Old 01-09-2013, 05:22 PM   #2026
DirtyBlackIrish
DirtyBlackIrish's Avatar
Oddometer: 153
Originally Posted by MentalGuru View Post
Zeta makes front triple mount handguard mounts also. If you look at the bend of the hand guard you'll see some work easier on higher bars. My handguards only cost me $10.00 so I wasn't to picky.
Perfect! I found the mount online.
Originally Posted by goondock View Post
go here http://www.advrider.com/forums/showt...3#post20216983
post #1404.
Slick looking shifter, easy to install seems to be really nice quality.. havent dropped the bike to test durability but looks like it would fair very well.
Yeah that looks nice! Plus it bends at the tip to help reduce chance of breakage I'm guessing.
Originally Posted by Balkan Boy View Post
They are not easy to find and everything Zeta makes is expensive. Part number: ZE71-1821
I have their hand guards and it seem like it would fit with a little bit of bending.
http://japan.webike.net/products/9669512.html
Yeah, I found it online. I see the bent ones vs the straight ones as far as contour goes. Looks much easier to make adjusting bends. That is what I'm going for.
Semper Fidelis
DirtyBlackIrish is offline   Reply With Quote
Old 01-09-2013, 06:00 PM   #2027
Harcomo
Oddometer: 120
Stalling issues
Originally Posted by Bob80 View Post
Anyone having any issues with their 250L's stalling for no apparent reason? I got about 800km on mine now, most of my drives this far have been mainly 30-40km's at a time,pretty much all pavement/dirt roads accessible by cars, and it will usually stall or quit at least once each outing. Mostly when stopped or slowing down to stop and once today while I was cruising along at about 50km/h, it just quit almost as if ya hit the kill switch. The bike will fire right back up no problem, just wondering if anyone else has a similar issue. I am about 99% positive it ain't my driving skills, as the wife's 250L doesn't have this issue (according to her, and I haven't noticed it the little i drove it either) May have to bring it up with the mechanic's at the dealer when it goes in for its 1st service, which I'm quite sure they will likely blame me also...lol
Originally Posted by Tommyrg View Post
Now that I think about it my 250l engine has done had the stalling issue on many occasions just didnt really acknoledge it and released the clutch....Vroom back on top. Mine may have done it 10 times out of the 4000 miles I have on it. Seems like everytime it did it was when I had been riding hard, choped the throttle grabed the clutch and downshifted.
Has there been any more issues with the stalling.....or possible fixes for it? I know it was discussed some awhile back..I had my first stall today going down the road about 45 mph, let off the throttle to slow down, shifted down through the gears, had the clutch in to grab first gear for a sharp uphill right turn and it just plain died.......like others have said, it was like shutting off the kill switch. I was maybe doing 5 mph when it shut off. I pulled over, hit the starter and it fired right back up. Kinda disconcerting you know, especially if someone was following you and all of a sudden you're dead in the water and get rear ended. That was my first ride after filling up at a Valero with 91 octane unleaded. Also the first ride with the FMF Q4 slip on installed. I also have the Dobeck fuel programmer that is on the factory preset settings. Maybe I should try gasoline from somewhere else next fill up as I don't think the Q4 pipe has anything to do with it. It seems to run good other wise. Or maybe program more fuel at the idle setting with the Dobeck? Who knows, maybe it will never do it again.....but I'm a little leary now.
Harcomo is offline   Reply With Quote
Old 01-09-2013, 06:07 PM   #2028
Bob80
Oddometer: 80
Ok, I'm done with handlebars.... What next????
How about Handgrips......so, the Answer pillow tops are no good??..... (just kiddin!!)
Bob80 is offline   Reply With Quote
Old 01-09-2013, 06:23 PM   #2029
TwilightZone
Oddometer: 3,205
>"Mostly when stopped or slowing down to stop and once today while I was cruising along at about 50km/h, it just quit almost as if ya hit the kill switch."
What are the current settings on the Dobeck programmer?
There was a stalling problem on the WR250R with some of the original programmer values.
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 01-09-2013, 06:29 PM   #2030
Bob80
Oddometer: 80
This looks familiar, No Dobeck programmer, all stock.
Harcomo, So, these issues are happening after the pipe and controller and weren't when the bike was stock? crazy!!.....keep us posted if ya get er figured out
Thx
Bob80 screwed with this post 01-09-2013 at 07:12 PM Reason: I answered my own question-read too fast!!
Old 01-09-2013, 06:44 PM   #2031
Harcomo
Oddometer: 120
The settings on my EJK are 3,3,6,5,4,4.5
This was preset from EJK for stage 1 modifications. I haven't changed any of the settings.
