Old 01-26-2012, 12:22 AM   #166
Patacca
Pimp my SE italian style
Patacca's Avatar
Oddometer: 568
Originally Posted by canadasax View Post
I was trying to find something stable so I could take some close up pictures. A plastic jar filled with pennies worked pretty well.
I must have 300 pennies in that jar, whats that worth.......$3.00
thanx!
If you aren't sure, open to MAX!!!
www.raffaellophoto.com
check out my pimped SE @
http://www.myktm.it/viewtopic.php?f=50&t=223
Patacca is offline   Reply With Quote
Old 03-14-2012, 12:48 PM   #167
jvg
jvg's Avatar
Oddometer: 37
Replaced my points today with a kit from Dr_Bean, received them only three days after they where shipped.
I have been running "the Swedish fix" -mod for the past year, it has worked flawlessly (the points still looks new) but i always felt it was a temporary fix.
The upgrade was easy, a bit fiddly to get the cables through the holes, solder and hold everything still at the same time.
Have not tried it running yet (only without fuel) but i'm sure it works fine.
/Joakim
KTM 950 Adventure S
| NorthCape 2010 | Geiranger 2011 | South Norway 2011 | Blh/Trontoppen 2012 |
jvg is offline   Reply With Quote
Old 03-14-2012, 01:35 PM   #168
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,475
How does the Dr Bean kit hold up to water contact? I've been through some pretty deep water with both my SE and ADV with the stock points. It's been mentioned a few times that water contributes to the destruction of the points. I've had these pumps apart and know they are not watertite.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-14-2012, 01:39 PM   #169
crazybrit
crazybrit's Avatar
Oddometer: 8,555
use the "search this thread" option above and enter "water", it's been discussed several times
crazybrit is offline   Reply With Quote
Old 03-14-2012, 02:10 PM   #170
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,470
I installed my kit yesterday...very well done, easy install.
I spent way too long trouble-shooting why it wouldn't work before finding out the ECU or relay or something cuts power three seconds after you turn the key on. Doh! I was chasing my tail on that one!
One question though: How did you get that little grommet back in place in the cap?
For Sale: 2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 03-14-2012, 02:12 PM   #171
slo rider
Oddometer: 59
Don't feel bad. I installed the board on 2 different spare pumps I had and couldn't get it to work. After Mr Bean helped troubleshoot, I found both pumps had an internal short. Found a working used pump to do the install and it worked like a charm.
Hit the gromet with a little WD40 and it'll slide right in.
slo rider is offline   Reply With Quote
Old 03-14-2012, 03:48 PM   #172
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,475
That's what happened to mine on the SE at 1100 miles. Points weren't the problem.
Old 03-16-2012, 10:26 AM   #173
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,147
Finally got the time to install mine.
Doing the task while on the bike is quite interesting.
The grommet in tight quarters was the hardest part for me.
I did a test run while the cover was off. Good thing. It was so quiet I had to look to see the plunger moving.
As it turns out I bought 2 of these kits. I was originally going to put one on my brand new spare pump. I've decided to just leave the stock new one alone. If I use it on the road for some reason I can swap the PCB over to it later when I get home.
So if somebody (CONUS) is wanting a kit send me a PM and I'll split the cost that I paid for the pair. Should be quicker than waiting for one from Europe.
Edit- This second kit has been sold. Dr Bean shipped these to me really quickly. Just do it thru him. Good seller. :)
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC
My2Wheels
dad2bike screwed with this post 05-03-2012 at 08:31 PM
dad2bike is offline   Reply With Quote
Old 03-16-2012, 10:29 AM   #174
ktm950se
ktm950se's Avatar
Oddometer: 1,385
PM sent
ktm950se is offline   Reply With Quote
Old 03-16-2012, 01:08 PM   #175
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,717
internal short
The internal short is due to the diode failing - can be fixed - worth your time? is another question. If you want to try PM me.
My 950KTM makes me feel like a little kid again......because it's so tall!
ridewestKTM is offline   Reply With Quote
Old 03-27-2012, 11:04 AM   #176
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,090
Received the little jewel today.
Very beautifully made, shining and minimal. Love it.
The hole GND is not to be used as per the photos?
Cheers.
gefr screwed with this post 03-27-2012 at 11:44 AM
Old 03-27-2012, 11:35 AM   #177
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,147
Originally Posted by ktm950se View Post
PM sent
Get it installed yet?
My2Wheels
Old 03-27-2012, 11:49 AM   #178
Dr_Bean OP
Dr_Bean
Oddometer: 109
Cheers.
Yes, correct. The original ground wire should be bolted below the stud, as described in the mounting instructions.
The pcb-GND hole is just in case the original ring-terminal failed somewhere, so you could solder the gnd-wire into the PCB instead.
see photos in this thread like:
Dr_Bean screwed with this post 03-27-2012 at 01:48 PM
Dr_Bean is offline   Reply With Quote
Old 04-04-2012, 01:27 PM   #179
Sumi
Sumi's Avatar
Oddometer: 1,822
Received the kit today!
Unfortunately I have to wait until the weekend to install it:) But it looks very promising:)
Sumi screwed with this post 04-04-2012 at 01:33 PM
Old 04-06-2012, 06:45 AM   #180
Sumi
Sumi's Avatar
Oddometer: 1,822
So I've installed the kit today:)
It was easy, and *sigh* hopefully won't have to pull the pump now for a couple 10k's of miles:) (this is a 2k miles old pump, and already I had to wiggle the points in the middle of nowhere 3 times, because it got stuck..)
I'm not very good at soldering - as you can see it on the last 2 pictures - but the pump is working, and everything looks good (the black-blue wire goes through the PCB - it's just not all the way in, as the tin always hardened before I could get it all the way through ( I think I've cut the wire too long), so I gave up - but it should be OK. IMO)
Thank you Dr_Bean once again for your help, and for the kit!
2k!!! miles old pump (not only the points, but the whole pump), and you can see that the points are already missaligned - and now and then they tend to stuck:
Sumi screwed with this post 04-06-2012 at 06:57 AM
Times are GMT -7.   It's 08:52 PM.
