Old 12-24-2012, 03:05 PM   #1711
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,370
Originally Posted by Ed@Ford View Post
can't remember where i saw it (maybe RamZ) but 3 / 2.5 / 5 / 4.5 / 4 / 4.5 was the cal settings
Has there been any discussion regarding stalling recently? It would seem one of these numbers deals with idle and off idle fuel (based on a quick glance explaining which number is applicable to which carburetor mode "analogy"). Or is it still being attributed to alcohol in the fuel?
Just went to RamZ's site...he says: "I spent some time reading up on the EJK. There are six numbers you can change that determine where in the power band and to what extent jetting changes are made. These are well-explained in the paperwork that comes with the EJK and on their web site. The numbers that are preset in the EJK are 3 3 6 5 4 4.5 which I verified before the first ride."
I did see that 2nd set of number's on Ramz site ... they correlate to EJK's website ... as Rick says also.
I'd be interested in confirming that the first set you listed is really the setting when it comes from BDSB. If it is then the Acceleration, Full Throttle, and Idle Lower Switch Point are all lower in the BDSB version than the EJK version. If I understand this properly, the Accel and FT is slightly leaner in the BDSB and the 'green zone' (or Idle zone) begins lower also.
Does this make sense to y'all?
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 12-24-2012, 03:11 PM   #1712
Ed@Ford
Oddometer: 1,630
I might make sense if I went back and studied the presentation from Dobek. I went to Best Dirt Bike and found no cal numbers....am lost as to where I found 3-2.5-5-4.5-4-4.5
Went to Dobek, and they refer you to EJK. What they sell for CRF and CBR are Version 3 devices, and sure enough 336544.5 are the starting cal #. Oddly, for the CBR250R you can also buy Version 3.5 devices...and of course it has a very different set of numbers. Odd that the CBR has 2 choices of devices...and the CRF only one...whatever, I'm probably confused and am busy confusing others......
Ed@Ford screwed with this post 12-24-2012 at 03:36 PM
Ed@Ford is offline   Reply With Quote
Old 12-24-2012, 03:37 PM   #1713
Krono
Speed Junkie
Oddometer: 193
Stock EJK settings are 3 3 6 5 4 4.5. Dont know for BDSB, but it should be the same, i guess.
I previously gave a personal set (3 2.5 5 4.5 4 4.5 witch is become 2 2.5 5 ...), stated I installed a "db killer" of my own.
Values are based on personal feeling and carbon deposit at exhaust. Not to much scientifical, but seems to works well in my case. This can still evolve as im experimenting, but snow here dosent make tries easy.
Here's a picture of the mod (FMF Q4 spark arrestor turned into a db killer) that induced these changes.
Its really efficient : cruise is quiet, but roars pleasently on full throttle.
L
SM510R
Krono is offline   Reply With Quote
Old 12-24-2012, 03:51 PM   #1714
Ed@Ford
Oddometer: 1,630
KRONO: Thanks
Old 12-24-2012, 04:02 PM   #1715
Krono
Speed Junkie
Oddometer: 193
KRONO: Thanks
You're welcome !
Happy if it helps
L
SM510R
Old 12-24-2012, 05:40 PM   #1716
'Flagger
'Flagger's Avatar
Oddometer: 2,370
Krono / Ed ... thx for the replies. My goal is to confirm that BDSB has actually done some work to figure out what settings work with the FMF bits that they're selling. Their website references 'our base map'. Are the settings different than that sold by EJK?
On the other side of the coin, the EJK literature says that the settings are appropriate for 'typical stage 1 modifications'.
Maybe they worked together to determine the settings?
- B
Old 12-24-2012, 06:06 PM   #1717
13Moose-man
Oddometer: 35
Originally Posted by 'Flagger View Post
A question for those of you who have purchased the Dobeck/EJK Fuel Controller sold by BestDualSportBikes.com ..... 13Moose-man, I'm looking at you.
Can you share the settings that the unit has on it's arrival? Are they different than the settings on the unit when purchased from EJK? For comparison the settings on the unit when purchased from EJK are: 3 3 6 5 4 4.5
The settings that it came with are 3 3 6 5 4 4.5 I have not done any tweaking around with it, bike runs great.
13Moose-man is offline   Reply With Quote
Old 12-24-2012, 06:12 PM   #1718
'Flagger
'Flagger's Avatar
Oddometer: 2,370
Excellent, Sir! Thank you very much. EJK settings and BDSB settings appear to be equal. Decisions, decisions.
- B
Old 12-24-2012, 06:25 PM   #1719
Harcomo
Oddometer: 119
Isn't this the programmer that BDSB's sells? Apparently their FMF branded one is programmed the same as the one from Dobeck. I guess it's up to the individual to tweak it if so desired.
http://fmfpowerprogrammer.com/viewpr...tnumber=014107
Harcomo is offline   Reply With Quote
Old 12-25-2012, 06:51 AM   #1720
koh kood
koh kood's Avatar
Oddometer: 121
Low front fender
Any suggestions on how to fit a low front fender?
"I wasted time, and now time doth waste me."
koh kood is offline   Reply With Quote
Old 12-25-2012, 12:41 PM   #1721
SAPB
SAPB's Avatar
Oddometer: 1,583
Well, to start with, being USD forks, something would have to fabricated. Lowest hard mounting point would be the bolts on the lower triple clamps, either eliminating, or go underneath the reflector bracket. Here are is some tie downs that use the mounting point I'm talking about, then go from there: http://www.manracks.com/#!product/zo...09044511/Honda CRF250L TieDowns,
SAPB is online now   Reply With Quote
Old 12-25-2012, 08:16 PM   #1722
NesquikNinja
Oddometer: 315
Metal bark busters, TCI skidplate with engine guards, radiator guard, folding shift lever....
Am I ready to make my first real venture off road without worrying about trashing my new bike? The pics may look offroad....but its just broken pavement, dirt roads, gravel, etc...only played in the mud a little it and its quite different than what I am used to.
Dont give a shit about cosmetics. Just cant afford to trash my bike and render in unrideable
Im trying not to worry about hurting my bike, but I swear I cant get that feeling away that developed in my history of sportbikes "If it falls, kiss your bank account goodbye"
How durable are these bikes? Someone please, make my fear go away!
EDIT:
XMAS fun, cold day, short ride.
Originally Posted by Sparrowhawk View Post
More stuff will clutter your life and make you poor. More adventure will richen your existence. Make do and make tracks.
NesquikNinja screwed with this post 12-25-2012 at 08:19 PM Reason: adding pics, because everyone loves pics
NesquikNinja is offline   Reply With Quote
Old 12-25-2012, 08:25 PM   #1723
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,237
Go ride and quit being a squid.
You got more than enough bike protection, how about rider gear for you? That sportbike gear won't cut it.
HARD boots like Sidi Crossfires, HARD armor like Thor Impact Rig SE, gloves with armor, pants with armor or knee braces under riding pants, Leatt brace, etc. Lots of options for that stuff.
Nancy walks away from all these get offs due to her personal protection... far more important.
Merry Christmas.
Just handgaurds.
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider is offline   Reply With Quote
Old 12-25-2012, 08:29 PM   #1724
NesquikNinja
Oddometer: 315
Merry Christmas.
Just handgaurds.
Amazing pics, thanks!
As for rider gear, Ill be ordering some Sidi or A* boots, and motoport gear soon. I stay off the trails in my leathers, lol.
Old 12-25-2012, 08:30 PM   #1725
JRaye89
Oddometer: 21
My new fender eliminator for 12oclocklabs
JRaye89 is offline   Reply With Quote
Times are GMT -7.   It's 12:43 PM.
