Old 08-30-2012, 11:07 AM   #1
NCD OP
Dirty Hairy
NCD's Avatar
Oddometer: 497
Lubin' Yer Balls (DIY 800GS Wheel Bearing Service)
Chances are, you are riding around with little or no grease in your wheel bearings. Sad but true. Bearing manufacturers ensure robust future sales by skimping on the grease during assembly. (This is not BMW’s fault BTW, before you hate.) But the good news is, those “sealed” bearings that make you feel all warm and fuzzy can be opened up and grease can be added. Its loads of fun. (Not really.) But it is easy, so let’s get started.
I am assuming that you know how/have the tools to get the wheels off of your bike. If not, then you are in trouble.
Tools needed for loobin’:
Screwdriver or panel puller to remove the big external seals
Thin, dull blade to pop bearing seal off
Snap ring pliers
Wheel bearing grease (preferably in a pencil-tipped gun)
Front Wheel:
Use the big screwdriver or panel puller to pop the big external seal out of the wheel:
Now you can see the actual bearing. Take a DULL, very THIN tool of some type and CAREFULLY slide it between the rubber seal and the metal outer race of the bearing. My tool of choice here is a dull x-acto blade. Use caution not to damage the lips of the rubber seal. A light twist pops it right off.
Don’t be shocked if you see naked balls inside your wheels. Take the grease gun and aim it right between each pair, and shoot grease into the void between them. This puts it in the bearings path. FWIW, what looks like bearings here is actually the carrier, the bearings are actually behind it.)
Leave some empty space in the cavity – maybe aim for filling the bearing like 80%. It’s no biggie if you put too much – it just seems to ooze out the excess when things get really hot.
By hand, snap the bearing seal back in nice and even, making sure the seal sits into the grooves in the bearing. Put the big outer seal pack in place flush with the outside of the hub. Sometimes these need a very light bump with a rubber mallet to set back home. Spooge a little grease on the lips of the seal where it runs on the axle or spacer.
OK. Turn the wheel over, and remove the big outer seal. Uh oh, WTF is that stupid ring in the way for? Dammit. Just take the snap ring pliers, engage the holes and squeeze. Lift the snap ring out of the groove and set it aside. (The snap ring blocks you from pulling the bearing seal out.)
Grease up this bearing the same as the other - - just remember to put the snap ring back into place before you button things up with the big outer seal. Installation is the reverse or removal, right? Right.
Rear Wheel:
You have 3 bearings to do in the rear. Grab the sprocket carrier and pull it straight out from the wheel. Set it and the 4 cush rubbers aside for now.
So, you know the drill now. Service that drive side bearing just like the front.
Flip the wheel over, and meet your old friend the snap ring again.
Time to do the bearing in the sprocket carrier. Pull the seal off, just like the others.
There’s another snap ring in the way here, too. No problemo.
It’s good form to put grease on the axles, spacers, and the sealing surfaces of the rubber seals when putting the wheels back on your bike. Just wipe off the external excess once things are all back together to avoid a mountain of dust building up on everything. That way, things come back apart later without drama.
Now start arguing about what kind of bearing grease is best, and whether it’s OK to use synthetic.
NCD is offline   Reply With Quote
Old 08-30-2012, 11:25 AM   #2
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
Awesome!!!
Thanks a bunch!!!!
Ryan
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 08-30-2012, 12:14 PM   #3
NCD OP
Dirty Hairy
NCD's Avatar
Oddometer: 497
This is my 2nd time greasing the bearings on this bike. I did it the first time shortly after bringing it home new.
The 4 wheel bearings only had a spaghetti thin bead of crappy grease on top of the carrier. Bearings were dry.
The carrier bearing (a different brand for some reason) had plenty of grease.
10,000 miles later they all still feel new and notchless.
Old 08-30-2012, 09:08 PM   #4
TheCowboy
back in the saddle again
TheCowboy's Avatar
Oddometer: 606
Thanks so much for taking the time to post this. I did not know you could service a sealed bearing. I jsst today replaced my rear wheel bearings for the second time in 62,000 miles.
