Old 01-23-2013, 11:45 AM   #2491
Krono
Speed Junkie
Oddometer: 193
Originally Posted by SAPB View Post
Uh oh, that doesn't sound good. Were you able to walk/ride away from that? Tough while is around freezing, most of the roads can seem alright, then you get into a spot that has not had the sun on it, in a shadow.
I was paying attention and was slow...
No damage on the bike. Only me feeling dumb to ride in these conditions
L
SM510R
Krono is offline   Reply With Quote
Old 01-23-2013, 11:50 AM   #2492
NesquikNinja
Oddometer: 316
Update on my starting issue- I went to get my bike from my buddies to head to the dealer and it fired right up. Let it warm up, oil level is fine. Everything is running just fine. Ill blame it on the cold, for now....unless it gives me trouble again.
EDIT: What racks are you guys using and happy with?
I need help deciding how much load space I need and which rack is right for me, whether it be just a top rack, or a full rack, or what.
All of my "trips" will consist of 1, maybe two nights camping (damn responsibilities!). Id like to be able to carry extra fuel, non-motorcycle boots, a sleeping bag, a tent, and some food/beverage. Will just a top rack be enough? Id really like to avoid having to wear a back pack except a camelback. I have never had a dual sport, and had nearly 90l of cargo space on my last bike, not counting the pillion seat, so packing was easy.
For commuting I'm just going to strap a milk crate to the top rack and throw all my stuff in there with a net on top
Originally Posted by Sparrowhawk View Post
More stuff will clutter your life and make you poor. More adventure will richen your existence. Make do and make tracks.
NesquikNinja screwed with this post 01-23-2013 at 12:11 PM
NesquikNinja is offline   Reply With Quote
Old 01-23-2013, 12:05 PM   #2493
gaw777
Oddometer: 59
Originally Posted by Lost Rider View Post
I just purchased the the Flatlands because it's a one piece design and I think it will provide the best protection for what's available now. But for now that's just speculation as the UPS guy still has it, like many other peoples comments around here on things they haven't actually used or tested. Too much talking, not enough riding... normal for winter time on ADV I guess.... We will be testing it undoubtably and I will share how it does in the near future.
That's what I am looking for, real time usage to see, how does it fit, does it work like advertised...
I like learning from other people's experience
Keep us posted.
Nancy could be the official parts tester.
gaw777 is offline   Reply With Quote
Old 01-23-2013, 12:08 PM   #2494
gaw777
Oddometer: 59
Originally Posted by 'Flagger View Post
Also consider Cogent Dynamics in NC. Rick had my OEM shock for baseline testing prior to building a custom unit. His conclusion was that the shock can be opened and revalved. Call for details.
Disclaimer: not affiliated, just a happy customer.
You had Cogent Dynamics work on your 250L shock, or a different shock?
If so, did you have them modify it?
Old 01-23-2013, 12:31 PM   #2495
SAPB
SAPB's Avatar
Oddometer: 1,585
L
Riding in less than ideal conditions is one thing, having someone in a car behind you not realizing why you are riding that way is more dangerous. I hate that when someone is on my tail in a car.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 01-23-2013, 12:39 PM   #2496
Ed@Ford
Oddometer: 1,633
Questions are popping up on racks....might as well add mine. most pick up the four "long neck socket head bolts" that hold the seat on and stick out the sides of the rear fender...seem stout...and are robust M8's.....but, since they have a overhung force on them might not be the best choice
Then there are a couple of racks (Flatland for one) that have 4 big studs that sprout straight up out of the rear fender...but are all pretty close together. My Husky TE610 had that and I wasn't real thrilled with that either, as creating the hoes in the rear fender for the bolts to go thru was a PITA.. If one had the dimensions of that pattern, it'd really be easy to make your own with a plate of appropriate dimensions to match your luggage.... I've seen the bolt pattern dimensions for the WR250R....but nada for the CRF
Ed@Ford is offline   Reply With Quote
Old 01-23-2013, 12:45 PM   #2497
Krono
Speed Junkie
Oddometer: 193
Yes, but car drivers are pretty smart here, and let me always pass when they see me behind.
