Old 02-25-2013, 01:32 PM   #3421
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 218
Here's the skinny on the IMS tank.
Available for pre-order now. Probably available in 3 to 4 weeks.
Black or natural for first run.
3.1 gallon capacity.
$274.95 MSRP.
CURRENT: None
PAST:
2013 CRF250L - 2009 DL650 - 1997 GL1500SE - 2005 DR-Z400S - 2008 DL650A - 2008 ST1300 - 2009 KLR650 - 2002 DR-Z400S - 1987 RM 250 - 1980 KD-80
Avi8tor is offline   Reply With Quote
Old 02-25-2013, 01:35 PM   #3422
Charleston
Charleston's Avatar
Oddometer: 90
Originally Posted by Lost Rider View Post
Honestly though I believe this failure was caused by inexperience and too much high revving, wrong gear while slipping the clutch. Brutal sand dune riding conditions with a rider who's never ridden in them.
Few bikes will keep taking what I saw without breaking something IMO.
If this failed under normal conditions I would agree and be exploring a warranty claim, but at least in this circumstance it was rider error that caused it for sure. There's a right way and a wrong way to use a clutch, high rev's in high gears and slipping the clutch isn't the way to do it.
Live and learn, at least the replacement is easy and relatively cheap... just glad we were able to get it home 250+ miles, could have turned into a real PITA.
I’m no expert but I don’t fully get why some of us have gotten the clutch to bite more when we increase the freeplay. Because if it is really “freeplay” shouldn’t there be basically no force counteracting the clutch springs? I’m wondering if factory recommendation for freeplay actually keeps enough tension on the cable to cause some slipping.
'13 CRF250L
'10 Ultra Classic
Charleston is offline   Reply With Quote
Old 02-25-2013, 02:01 PM   #3423
gnath9
gnath9's Avatar
Oddometer: 281
I ordered some zeta "shorty" adjustable levers thinking I may have a little more flexibility in this regard.
gnath9 is offline   Reply With Quote
Old 02-25-2013, 02:28 PM   #3424
kiwi5
Oddometer: 385
torque settings?
Clutch replacement DIY.
Long story short, a friend fried the clutch while learning how to ride off road and in sand.... luckily loosening up the clutch cable gave us just enough friction to get home from Death Valley, with the clutch slipping in high gears for the last 20 miles.
After some research I found that EBC makes replacement friction pads and springs for the CRF250L, available locally direct from manufacturer but I have to place the order though this company, then pick up at warehouse:
http://www.perfectbrakes.com
Part # CK1313 for the friction plates and #CSK188 for the springs, which they say are 10% stiffer than OEM.
The steel plates are looking fine and are not warped so I wont be replacing them.
I'll be going by the warehouse to pick them up later today, $65 for plates, $10 for springs.
Here's a DIY of getting the clutch apart, it's pretty straightforward and took me about a half hour to get it open.
Drain oil, drain coolant through drain plug on intake, not much coolant will come out until you loosen the cap on the radiator, then it sprays out all over the place 2-3 feet out from the bike.
Remove hose
disconnect clutch cable, I used a screwdriver to push the lever back to slide it out
Remove brake lever, kick plate, and brake switch bracket.
Remove bracket that holds clutch cable, then oil tube or whatchamacallit.
Remove bolts holding engine case on, in a crisscross patten, Rotate clutch lever counterclockwise to disengage lifter arm spindle while removing the cover.
Remove bolts holding clutch plates in crisscross fashion and then slide out clutch plates.
And for you folks who like to stress/obsess about keeping the LRP tip top, I found this screen hidden behind the cover with plenty of metal flakes and what looked like pieces of case sealant from the factory. I guess there's a pre filter in our bikes.
That's about all there is to it, replace it with new plates and in opposite order, if I find anything while putting it back together I'll edit this post. Don't forget to change the oil @ 600 miles just like when new, the contamination from bedding in the new clutch plates is one of the main reasons for that first oil change.
