Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 09-08-2014, 01:14 PM   #91
XR4EVER OP
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,083
"Honey, I'm scared. I think I got in over my head this time."
If you've followed this thread in the past, you know it has been my personal quest to make the ~36 mile trek from Thompson Pass to Idaho Point on all (nearly impassible) single track following Trail 7 along the ID/MT state line. I have been up there to make an attempt 9 or 10 times in all, with every attempt failed due to running out of time, losing the trail, running out of saw gas, and again yesterday, coming to the end of the line on a trail that scales up an impossible 45 boulder field at least a half mile long.
I figured I'd cheat a little bit yesterday morning and replace the first 25 miles of single track with 30 miles of easy FS road to start at the section that I last made it to. This got me up to Bloom Peak just after sunrise to see a moose grazing through Ninetythree Mile Lake.
About 8 miles north of Bloom Peak is where I ran out of time the last time I was up there. As soon as I started into uncharted territory, things started getting hairy. The trail eventually went from thick and hard to follow with a lot of blowdowns to flat-out gone due to overgrowth. This vid is from my way back after I turned around.
I got back on a few FS roads and figured I would skip the few miles I had to go to get to Porcupine Pass where Trail 7 crosses through. Twenty more miles of road just to get 2 miles from where I was... Ugh. At Porcupine Pass, Trail 7 to the south is non-existant, and to the north it is well marked and heavily travelled for at least the first four miles. After it breaks out into the ridge line, there were blow-downs-a-plenty and the trail was all but gone. I was working my way through it, determined to make it to that damned Idaho Point. By the time I got to Bottle Point and looked down the other side, I knew I would have to commit to making it all the way to the end, because there was NO WAY I was making it back up. With my goal literally in sight, I was not turning back now. Down I went.
It was fairly instant that I recognized this as a mistake. I had a split second of a misplaced tire knob and almost lost my bike down into the mouth of Montana. I regained my composure and carefully got my bike back onto the ridge. My mind started racing from here out, and I stopped filming in case I would have to save the memory card to tell my family I love them and don't be a jackass like me and do things like this alone.
I made it about another half mile of tree-strewn rock piles before reality was really starting to take grip. I was low on gas, nearly out of water, and the trail went from "I can't believe I'm making it through this" to looking straight up a 45 slope of boulders that the map says I'm supposed to climb. I would have gone up this if it actually stayed like this, but it got way worse.
I got off the bike and hiked up a bit, looking for that magical smooth dirt path winding up through the rock field with angels' light shining down on it. I didn't find it. What I did find was a boulder field that only got way worse. I looked the other direction at the mountain I just came down. I'm screwed. That's when I made the call to my wife I'd hoped I'd never have to make. "Honey, I'm scared. I think I got in over my head this time." I knew I wouldn't have cell reception for most of the return trip, so we put in a system of "what it means if you get this message from my SPOT". I got a text later where she told me to use my OK button more often so she could track my progress to know how close she is to beating the crap out of me. I deserved that.
The return trip proved to be every bit of the butt-puckering, near-death adventure I thought it would be. I knew an attempt at climbing that north face cliff of Bottle Point would only end with a broken or lost bike or body, so I decided to side-hill around it, mostly walking next to the bike. That was a joy. Every time I would ease out the clutch, the back tire would slide out from under the bike, taking me three feet down the hill, three feet further from where I wanted to be. I got good at jamming my bark buster into the dirt to stop the slide. And if the terrain wasn't enough of a struggle, I started suffering from crippling leg and forearm cramps from dehydration. After I finally got around Bottle Point, I only had to hop 100 trees again (the saw was out of gas before I even got to Porcupine Pass), make it back to the pass and back ~35 miles of FS roads, coasting with the engine off where I could to save gas.
So there it is. The Centennial Trail from Thompson Pass to (almost) Idaho Point. A trail that is in-part too overgrown to save without teams of professionals, but definitely a fun challenge for the rugged.
Here is a vid of the climb up and over Bottle Point:
XR4EVER screwed with this post 09-08-2014 at 01:24 PM
XR4EVER is offline   Reply With Quote
Old 09-08-2014, 02:07 PM   #92
birdcool
Oddometer: 112
Wow. Talk about pushing the limits of solo. Ive been admiring that line on the map too. Never knew that was the condition! That area needs a dedicated small team just to bring that glorious trail back to life. PM me the next time u get this hairbrained idea, ill go out and suffer with u. Ill carry the extra gas and bivies. We can use the gas for the signal fire and the bivy to drag the dead carcus out.
birdcool is offline   Reply With Quote
Old 09-08-2014, 08:41 PM   #93
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,488
Ooh ooh ooh, me too.
