Old 08-30-2012, 12:09 PM   #16
RyanR
Oddometer: 111
I've only tried the Kenda Trakmaster II and the Dunlop D606 so far. The D606 is a great street knobby IMO. It sticks like crazy and the ride is pretty good. The Kenda is more aggressive and works better off-road and it's ride is OK. The biggest thing I have noticed is the compound on the Kenda is not nearly as grippy on the pavement as the D606. I can make the TM II step out pretty easily where the D606 has quite a bit of bite on the pavement and holds a line very well. Then again the D606 is no nearly as grippy off-pavement as the Kenda.
After my current set wears out I am going to try a Pirella MT-43 trials in the rear. Still searching for a new front tire to try. I may have to give that Pirelly XCMH a go.
2008 - KLR685 - Currently For Sale
2008 CRF250x - Street Legal Hooligan Machine
RyanR is offline   Reply With Quote
Old 08-30-2012, 12:09 PM   #17
rotten
LOST AGAIN
rotten's Avatar
Oddometer: 670
Good comparison here:
http://www.advrider.com/forums/showthread.php?t=796751
rotten is offline   Reply With Quote
Old 08-30-2012, 08:58 PM   #18
Chompa OP
Oddometer: 16
Need tires rated for S speed
Chompa screwed with this post 08-30-2012 at 09:19 PM
Chompa is offline   Reply With Quote
Old 08-31-2012, 05:15 AM   #19
Grreatdog
Grreatdog's Avatar
Oddometer: 5,930
The only "S" rated true knobby that I know of is the T-63. Dropping down to "R" will open things up a bit more to include Karoos and TKC-80's. I doubt you do much cruising at the 106 mph "R" rating much less 112 mph anyway.
KTM 640 LC4E
KTM 200 MXC
XT200
Grreatdog is offline   Reply With Quote
Old 08-31-2012, 05:59 AM   #20
Chompa OP
Oddometer: 16
Very true.. i shouldnt be driving that fast anyway
Old 08-31-2012, 06:18 AM   #21
Lenz1
Oddometer: 125
The Pirelli Scorpion MT90 has been recommended as good on sealed and gravel roads but they're not gonna beat knobbies in muddy slop. Not sure about sandy country .......
Metzler Sahara tread pattern looks useful too but they're ~ twice the price of the Pirelli's in Australia.
So new MT90 Pirelli's, 90/90 - 21 front and 120/80 - 18 rear it is on the TT350 ..... we'll see how they work out for the planned usage
Lenz1 is offline   Reply With Quote
Old 08-31-2012, 12:53 PM   #22
Baja Ho
Baja Ho's Avatar
Location: Central Coast, CA. USA & Cabo San Lucas, Baja Sur
Oddometer: 640
This custom grooved Kenda sounds interesting, any pics?
Originally Posted by Kommando View Post
You can do what I did for the sand...Run a knobby up front, and a long-wearing DS tire out back...custom grooved.
That Pirelli XCMH front sounds interesting...good manners offroad, and long-wearing onroad. I'd try something like that up front, and a custom-grooved Kenda K761 out back. I get over 6K miles out of a rear K761, and it'll propel my DR through some pretty nasty stuff, while having limited lateral stability, with just basic grooving. With involved grooving, I can make it a bit better offroad, while giving up little onroad.
If you look at a pic of a rear K761, you can picture the grooving I do. Basically, what I do is cut the half-depth cross-grooves in the center to full-depth. Then I cut the half-length circumferential grooves in the center blocks the full length of the blocks. Then I make the left and right sides identical, and add an extra paddle channel in the center of each outer block. Air it up for pavement, but not too much or you'll square it. Air it down for offroad and the side lugs can assist better. The tire then has better offroad drive AND lateral stability than before, while still lasting a LONG time. It also works better in the rain onroad.
I use grooving blades that are about the same width as the original grooves of the tire. For the 130/80-17 size I run, I use #3, #4, and #6 blades. A different tire size may have grooves of different sizes, BTW. The K761 runs me about $60 in the 130/80-17 size, so it's typically a bit cheaper than the D606 or MT21.
Baja Ho is online now   Reply With Quote
Old 02-18-2013, 01:33 AM   #23
Perun
Oddometer: 30
Originally Posted by LittleRedToyota View Post
the best i have come up with is the pirelli XCMH.
the front XCMH is a no-brainer, imho.
I find front XCMH only in 80/100-21 and 90/100-21. That 80/100 has almost same hight as 90/90, but its 1cm narrower, right?
Question: is it OK to fit 80/100-21 instead of stock 90/90-21?
Perun is offline   Reply With Quote
Old 02-18-2013, 01:56 AM   #24
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,176
Send a message via MSN to warewolf Send a message via Skype™ to warewolf
They are probably the same size, but measured using different systems. ISO vs ERTRO. The 80 wide is across the carcass, with 100% aspect gives 80 mm tall. The 90 wide is across the tread, with 90% aspect is 81 mm tall.
The 90/100 will be a bigger tyre, 90 mm across the carcass with 100% aspect gives 90 mm tall. There's a few of those about now which I'm keen to try on the 640A's 2.15" front rim, e.g. Dunlop GeoMax MX71 90/100-21.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
Originally Posted by Steve McQueen
All racers I know aren't in it for the money. They race because it's something inside of them... They're not courting death. They're courting being alive.
warewolf screwed with this post 02-18-2013 at 02:03 AM
warewolf is offline   Reply With Quote
Old 02-18-2013, 08:01 AM   #25
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 3,942
Originally Posted by rotten View Post
My thought as well, I settled with the T63s which as suited my needs VERY well but I don't ride in the MUD. Lugs seem to shallow for any serious lose terrain work.
Here is another tire that looks good, have no experience with
http://www.mandhtires.com/Teraflex-T...5#.UD-4btZlSYQ
I really like this tire, surprising quiet & smooth on pavement compared to other aggressive DOT legal tires.
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is online now   Reply With Quote
Old 02-19-2013, 08:04 AM   #26
Perun
Oddometer: 30
Muchas gracias, I will try MXMH on my X-challenge then.
Times are GMT -7.   It's 07:21 PM.
