Old 01-01-2013, 07:26 PM   #1816
damasovi
damasovi's Avatar
Oddometer: 2,632
range?
Hi,
I saw this bike with joy at the IM show and like everything except the tiny tank (2 gallons?) so I was wondering how big was the range and if anybody is already making a bigger tank. This and the WR250 are bikes I really like but the Yamaha is a lot expensive-er.
So what options if any are there for 3-5 gallon tanks? (I read the last 20 pages of this tread and could not find any info)
Damasovi
A motorcycle or scooter always turn a bad day into a great time!
KLR 650, Honda Beat scooter!!
damasovi is offline   Reply With Quote
Old 01-01-2013, 08:01 PM   #1817
13Moose-man
Oddometer: 35
Spoke wrench size
Would anyone happen to know what size spoke wrench is needed. The so called "tool kit" that it came with didn't include a spoke wrench. Any thoughts on spoke torque wrenches, are they worth the money?
13Moose-man is offline   Reply With Quote
Old 01-01-2013, 08:26 PM   #1818
Spud Rider
Spud Rider's Avatar
Oddometer: 3,771
I own Motion Pro and OEM, Honda spoke wrenches. However, I also like my Tusk Spoke Wrench Set.
http://www.rockymountainatvmc.com/p/...k+spoke+wrench
Torque spoke wrenches are very expensive, and I don't trust them. When tightening spokes, I trust the feedback from my hand much more than I trust a torque wrench. As long as one applies common sense, it's very difficult to tighten a spoke too much.
Spud
Old 01-01-2013, 08:52 PM   #1819
trainman
trainman's Avatar
Oddometer: 397
The fuel tank is 2.3 gals., at 70 mpg the tank is ok for me, but others on long off road rides may want a larger tank. I don't think you will see a 4.0-5.0 gal. tank for this bike, lucky if a aftermarket tank is 3.0 or 3.3 gals. I'm going to go with the RotopaX Fuel Tank and carry it on the rear rack on the bike, for my extra long rides where fuel could be a problem.
John
trainman is offline   Reply With Quote
Old 01-01-2013, 08:55 PM   #1820
Fytclub
Oddometer: 17
Gps
Is there a decent GPS and mount that everyone is using?
Fytclub is offline   Reply With Quote
Old 01-02-2013, 12:50 AM   #1821
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,222
The Garmin Montana is the most powerful GPS on the market today for adv riding, and the rugged mount is awesome too.
Lots of options and probably best to search the Layin Down Tracks forum.
Mobile ADV Fix Complete
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider is offline   Reply With Quote
Old 01-02-2013, 01:19 AM   #1822
nbrooks
Oddometer: 30
Chain
I put the 13T front sprocket on with the stock chain. I had to move the rear tire back to get the slack out of the chain. I'm wondering if there is a master link for the chain but I don't know what will work. I'd like to get the rear tire as far forward as I can and am wanting to remove a link, if that will work, using a master link. Will it work or do I need to look at a different chain?
nbrooks is offline   Reply With Quote
Old 01-02-2013, 03:39 AM   #1823
Krono
Speed Junkie
Oddometer: 193
Instead of buying a new chain or cutting yours, you can fit a 42t rear sprocket in conjuction with your 13t front sprocket, then keep the original chain. It would gives you a 11.6% reduction, witch is still managable on road, and really better on dirt.
You will also need an odometer corrector, such the DRDspeedo.
You can get all this there http://www.crfsonly.com/catalog/index.php/cPath/290_293
Hope this helps
L
SM510R
Krono is offline   Reply With Quote
Old 01-02-2013, 06:03 AM   #1824
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 851
Hope this helps
L
+1 I run the 13/42 combination with the stock chain and I find it to be reasonable off road. And since the front sprocket is so easy to change, I also bought a 12t for the times when I temporarily need to ride knarley off road (haven't tried it yet though) -
In Loving Memory of Cruzin2B 1953 - 2014
SugarDust screwed with this post 01-02-2013 at 06:13 AM
SugarDust is offline   Reply With Quote
Old 01-02-2013, 07:42 AM   #1825
Road Dirt
Road Dirt's Avatar
Oddometer: 12
Thanks JR.
Fell off and messed-up some ribs so haven't been riding. Will get at the valve adjustment soon.
Originally Posted by JRNASTY View Post
I was wondering the same and found it over here:
http://advrider.com/forums/showthrea...t=valve&page=9
Per the Service Manual
Valve Clearance
Index line IN - 0.16 +/- 0.03 mm (0.006 +/- 0.001 in)
Index Line EX - 0.27 +/- 0.03 mm (0.011 +/- 0.001 in)
So my question, Anyone know a replacement folding shift lever and brake lever?
Road Dirt is offline   Reply With Quote
Old 01-02-2013, 08:25 AM   #1826
AZDavis
Oddometer: 9
Chain
MBrooks,
Why are you wanting to move the rear tire as far forward as possible? I just fitted the 13T sprocket over New Years but am a bit hesitant to do the 42T rear after reading all the trouble guys have had removing the stock 40T. I adjusted the rear wheel back 7-8mm to nearly the end of adjustment but have no chain slap. Is there some other advantage to moving the rear tire forward? You may notice that I am a legitimate Noob. Sorry if this is a silly question but i found myself wondering about the adjustment myself just 2 nights ago. Regards,
AZDavis is offline   Reply With Quote
Old 01-02-2013, 08:57 AM   #1827
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,125
Looks good... yeah lots of snow
Originally Posted by siyeh View Post
We have 20" of snow on the ground here in WI. So our bikes are in the basement for a bit. Merry Christmas to me.
I found some Aerostich Tank Panniers under the tree.
For $3 at the local hardware store I procured some front attachment points:
I think they will ride there just fine but need more road testing,,,,
And now it is just damn cold here in Wisconsin too... My bike is in the garage hooked to a battery tender up in Portage
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 01-02-2013, 10:19 AM   #1828
trainman
trainman's Avatar
Oddometer: 397
Can someone who has raised their handlebars up with risers tell me what will be the maximum height without having to re-adjust or replace the cables using stock bars, 1" or 2"s, John
Old 01-02-2013, 10:29 AM   #1829
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,098
Careful those bags aren't blocking air flow through the radiators by blocking the rear vents....
fastdadio is offline   Reply With Quote
Old 01-02-2013, 12:04 PM   #1830
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Heads Up...
Easton 1 3/8" EXP bars, adapter mounts and pad blowout for $40.00
http://www.motosport.com/dirtbike/EA...-BAR-MOUNT-KIT
xladv.com
MentalGuru is offline   Reply With Quote
Times are GMT -7.   It's 07:40 AM.