Beaten paths are for beaten men.
lamotovita is offline   Reply With Quote
Old 09-08-2014, 09:40 PM   #94
Bungholio
Bungholio's Avatar
Oddometer: 618
This definitely needs to be a 3 man affair if you want to try again. How was the butt whoopin? 😉
Bungholio is offline   Reply With Quote
Old 09-09-2014, 09:43 AM   #95
XR4EVER OP
XR4EVER's Avatar
Oddometer: 1,083
Sounds like a plan. I might have to wait till next year; give me time to forget the terrifying parts and only remember the good parts. Maybe it would be better to start at Idaho point and drop down into it. Looking at the satellite images, it would definitely be easier to follow the trail from that end. Plus, it probably would not have been that big of a deal if I wasn't solo.
Lamotovita, I would have invited you on this one, but the plan came to me as we were putting the kids to bed the night before. I was then loading the bike at 10 and getting up at 3, hit the trail by 5:30. Kinda gave new meaning to "short notice".
Honestly, little was said of it. I thanked her for being there by talking me through it and volunteering to load her bike to come save my butt if need be, but besides that, nothing. I guarantee it will come up again the next time I want to go ride. Waaaaiiiit foooor iiiiittt.....
Old 09-09-2014, 10:28 AM   #96
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,344
you're crazy. I'm glad you made it out alive. Are there many creeks around there?? Do you carry a filter or chlorfloc tabs?
I carry one of those little stihl premix bottles for my saw for when it runs out, the little stihl screwdriver tool, a file with guide, and a wedge. I've used all of them and they were very needed in each case. And when you run out of bar oil you can use the premix as well.
n16ht5 is offline   Reply With Quote
Old 09-09-2014, 10:50 AM   #97
XR4EVER OP
XR4EVER's Avatar
Oddometer: 1,083
OK, I might have to go back there sooner than later. I finally had time to sit down at the big computer and overlay my SPOT tracking points with google earth and the topo maps. For anyone following along, I made it to 47.88556, -115.94511.
It looks like there is a magical dirt path that I didn't see, at least for a good portion of the remaining way (aside from the 500' of near-vertical rock face I'd somehow have to find a way up...).
Also, it appears that the section I lost just south of Porcupine Pass is mapped wrong. The trail map shows the trail following the dog leg of the border, where the topo map shows a trail taking a more direct path from near where I was to the pass... Again, it might be easier to find the trail from the other end. Hmmm.... Anyone have a weedeater with a brush blade they'd want to pack and go on an adventure?
I hate bear grass.
Old 09-09-2014, 11:49 AM   #98
XR4EVER OP
XR4EVER's Avatar
Oddometer: 1,083
If I would have had to spend the night up there, I guarantee I could have found some snow on the north side of that ridge I was on. I passed a few small piles on the way there.
There's always pee.
Kidding.
I carry a hatchet and a folding shovel in may pack that have both come in handy. I usually carry two of those red fuel bottles with me, one with bike gas and one with saw gas, but I really didn't expect to need extra fuel this time out. I even looked at them when I was loading the car and decided against it. I was thinking 60 miles, tops, with most of it sipping fuel on FS roads. I was just under 100 miles by the time I got back to the car, and there were about 3 hours of fighting through thick brush and 10' tall trees at 1/2 MPH. I have about 2 hours of video footage that looks like this:
I hate bear grass.
Old 10-08-2014, 09:02 PM   #99
Eldon
950 ADV
Eldon's Avatar
Oddometer: 523
Great RR!! I can't wait to make it out to Idaho next summer.
This trail (and lack of) looks awesome.
05 KTM 950 ADV. Black (Black ones aren't faster. Fast riders just buy them)
06 YZ250 Smoker
00 KTM LC-4 - Sold
93 CR125 - Sold
89 CR80 - Sold
84 XR80 - Sold
74 Honda MR50 - Sold and I wish I hadn't
Eldon is offline   Reply With Quote
Old 10-09-2014, 05:22 PM   #100
tomasinator
Oddometer: 92
Wow, what a ride. Glad you made it back. Scary to be out there alone.
Have you ridden the section of the Centennial Trail from Cooper Pass over Burke Summit and down to Little North Fork above Mullan? I'm curious if that's rideable.