Old 01-09-2013, 07:03 PM   #2032
Harcomo
Oddometer: 120
Harcomo, Were these issues happening before the pipe and controller also? If so, then I guess the Dobeck must not solve it unless you can figure out a good setting mix...keep us posted if ya get er figured out
Thx
Nope, hadn't had a problem until today, so I guess it can happen with a bone stock bike like yours or one that has been modded with the Dobeck EJK like mine. I never had a stall when it was stock.....maybe I was just lucky?
Old 01-09-2013, 07:20 PM   #2033
Bob80
Oddometer: 80
Yeah, weird, but if for some reason you can solve it with your EJK then it may be similar to my issue (from factory) ... we might be on to something here...good luck and keep us posted
Old 01-09-2013, 07:31 PM   #2034
Harcomo
Oddometer: 120
Well, I'm open to suggestions from anyone who has any ideas. I'm new to EJK's and power programmers....this is my first one on anything.
It's supposed to be near 60 degress Friday......I will try to take another ride on it after work and see if it will do it again before the weather turns back cold this weekend.
Old 01-09-2013, 07:56 PM   #2035
roundtripping
Adventourist
roundtripping's Avatar
Oddometer: 1,704
Why are you using 91?
12 F658GS
13 Honda CRF250L
My SPOT Tracker
roundtripping is offline   Reply With Quote
Old 01-09-2013, 10:09 PM   #2036
gregitt
gregitt's Avatar
Oddometer: 14
My stalled as soon as I put on the fmf pipe, header and programmer. I perceive the bike is idling a little slower and perhaps causing this problem. I contacted Dobeck and he suggested adjusting the controller. GREEN/BLUE MODE 4 TO #1 position.
I have not done this because now I have adjusted my throttle style coming to a stop and it rarely does it..
I would like to know if anyone has compared performance with the 0-2 sensor unplugged and plugged? I have tried both and cannot seem to feel much difference. Thanks
gregitt is offline   Reply With Quote
Old 01-10-2013, 03:27 AM   #2037
Harcomo
Oddometer: 120
To tell you the truth, I'm not 100% sure......I think I recall the dealer told me that when I asked him what fuel to use, but not positive on it. Maybe I just dreamed that up.....should I just be using standard 87 octane?
Old 01-10-2013, 05:39 AM   #2038
Ed@Ford
Oddometer: 1,683
87 Octane?
If the owners manual says 87 octane, that's all you need, and 91 is a waste unless you lug the daylights out of the engine. BUT....here's a possibility: If the gas station is unscrupulous, he could be "splashing" in extra ethanol to make an 87 octane pass as a 91....but, since the CRF has an O2 sensor, it may get get confused by the ethanol, and modify your idle fuel enough to get a stall. Since ethanol carrys around some oxygen in it, it is possible to confuse the O2 sensor. This usually does not happen in automobiles because their computers go thru lots of little routines to keep idle speed extremely well managed because of automatic transmissions, air conditioner and power steering loading. SOOOO...see if you can get more stalling on this tankful...if so, safely burn off that tankful, and go elsewhere for fuel next fillup. I just have a bad feeling this engine/calibration is ethanol sensitive, because it seems stalling issues are particular to US owners...I THINK. We're the only ones....other than Brazil, that screw around with ethanol in gasoline.
Ed@Ford is offline   Reply With Quote
Old 01-10-2013, 05:45 AM   #2039
Ply318ci
Oddometer: 47
CRF250L IMS Footpegs
In case you guys are interested in new foot pegs the IMS Super stock and Pro-Series foot pegs for the CRF450R (02-08) will fit the 250L. They are part numbers 272219 for the Super Stock and 292220-4 (5/8" back) and 292219-4 (normal) for the Pro-Series. Just installed the Pro-series on a 250L and they look great and add more grip due to the larger teeth. The right side peg had thicker powder coating on the bolt hole so that had to be cleaned out but over all a nice fit. I will try to get pics up later.
Ply318ci screwed with this post 01-10-2013 at 10:14 AM
Ply318ci is offline   Reply With Quote
Old 01-10-2013, 06:08 AM   #2040
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 218
Harcomo,
If you have Hy-Vee gas station in your area, they sell ethanol free premium fuel. I fill my car up or at least squirt in a couple of gallons and then two 5 gal cans to make sure I get rid of any residual blend fuel from the pump/hose. Use the gas cans for lawn equipment and bikes.
While true, ethanol is used to raise the octane rating, alkylate is also used. Gasoline, in general, comes blended from the refinery and is not enhanced at the station.
CURRENT: None
PAST:
2013 CRF250L - 2009 DL650 - 1997 GL1500SE - 2005 DR-Z400S - 2008 DL650A - 2008 ST1300 - 2009 KLR650 - 2002 DR-Z400S - 1987 RM 250 - 1980 KD-80
Avi8tor is offline   Reply With Quote
Times are GMT -7.   It's 02:30 AM.
