Old 09-01-2012, 05:06 PM   #1
OlyRider OP
Oddometer: 1,296
GXM 30 antenna mounting position F800GS
Anybody found a clever place to put their Zumo 550 antenna on the front portion of the bike?
Care to share a photo of the install?
Olyrider
Ob-la-di...Ob-la-da
OlyRider is offline   Reply With Quote
Old 09-01-2012, 06:10 PM   #2
GH41
Oddometer: 822
Nope. GH
GH41 is offline   Reply With Quote
Old 09-01-2012, 06:45 PM   #3
OlyRider OP
Oddometer: 1,296
Originally Posted by GH41 View Post
Nope. GH
That's how you get your post count up?
Olyrider
Ob-la-di...Ob-la-da
Old 09-02-2012, 12:38 AM   #4
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,753
I put mine on top of the left headlight. There's a nook there. I secured it with 3M lock. I'll try to remember and get a pic tomorrow.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 09-02-2012, 04:30 AM   #5
GH41
Oddometer: 822
Is there a prize for the highest post count?? GH
Old 09-02-2012, 10:29 AM   #6
lakota
Geeser
lakota's Avatar
Oddometer: 3,190
I use this which attaches to the GPS mount
http://www.jcwhitney.com/garmin-gps-...FTN0MgodGRAAeQ
you an see how they go together here
IBA #42016
my ride reports
follow my ride
lakota is offline   Reply With Quote
Old 09-02-2012, 12:02 PM   #7
OlyRider OP
Oddometer: 1,296
Thanks, Lakota!
If you reversed the direction of the J C Whitney plate, wouldn't you have a more horizontal mount for the GXM? Do you get good signal strength with the GXM mounted at an angle like that?
Thanks again.
Olyrider
Ob-la-di...Ob-la-da
Old 09-02-2012, 01:08 PM   #8
lakota
Geeser
lakota's Avatar
Oddometer: 3,190
never have had a problem with reception when it is like that. I have tried it the other way but never liked it in that position.
IBA #42016
my ride reports
follow my ride
Old 09-03-2012, 10:32 AM   #9
ScienceOfDirt
U-Boat Rider
Oddometer: 1,753
Here's where I put the sat antenna. I had reception problems when I had it behind the gps. I also had interference when I tried it on top of the brake reservoir.
The pic is of the 665 that I upgraded to. The 550 antenna was in the same place.
Old 09-04-2012, 01:33 PM   #10
montanaman
Traveler
montanaman's Avatar
Oddometer: 171
Bobble headed mount
Originally I had the "puck" under the fairing in the front. It kind of worked but then I went to a tank bag and had to mount it almost vertically on my Mirage screen fairing. That did not work. Now I have it on the brake res and it is still intermintent at best. I dont get it. Its as straight and clear a shot to the sky as I am going to get. I am beginning to think I have a faulty system..
Quit dreaming, get on and start living.
montanaman is offline   Reply With Quote
Old 09-04-2012, 05:18 PM   #11
ScienceOfDirt
U-Boat Rider
Oddometer: 1,753
I had the same problem. They seem to interfere with each other if the zumo is in the same horizontal plane as the puck and within 12"-18" of it.
Old 09-04-2012, 07:17 PM   #12
Ron Wardman
Beemerguy
Oddometer: 249
Mount
I made a small "L" shaped bracket and attached it to the back windscreen screw. Gets good reception and not likely to take a hit if I go down.
Ron Wardman is offline   Reply With Quote
Times are GMT -7.   It's 07:46 PM.