Have you ridden the trail from the top of Sunset Peak (near Dobson Pass) down the ridge to Pony Peak down to Kings Pass? (http://www.fs.usda.gov/recarea/ipnf/...6872&actid=104) The top part looks rocky, just the kind of stuff you like. I want someone else to ride it and submit a ride report first :-)
tomasinator is offline   Reply With Quote
Old 10-09-2014, 06:53 PM   #101
XR4EVER OP
XR4EVER's Avatar
Oddometer: 1,083
The farthest south I've ridden on 7 was somewhere between Glidden Pass and Cooper Pass, and that was 2, maybe 3 years ago. We turned around because of downfall.
Have you ridden the trail from the top of Sunset Peak (near Dobson Pass) down the ridge to Pony Peak down to Kings Pass? The top part looks rocky, just the kind of stuff you like. I want someone else to ride it and submit a ride report first :-)
A hardcore buddy of mine did back in August. I just found my text from him after he got back. Here are some excerpts...
"151 was endurocross log crossing galore... Parked at Kings pass, rode out 10 miles and back, lots of trees...."
That trail is listed on the ID trails site as a seasonal ATV trail, open from April 1 to Sept. 5. Guess we'll have to wait till next year for that one.
I hate bear grass.
Old 10-09-2014, 10:51 PM   #102
tomasinator
Oddometer: 92
You're right about the ID trails site as marking the Sunset Peak trail as an ATV trail. However, the top part of the trail at Sunset Peak is definitely just a singletrack. Here's a photo:
Here's one of the tough parts on that trail:
The Idaho Trails Map has a few errors. It shows the trail from Lost Lake down Lake Creek Gulch (near Wallace) as an ATV trail, but it's definitely only a singletrack as well.
I enjoy reading about your explorations.
Old 10-09-2014, 11:02 PM   #103
tomasinator
Oddometer: 92
Here's what trail 133 looks like coming down into Little North Fork:
Old 10-10-2014, 08:16 AM   #104
XR4EVER OP
XR4EVER's Avatar
Oddometer: 1,083
That looks like a good time right there!
Don't get me started on the mistakes on the maps. We could start a whole thread just on that topic alone, but I don't want to complain too loudly and give them a reason to pull the funding for that project. I checked the paper MVUM last night - the paper map is usually a little more acurate than the website - and that shows it as the same seasonal ATV trail.
A ranger at the BLM office told me to always trust the paper map (MVUM) over the website, unless you are in an area that doesn't ever seem to get around to printing an MVUM, like the St. Joe Forest.
I hate bear grass.
Old 10-10-2014, 08:36 AM   #105
XR4EVER OP
XR4EVER's Avatar
Oddometer: 1,083
While this thread is active again...
I didn't post this publicly yet, but a few months ago I emailed a guy who is labeled as the ID Parks & Rec "ambassador of the Centennial Trail" and actually got a response.
Me:
"I just wanted to send a quick note to thank the powers-that-be (you?) that keep certain sections of this trail opened to motorized use.
At least for the past 4 years, I have packed a saw and worked diligently to keep it open on dirt bike, often using 3 tanks of gas in my saw just to make it ten miles. The section in particular that I have taken under my wing is from Thompson Pass, north to Eightyseven Mile Peak - so far. I've been trying to make it to Idaho Point, but the trail all-but-disappears do to overgrowth just before Porcupine Pass, and again from blow downs from the meadow near Cabin Peak to Bottle Point. I'll attempt to get it unclogged next year; it doesn't help when there are only 2 good months when it is accessible.
My riding buddies ask me why I am so obsessed with this trail when there are so many other hundreds of miles of good trails in the area that don't require such maintenance, and I really can't explain it. I guess I feel like above all other trails, this one has meaning above just a route to get somewhere. We owe it to ourselves as Idaho citizens to put as much into it as it gives us in return.
Anyway, I just wanted to introduce myself, and let you know you have one more "friend of the trail" out there.
Take a close look at the one picture I attached; there is a moose grazing through Ninetythree Mile Lake. That was taken last Sunday.
Thanks for your work,
Ryan Frankenberg"
His Response:
"Ryan,
Thank you for maintaining the Idaho Centennial trail. IDPR only does the coordination the ICT and does not make decisions as to which type of use can occur. The USFS makes those decisions and if they change allowed uses they must go through a public process. At present I see no changes in use designation so keep using and clearing it. Again thank you for your hard work. It is great to see users passionate about trails.
Leo Hennessy
Non-Motorized Trails Program Manager
Idaho Dept. of Parks and Rec.
5657 Warm Springs Ave.
Boise ID 83716-8712"
I hate bear grass.
Times are GMT -7.   It's 09:23 PM.