Only one tailgated me today
L
SM510R
Old 01-23-2013, 12:48 PM   #2498
SAPB
SAPB's Avatar
Oddometer: 1,585
I like my Manrack, the one with the Rotopax plate in it. They include bolts the replace the original seat bolts that stick out. There are spacers, so you wouldn't be able to use the original seat bolts. At the time, it was free shipping before the holidays, that was the kicker for me. As a bonus, they threw in a pair of the tie down things, that go under the lower triple clamp bolts, no charge. The rack seems pretty solid to me, but I haven't had anything real heavy on there yet.
Old 01-23-2013, 01:02 PM   #2499
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,373
Apologies for the lack of clarity. It was my CRF250L shock that they tested. Didn't do any mods however... I decided to go the custom route with them instead.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 01-23-2013, 01:10 PM   #2500
Spud Rider
Spud Rider's Avatar
Oddometer: 3,787
That's great! Do you know when your custom shock absorber will be completed? If you don't mind me asking, how much is Cogent Dynamics charging for a custom shock absorber?
Spud
Old 01-23-2013, 01:18 PM   #2501
SAPB
SAPB's Avatar
Oddometer: 1,585
I don't have a picture of the Manrack on my bike, but here's how it looks on Tony's bike. That's what made me decide on this rack.
Originally Posted by G19Tony View Post
I finally got around to installing the rack today. It literally took 5 minutes. Everything fit perfectly. I don't have any pictures without the Rotopax adapter, but, you will get the idea. For day to day riding the adapter might be in the way, but it would be a quick matter of loosening the front bolts, removing the rear bolts and rotating it up to get to the adapter bolts. I'm very pleased with the quality of Mike's work.
Old 01-23-2013, 01:28 PM   #2502
Ed@Ford
Oddometer: 1,633
Yes, the ability to handle a rotopax...which I already have...is a big feature
Old 01-23-2013, 01:42 PM   #2503
bungie4
Frostback
bungie4's Avatar
Oddometer: 484
I've got the Manrack with the Rotopax plate as well. Haven't mounted it up yet (Hey, it was -49F here last night!). I'll be shopping around for a 1.75g Rotopax which appears to be a new tank and not carried by all suppliers. The 1.75 can be filled to 2 gallons which would be a full tank for the CRFL. Same dimensions as the 1g tank except thicker.
Come to think of it, I've got a bunch of toys waiting to go on the CRFL. I'm gonna have fun with it in the spring
-Steve
2013 FJR1300, 2004 FJR1300, 2013 CRF250L
I have a job, I explore, I follow every little whiff.
On/Offroad help when you need it - http://www.assistancelist.com
bungie4 is offline   Reply With Quote
Old 01-23-2013, 01:43 PM   #2504
Spud Rider
Spud Rider's Avatar
Oddometer: 3,787
Thanks for posting the photos. That's a nice luggage rack.
Do all the available luggage racks utilize the same, four mounting points? With these mounting points you need to remove the two, front bolts to remove the saddle, don't you?
Spud
Old 01-23-2013, 01:45 PM   #2505
SAPB
SAPB's Avatar
Oddometer: 1,585
I think the difference between the "bottom end" rack, and the one with the RP mount was $20. I wanted the ability to add the RP later on, for longer trips. I think that's a pic of Tony's bike on the Manrack site. The pic of it on his bike has the front mount tucking in real tight in the front, maybe have to put the seat on after. Mine, the front mounts are wider, and have spacers between the rack and the mount point. I had to wiggle a Phillips screwdriver in there to line up the mount point. 10 minute job. It only came with replacement front bolts (allen, not the same wrench size), and I re-used the long bolts in back.
Times are GMT -7.   It's 08:38 AM.
