Old 03-21-2013, 12:46 PM   #3946
gnath9
gnath9's Avatar
Oddometer: 276
Originally Posted by emreturkeli View Post
Ok.. Maybe I'm stupid but where is this number 12 thing on the bike? under headlight? on the tail? underneath one of the side covers? How can I reach it?
I believe it is behind the horn and over flow bottle. I have seen a post on this somewhere
I would remove your plastics from the right hand side as I don't think the guy had to remove the tank. Maybe lift it a little as I am sure it is tucked up out of the way.
gnath9 is offline   Reply With Quote
Old 03-21-2013, 12:50 PM   #3947
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,330
I just hand the entire front end of my wife's CRF250L apart and I don't remember seeing a turn signal relay under there. The connections to disconnect the turn signals are there, but I don't remember a relay, but I wasn't looking for it either. My guess would be on the right side by the overflow bottle.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 03-21-2013, 12:56 PM   #3948
emreturkeli
emreturkeli's Avatar
Oddometer: 120
I also dismantled the whole head today and it's not there... Will see the right side cover tomorrow! Thanks Guys!!
Emre Turkeli
"Specialist"
ARh-
emreturkeli is offline   Reply With Quote
Old 03-21-2013, 03:13 PM   #3949
kiwi5
Oddometer: 385
Clutch
So what other clutches will fit in the CRF250L? As others have pointed out, the CRF250L clutch may not be the best so would a CRF250R cluth fit?
kiwi5 is offline   Reply With Quote
Old 03-21-2013, 08:00 PM   #3950
mcrosser
Only the truth
Oddometer: 12
To Answer KIWI5
The CRF250R is a completely differnt bike design to the CRF250L. The best bet is the CBR250R clutch, its a stronger clutch and it will fit. The added bonus is as there several race series for the CBR so theres plenty of aftermarket engine and transmission compoments that fit the CRF250L.
Hope this is useful info.
mcrosser is offline   Reply With Quote
Old 03-21-2013, 09:14 PM   #3951
BigAHelm90
Oddometer: 6
fuel programmers
Hey guys so I finally picked up my first bike the cool little 250l. love it so far. I was planning on doing a couple of mods to just kinda make the bike mine. So far I did a fender eliminator kit to get rid of all that junk hanging of the back and I put on the fmf q4 slip on. I did no mods to the air box or the header. I haven't put a fuel programmer on is. So my question is has anyone one just put the slip on on with no programmer and did it run fine? And do you think my bike is running to lean or rich with just the slip on and no programmer. Sorry for all the questions but just one more. If I absolutely need a programmer are there any suggestions for a good one? I was more of a plug and play type. I don't want to have to hit a buch of buttons or anything. All feed back would be apreciated
BigAHelm90 is offline   Reply With Quote
Old 03-21-2013, 09:21 PM   #3952
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
I have an opinion on this....
If it isn't broke why try to fix it?
For the very few folks who are spending big bucks seriously modding their engine to produce much more HP than OEM, and are feeling slipping then sure, OK, I understand concern, par for the course taking the motor far beyond it's intended design, and probably why I wouldn't be doing every mod possible to squeeze every ounce of power of the non-race motor. Possibly making the LRP less reliable for our long distance ADVenture Riding, I hate hiking in MC boots. We all have different needs or passions when it comes to bikes so there's no right or wrong IMHO though.
For most folks, even those who do more common mods like just a Stage 1 kit or a fuel controller and/or exhaust why stress about it if there no proven issues? As far as I know we have the first CRF250L clutch replacement needed in our little community online, hardly a common issue yet.
We push our LRP on a weekly basis, beat on it even... I'm no master mechanic, we're spending more time riding instead of tinkering, but even with the Bazzaz fuel controller and power improvements I've never felt the clutch slip on big knarley hill climbs with the lever fully extended.
Our clutch failure was surely caused by operator error while a client was riding the bike, not because these clutches are weak IMHO.
Folks that want a slightly stronger engagement can replace the springs with stronger ones and get rid of the Judder Spring in the clutch assembly for not much cash or work. I have no experience as to if this will make a clutch last longer, just make the engagement stronger feeling or more abrupt.
With what I've done to ours it does feel slightly more definitive in engagement, but like I said I never felt the clutch slip either way with the lever released.
The EBC aftermarket pads part number is the same for CRF and CBR 250, so I'm not even sure how different the clutches actually are, but I'm no CBR expert, I just ride. ;)
See this thread for a little Judder Spring discussion, something I discovered accidentally after replacing the LRP clutch and Ed pointed out the correct term for the springs I removed and a little internet searching.
