy KLR it was excellent offroad.
Originally Posted by kbasa View Post
If you're wearing Crocs, chances are that you're not smart enough to tie your shoes.
2handedSpey screwed with this post 08-30-2012 at 07:11 AM
2handedSpey is offline   Reply With Quote
Old 08-30-2012, 11:54 AM   #13
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Mefo Stone Master
Anyone try these, aggressive DOT
http://www.twistedthrottle.com/trade...view/4796/766/
rotten is offline   Reply With Quote
Old 08-30-2012, 11:59 AM   #14
sieg
sieg's Avatar
Oddometer: 2,853
Aren't we all..........
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 08-30-2012, 12:03 PM   #15
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
My thought as well, I settled with the T63s which as suited my needs VERY well but I don't ride in the MUD. Lugs seem to shallow for any serious lose terrain work.
Here is another tire that looks good, have no experience with
http://www.mandhtires.com/Teraflex-T...5#.UD-4btZlSYQ
Times are GMT -7.   It's 04:02 AM.
