Old 01-22-2013, 02:01 PM   #2446
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
Originally Posted by SAPB View Post
Yes, just went out to look, since I'm thinking of doing the 13/42 soon...
Instead of a 13T/42T sprocket combination, you might consider the 14T/45T sprocket combination. The 45T sprocket is stock for the Honda XR650L, therefore, many choices are available. I employ the Primary Drive sprockets available from Rocky Mountain ATV/MC on my XR650L. I like these sprockets very much, and they only cost $19.99.
http://www.rockymountainatvmc.com/p/...Steel-Sprocket
Spud
Old 01-22-2013, 02:17 PM   #2447
Krono
Speed Junkie
Oddometer: 193
Spud
... what would gives almost the same gearing reduction but at the added cost of a new chain, as 13/42 allows you to keep the stock chain.
L
SM510R
Krono is offline   Reply With Quote
Old 01-22-2013, 02:19 PM   #2448
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
The XR650L rear sprocket is also commonly available with 48 teeth.
In addition, the PBI C/S sprocket for the CBR250R/XR250R is available in sizes from 12T-15T.
http://shop.pbisprockets.com/product...&categoryId=20
Therefore, one could also employ a 48T/15T sprocket combination instead of a 13T/42T sprocket combination.
However, I think a 45T rear sprocket is a good choice. For technical off road riding one could employ the stock, 14T front sprocket with the 45T rear sprocket. Then, one could easily swap a 15T, PBI C/S sprocket for lower rpms during extended street riding. The larger sprockets reduce wear on both sprockets as well as the drive chain, thereby extending the service life of all three components.
Spud
Old 01-22-2013, 02:21 PM   #2449
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
L
Yes, that's true. Therefore, it would be best to switch to a 45T rear sprocket after one needs a new drive chain.
Spud
Old 01-22-2013, 02:26 PM   #2450
Krono
Speed Junkie
Oddometer: 193
Spud
Yup ... but let's wear the stock chain with a 13/42, then use the stock 14t contersprocket w/ a new rear sprocket and a longer chain
Thats economy
L
SM510R
Old 01-22-2013, 02:26 PM   #2451
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
L
Another factor to consider is possible interference with the chain guide and/or chain guard when using 45T, or larger sprockets. Also, the larger sprockets might cause accelerated wear of the chain guide slipper, part #9 in the following diagram.
Spud
Old 01-22-2013, 02:31 PM   #2452
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
If one wants a 13T C/S sprocket, I can also recommend the Primary Drive C/S sprocket for the XR250R. These excellent C/S sprockets only cost $8.99.
http://www.rockymountainatvmc.com/p/...Front-Sprocket
Spud
Old 01-22-2013, 02:34 PM   #2453
Krono
Speed Junkie
Oddometer: 193
Spud
This chain guide slipper have to be reversed when using a 42t.
I guess i would simply remove it with a lager sprocket, unless i can find a suitable aftermarket part.
L
SM510R
Old 01-22-2013, 02:37 PM   #2454
Larry Ferguson
Oddometer: 88
L
You wouldn't really need a whole new chain. You could get another master link and add enough links to make it work. I have run chains with 2 master links many miles with no trouble. Plus, it makes it easy to switch back if needed.
I also like Sanford and Son but, since I am not a junk dealer in 1970's Watts, I find it hard to criticize his methods.
'01 Connie
'83 XT 550
'78 XL 350
'73 XL 250
'72 XL 250 (Needs "assembly")
Larry Ferguson is offline   Reply With Quote
Old 01-22-2013, 02:45 PM   #2455
Krono
Speed Junkie
Oddometer: 193
True
I didnt even consider this, because were I live, chains have to be riveted (by law).
Not that can't be done, but put aside, the 13/42 w/ stock chain is a "no brainer"
L
SM510R
Old 01-22-2013, 02:47 PM   #2456
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
L
I completely removed the chain guide slipper on my XR650L. The chain guide slipper is installed to prevent the drive chain from leaving the rear sprocket. My XR650L has greater suspension travel than the CRF250L; however, I have been riding the last 16,000 miles without any drive chain problems. Nevertheless, a more "spirited" rider might derail the drive chain if he removed the chain guide slipper.
I also removed the chain guard, since I don't carry passengers on my bike. Drive chain maintenance and rear wheel maintenance are much easier after the chain guard and the chain guide slipper have been removed.
Spud
Old 01-22-2013, 02:47 PM   #2457
Harcomo
Oddometer: 118
I guess I didn't realize this......if I ever read about it, I had forgotten!
So you just unbolt the slipper and flip it over with the beveled end now on top and facing the rear?
Harcomo is offline   Reply With Quote
Old 01-22-2013, 02:53 PM   #2458
Krono
Speed Junkie
Oddometer: 193
I dont remember ... but just unbolt it and you'll figure out
L
SM510R
Old 01-22-2013, 02:55 PM   #2459
Spud Rider
Spud Rider's Avatar
Oddometer: 3,777
No, if you turn the chain guide slipper upside down, it will wear very quickly. I think Krono rotated the chain guide slipper 180 degrees, so it did not extend so far from the rear of the chain guide. I imagine a larger rear sprocket will rub the extended rear of the chain guide slipper, unless you rotate it.
Given the way I ride, I would just remove the chain guide slipper entirely. However, I don't jump my bikes, et cetera. A very aggressive rider should keep the chain guide slipper; otherwise, he risks derailing the drive chain.
Spud
Spud Rider screwed with this post 01-22-2013 at 03:50 PM
Old 01-22-2013, 03:19 PM   #2460
roundtripping
Adventourist
roundtripping's Avatar
Oddometer: 1,702
Looks like things are moving along over at Scott's...
http://www.scottsonline.com/Stabiliz...L&BI_ID=243800
12 F658GS
13 Honda CRF250L
My SPOT Tracker
roundtripping is offline   Reply With Quote
Times are GMT -7.   It's 08:56 PM.