Or do your own google search on judder springs, lots of various points of views on many forums, while the racers like the mod methinks some riders might want to consider leaving it alone for a while, especially less experienced riders who can benefit from what the judder spring actually does.
http://www.advrider.com/forums/showt...=859691&page=3
http://www.thumpertalk.com/topic/935...ch-engagement/
http://www.thumpertalk.com/topic/864...judder-spring/
Lost Rider screwed with this post 03-21-2013 at 11:50 PM
Lost Rider is offline   Reply With Quote
Old 03-21-2013, 09:26 PM   #3953
mcrosser
Only the truth
Oddometer: 12
Hi BigA
Any thing you do to the induction or exhaust will make the bike run leaner. As standard the bike will be at the best set up for economy and you can see that from the MPG they return.
You should be ok with the slip-on. for the best results as everyone has said on here you will need the header as well as the slip-on and fuel controller.
Only do the airbox mods, if you decide to do it once you have the fuel controller on the bike
Dont run it lean or your be in danager of damaging the valve seats and possibly the piston.
Depending on where you live there should be many options for the controller.
I hope this info helps you.
Steve
Old 03-21-2013, 09:45 PM   #3954
BigAHelm90
Oddometer: 6
Hi BigA
Steve[/QUOTE]
Hey steve thanks alot for the info. So you think the. I should be fine with just a slip on and no programmer?
Old 03-21-2013, 09:54 PM   #3955
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,389
I had always figured that the ECU would adjust the fuel injection to compensate for the additional airflow, thereby preventing the lean condition that occurs in a carburated bike with similar mods.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 03-21-2013, 10:32 PM   #3956
gaw777
Oddometer: 59
Stallin
I have been away from the forum for awhile. Ride my bike mostly off-road and just this weekend the bike stalled on me, twice. Once on a single track while decelerating getting ready to go around a corner and another time while decelerating. Once I dumped it, it would not start for a few minutes. I know the bike was pretty hot when it stalled and when it would not re-start.
I do have the megabomb, Fuel programmer and q4 can. Has about 500 miles on it.
Any definitive answer on the stalling? Maybe re-adjusting the programmer for on the idle setting to keep more fuel flowing at the lower rpm?
2010 ktm 690smc, 2013 crf250l
gaw777 is offline   Reply With Quote
Old 03-21-2013, 11:00 PM   #3957
mcrosser
Only the truth
Oddometer: 12
[QUOTE=BigAHelm90;21005725]Hi BigA
Steve
Hi BigA....The basic map in the standard ECM should be able to compensate for the slip-on.
If you do any work on the induction side of the bike you will need a fuel controller to re-balance the fuel/air ratio which will increase the torque & BHP and prevent damage to the engine.
Steve
Old 03-21-2013, 11:08 PM   #3958
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
I don't know about the stalling issues as we've not had that happen, but when we've dropped the bike (while very hot) it was necessary to turn the bike off then back on or it wouldn't start. Once I hear the fuel pump kick on it always starts right up, but without "resetting" the bike it will just turn over and over. I thought the tip over sensor has to get reset to kick the fuel pump back on.
How/when did it re-start?
Did you cycle the ignition key?
You did the stage one mod kit during break in? It hasn't had the first service yet then, how many miles without the mods did it have before you installed them?
Maybe that could have to do with your stalling, though I think Kiwi has had similar unresolved occasional stalling issues, but also before the 600 mile break in period was done I think. Not sure if a fuel controller could effect how the ECU "learns" on a new bike. Maybe someone with better understanding of the black arts of FI can comment.
Sorry to hear of your troubles, good luck getting it sorted.
Old 03-22-2013, 02:53 AM   #3959
D-Real
Oddometer: 7
Thanks for the warm welcome Lost Rider. To answer your question, no I'm not able to take the motorcycle saftey course at this time. It's only on weekends and I drive a charter bus. Weekends I'm always running. Currently im on my permit. I did get the rest of my gear, pants, jacket, gloves, boots and helmet. I ordered from Motor Cycle Super Store. Shipping was fast.
Kind of a newbie question I know but what's the best fuel to use in my CRF? I'm at 35 miles right now and I'm still using the fuel it came with. The dealer said I could use regular, mid grade or premium. I'm wondering what the best choice is.
Thanks again for the welcome.
D-Real is offline   Reply With Quote
Old 03-22-2013, 05:09 AM   #3960
emreturkeli
Oddometer: 120
Right where you said!! Thanks man! It was all done under 15 minutes! My flashers are no longer in rush!!
Emre Turkeli
"Specialist"
ARh-
Times are GMT -7.   It's 02:06 PM.
