Old 01-14-2013, 04:52 AM   #2161
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 866
Originally Posted by cat View Post
Let's stop before it starts.
On cbr250.net forum, there is a thread on doing the oil change, nice photos and all...it turned into a heated argument about oil, quite an absurd one too.
btw, the rear sprocket... the Renthal sprockets listed on ebay for CRF250L, i think they are actually CRF250R sprockets - in the pic (which is not very clear and cannot be enlarged) the bolt holes appear to have the countersink (instead of the flat recess that the CRF250L sprocket should have.) And the Renthal website does not list CRF250L. The holes could be drilled out to 10 mm, if there is enough space, but WTH, why are there no sprockets available? I was a bit surprised to see that the Honda parts manual only has the stock 14 and 40 sprockets; usually you get alternative / different size OEM sprockets.
I'm waiting for a local dealer to call me back about oil filters and gaskets - like do they have stock or how long would it take to get them. (Their system not working or something.) I explained to him that the CRF250L and the CBR250R have the same motor, so he could search it either way.
As usual, i know more about it than the dealer.
The xr250r late model front sprockets fit - I got 2 sizes for my bike, rear sprockets here:
http://sprocketcenter.com/index.php/...50-l-2013.html
2014 BMW R1200GS -- 2011 F650GS-- 2013 Honda CRF250L -- 2013 KTM 250 XCW
In loving Memory of Cruzn2b - 1953 - 2014
SugarDust is offline   Reply With Quote
Old 01-14-2013, 05:16 AM   #2162
cat
cat's Avatar
Oddometer: 1,323
Thanks, i'll check it out now.
What did you do about the chain? (Please see my earlier posts. DID 520 VF not listed in DID catalog, google turns up nothing.)
Here is a very good parts look-up facility:
http://www.hondapartshouse.com/oempa...f250l-ac-parts
cat is offline   Reply With Quote
Old 01-14-2013, 05:36 AM   #2163
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 866
my gearing is 13/42 - still running the stock chain
Old 01-14-2013, 05:43 AM   #2164
cat
cat's Avatar
Oddometer: 1,323
JT rear sprocket
sprocketcenter, note:
*Sizes 40,42 and 43 are custom drilled sizes
You can see in the image there; they have the normal countersink 8mm holes and the 10 mm recessed holes are added so it fits CRF250L.
They are JTR301, listed for various XR250, XR600, XR650.
Old 01-14-2013, 06:08 AM   #2165
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 866
yes thats right - the first rear sprocket they sent me was shipped without the countersink - I called and he sent a new one properly drilled out immediatly (basically an oops) . Oh and btw, the XR650L sprocket bolts work.
Old 01-14-2013, 06:25 AM   #2166
itrack
Oddometer: 115
I run Rotella T6 Synthetic in everything I own, 4x4 Tundra, Civic, ES300, CR250, IT200, CRF250L, lawn mower, spec Miata, etc. You can get it at Walmart, been running it for 4 years now in everything. My friends call me the "product tester". Every friend of mine now runs Rotella. Great oil, cheap, found everywhere. What else could you want.
The 94-04? XR250R front JT 13t sprocket from motorcycle-superstore is $13. Just ordered one last week.
itrack is offline   Reply With Quote
Old 01-14-2013, 06:29 AM   #2167
itrack
Oddometer: 115
Originally Posted by JRaye89 View Post
Can you please post a link to where you bought all your performance upgrades from. Thanks
slip on
http://www.jcmotors.com/p-27985-big-...50-l-2013.aspx
ejk tuner, same as fmf, made by dobeck
http://www.phatperformanceparts.com/...TARDEJK&CartID=
XR250R front JT 13T sprocket
http://www.motorcycle-superstore.com/
Old 01-14-2013, 08:25 AM   #2168
gnath9
gnath9's Avatar
Oddometer: 281
When I get around to ordering all my parts (getting c/c paid down first) I think these guys have a lot to offer.
http://www.crfsonly.com/catalog/prod...oducts_id/4743
I still need to decide on what gearing to go with. If the lower chain guide was not an issue I think I would just put a 50 on the rear and leave the front a 14. I am currently thinking of going with a 13/45 combo.
gnath9 is offline   Reply With Quote
Old 01-14-2013, 08:41 AM   #2169
bungie4
Frostback
bungie4's Avatar
Oddometer: 501
Hardly surprising, that forum smells like a Junior High locker room. I've been on it since 2011 and only venture in there when I'm bored.
2013 FJR1300, 1984 CX650e, 2013 CRF250L - Help when you need it -http://www.assistancelist.com
bungie4 is offline   Reply With Quote
Old 01-14-2013, 10:27 AM   #2170
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,328
If your obsessed with knowing how the oil you chose is doing you can spend $25 and have it analyzed here:
http://www.blackstone-labs.com
I send in the oil from my Husaberg regularly, but I also push the envelope with the miles I put on that high performance engine's oil in my travels, sometimes doubling recommended intervals out of pure necessity.
While the Husa does have a wet clutch and calls for full synthetic, I won't be spending the cash for it on the Honda as I don't think it really is going to matter in the long run, there's too many Honda's in the world that have many miles using whatever standard oil is around and lets face it, this engine isn't high performance. Maybe I'll try a semi-synthetic to see if it will help the shifting be smoother, after we get plenty of miles to wear in the engine but maybe not...
It's a Honda, just ride it.
Lost Rider is offline   Reply With Quote
Old 01-14-2013, 10:49 AM   #2171
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Previously, I exclusively used Easter Timber Rattlesnake Oil, harvested only from serpents employed during religious snake-handling ceremonies in Appalachia. Croatalus horridus, the timber rattler, when harvested from the free range, produces unsurpassed base oil stocks. These excellent base stocks are further, miraculously enhanced during the religious ceremonies.
Unfortunately, the cost of collecting, handling, and harvesting these serpents has became prohibitive, so I switched to 15W/40 motor oil. The diesel motor oil is doing an excellent job for me, so I intend to keep using it.
Spud
Old 01-14-2013, 11:11 AM   #2172
RockRacing
Oddometer: 14
RockRacing is offline   Reply With Quote
Old 01-14-2013, 12:22 PM   #2173
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 369
Originally Posted by EEKAMOUSE View Post
Anyone know the triple clamp torque spec? Thx for the info in advance!
Hey when your all done worrying bout oil could I plz get those torque specs from someone with a manual.
EEKAMOUSE is online now   Reply With Quote
Old 01-14-2013, 12:38 PM   #2174
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,328
you looking for the specs for the pinch bolts (forks) connecting to the triple clamp or the triple clamp connecting to the frame or the bars connecting to the triple clamp?
Old 01-14-2013, 02:18 PM   #2175
itrack
Oddometer: 115
Got an email saying my Big Gun Evo Eco was on back order from the other company posted earlier. I emailed Tom at tom@biohazardcycles.com and he sold me one for $175 shipped. Tom was great to work with over email and sent me an invoice within 10 minutes of requesting one. Figured I would pass this on as its the cheapest slip on by a long shot I have seen.
Times are GMT -7.   It's 03:33 PM.