-Finn
Great post! What were the torque settings for all the little bolts or did you do you just crank it tight?
kiwi5 is offline   Reply With Quote
Old 02-25-2013, 02:42 PM   #3425
trainman
trainman's Avatar
Oddometer: 397
Wow, the new IMS tank is $275.00 plus freight that would put it at about $300.00 delivered, I think I will stick with the one gallon Rotopax for $50.00 and be happy, plus I can move it to my other bikes if needed.
John
trainman is offline   Reply With Quote
Old 02-25-2013, 02:44 PM   #3426
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,427
John
Capacity?
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 02-25-2013, 02:51 PM   #3427
trainman
trainman's Avatar
Oddometer: 397
3.1, that figures out to, 1 extra gal. for $300.
Old 02-25-2013, 02:52 PM   #3428
Larry Ferguson
Oddometer: 88
Originally Posted by 'Flagger View Post
Capacity?
"Wow, the new IMS tank is $275.00 plus freight that would put it at about $300.00 delivered, I think I will stick with the one gallon Rotopax for $50.00 and be happy, plus I can move it to my other bikes if needed."
One gallon?
I also like Sanford and Son but, since I am not a junk dealer in 1970's Watts, I find it hard to criticize his methods.
'01 Connie
'83 XT 550
'78 XL 350
'73 XL 250
'72 XL 250 (Needs "assembly")
Larry Ferguson is offline   Reply With Quote
Old 02-25-2013, 03:42 PM   #3429
siyeh
Lawn Nazi
siyeh's Avatar
Oddometer: 1,689
One gallon?
A one gallon Rotopax on a Manracks:
me likey it cheaper than a new tank
siyeh is offline   Reply With Quote
Old 02-25-2013, 04:07 PM   #3430
'Flagger
'Flagger's Avatar
Oddometer: 2,427
One gallon?
Suck it, Trebek.
Trainman knew what I was asking.
Looking at IMS' website, $275 seems to about par for all of their tanks of similar capacity. The big capacity tank (4.7g) for the WR-R is ~$400.
- B
'Flagger screwed with this post 02-25-2013 at 04:18 PM
Old 02-25-2013, 04:21 PM   #3431
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,316
$274.95 MSRP.
That's great news!
Natural color for me please ASAP.
Is it for certain that it will be replacing the OEM tank, only giving a 1 gallon increase or is it 3.1 in addition to the OEM tank? That's what I need, 5 gallon capacity....
Since the fuel pump and other bits are in the tank I would think this is an add on tank.
$275 is a bargain, IMO. I won't even mention how much other extra fuel tanks have cost me on other bikes...
Plus when you factor in the tank will serve as a great Radiator protector, plus protect the other bits on the right side, it's a good price... anything to get heavy fuel off the worst spot possible for handling - on the tail rack, where lightweight camping gear needs to go.
Got the new clutch in hand and putting it back together now.
Lost Rider is online now   Reply With Quote
Old 02-25-2013, 04:23 PM   #3432
'Flagger
'Flagger's Avatar
Oddometer: 2,427
$274.95 MSRP.
Hmmm.... so this is the post I missed .... I blame Tapatalk.
- B
Old 02-25-2013, 04:25 PM   #3433
'Flagger
'Flagger's Avatar
Oddometer: 2,427
That's great news!
Any wisdom as to why 'Natural' over 'Black'?
- B
Old 02-25-2013, 04:26 PM   #3434
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Suck it, Trebek.
JustGasTanks offers free shipping for purchases over $150. The also sell their fuel tanks at a discount from the full retail price. I sent them an email, and they confirmed they will be selling the IMS tank for the CRF250L.
Spud
Old 02-25-2013, 04:26 PM   #3435
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 218
That's great news!
A 5 gallon tank would be something.
Yes...replaces stock tank for 3.1 gallons total.
CURRENT: None
PAST:
Times are GMT -7.   It's 09:31 PM.