TheCowboy
TheCowboy is offline   Reply With Quote
Old 09-01-2012, 07:29 AM   #5
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
Nice writeup. Maybe Wildman can link this thread to the F800 index / database.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 09-01-2012, 08:11 AM   #6
fiwi
Oddometer: 145
Well? anyone?
fiwi is offline   Reply With Quote
Old 09-01-2012, 12:18 PM   #7
NCD OP
Dirty Hairy
NCD's Avatar
Oddometer: 497
Some more to chew on:
I popped both seals off of a brand new bearing to showcase the scant use of grease in a new unit. Sad. Unless you own stock in or run a bearing company, then it's good. Sadder still is that this bearing has FAR more grease in it than mine did when new. No wonder people sizzle through these in like 6-8000 miles (bore problems not included.)
I flushed out what grease is there to show the guts clearer. The bearings (mostly hidden), the carrier, and the voids that you want to smoosh grease into (the bearing's path.)
Old 09-01-2012, 12:39 PM   #8
Cambi
Oddometer: 73
Mobilgrease 28
Originally Posted by fiwi View Post
Well? anyone?
http://www.exxonmobil.com/Belgium-En...grease_28.aspx
Cambi is offline   Reply With Quote
Old 09-01-2012, 12:48 PM   #9
Zoef zoef
Oddometer: 381
Nice writeup. Only thing I'm worried about is the mount of grease. 80% is according to manufacturers specifications way too much. About 30% filling of the free space is deemed sufficient. Too much grease, results in the bearing running too hot, and he grease will melt. Then the grease can go out if the bearing, which result in too little grease. Therefore the correct amount grease is vital for bearing life, not too little, not too much.
Zoef zoef is offline   Reply With Quote
Old 09-01-2012, 01:05 PM   #10
machinebuilder
Oddometer: 1,116
so much misinformation on the internet
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table
machinebuilder is offline   Reply With Quote
Old 09-01-2012, 01:23 PM   #11
LukasM
Oddometer: 5,418
The wheels are not turning anywhere near the maximum RPM that these bearings will be rated for, so you can fill them up with more grease and still not get any heat issues.
Old 09-02-2012, 06:37 AM   #12
NCD OP
Dirty Hairy
NCD's Avatar
Oddometer: 497
I used to fill them 100%. When I did that, I would get some grease that would migrate outside of the bearing after a few 1000 miles. But there would still be WAY more left inside than there ever was before the lube job. My 'scientific analysis' suggested that this was about 10-20% of the grease.
Now I fill them about 80% and it all stays in. Could vary I guess depending on type of grease?
Who cares. It's all better than the watered down Chinese dog turds I find in there from the factory.
Old 09-02-2012, 09:01 AM   #13
itsatdm
itsatdm's Avatar
Oddometer: 4,873
Low bidder apparently gets the bearing contract. Different brand name bearing on different bikes. Mine had different color grease in the rear bearings.
I had a worry about packing them and Woody advised more is better, they don't spin that fast.
Old 10-14-2012, 03:56 AM   #14
Wildman
In my castle
Wildman's Avatar
Oddometer: 18,067
Done. Sorry for the delay, fellas!
Ridden; GBR CYM DEU FRA ESP AND MCO ITA BEL SCT LUX CHE SMR LIE AUT NLD POL LTU LVA EST SWE FIN NOR DNK CZE SVK HUN ROU BGR GRC MKD SRB ALB MNE BIH HRV SVN MYS IRL BRA MAR PRT ARE USA ISL JPN MLT Planning; AUS TUR MDA UKR MEX BLR MNG RUS KAZ TJK KGZ SEN ZAF ZMB MWI NZL IND CPN
Wildman is offline   Reply With Quote
Old 10-14-2012, 07:06 PM   #15
JRWooden
Oddometer: 4,257
I'm not sure anyone could find fault with the specs. for the Mobilegrease 28 Aviation-rated grease.
I do wonder about compatibility in a mixed environment.... some greases do not play well with others.
If trying to top up the grease while on the bike, I'm not sure how we asses compatibility with the unknown factory lube.
if installing new bearings you have the ability to wash the factory grease out first and then fill with your choice...
Any comments/thoughts on this?
Times are GMT -7.   It's 06:30 AM.
