Old 04-09-2013, 12:58 PM   #4261
kiwi5
Oddometer: 385
Ejk tuner
Okay, just spoke to the tech team at EJK and here is the verdict on the 02 sensor: try it on/off and see what you feel. He said that it improved performance on some bikes, not so much on others. There could be a reduction in fuel efficiency with it removed- he reckoned if there was an improvement you would certainly feel it in the old "seat of pants" test. We also spoke about what airbox mods to do with a stock bike exhaust and EJK tuner: remove snorkel and backfire screen is the answer. Drilling holes all over the airbox was not recommended. Maybe open up the top more if you live in some crazy high altitude USA state. That's it boys- straight from the horses mouth! I also discussed fuel effiiciency- 5-7% reduction at cruising speed on the highway is the answer. Impossible to really give an answer when you are thrashing the bike offroad as there are too many variables. Right, as soon as I finish work I am off to test my bike with the 02 on/off, I've got a paddock with no cows in it next to the house. There is a steep hill and some trees to do figure eights around. Good testing ground. When there are no cows. Or sheep.
kiwi5 is offline   Reply With Quote
Old 04-09-2013, 03:34 PM   #4262
emreturkeli
emreturkeli's Avatar
Oddometer: 120
Waiting for that answer hoping that it will be "no need to remove o2 sensor"
Emre Turkeli
"Specialist"
ARh-
emreturkeli is offline   Reply With Quote
Old 04-09-2013, 03:46 PM   #4263
bhoneydew
Oddometer: 2
Does anyone have any experience with 2-up riding? I am close to buying one and might have a passenger every now and then. Thanks :)
bhoneydew is offline   Reply With Quote
Old 04-09-2013, 04:13 PM   #4264
emreturkeli
Oddometer: 120
My wife said that it's acceptable for short runs in the city, but no way for longer trips.
Of course we need to keep into consideration that our last bike was a 2012 Kawasaki Versys 1000 Tourer with a Gel Seat!! (which was closely sized to our sofa)
PS: She's 163cm and 47kg by the way..
Emre Turkeli
"Specialist"
ARh-
emreturkeli screwed with this post 04-09-2013 at 05:16 PM
Old 04-09-2013, 04:46 PM   #4265
bhoneydew
Oddometer: 2
My girlfriend is 5'10 so I am hoping it isnt too cramped. We'll try it out at the dealer to be sure. Looking to ride up into the mountains 20 kms or so to do some exploring and fight the Samsqauntch.
Old 04-09-2013, 05:35 PM   #4266
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,337
How tall are you because that might be a pretty cramped ride? To make room for her on the back, you might be really pushed up on the tank yourself and the CRF has a pretty small and cramped seating position. Most DS bikes aren't known for their 2up comfort, but a 20kms ride may not be too bad since its pretty short.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is online now   Reply With Quote
Old 04-09-2013, 06:00 PM   #4267
kiwi5
Oddometer: 385
From what the tech team at EJK said, there is no need to remove it- the EJK tuner will work fine with it clipped in or out. But your bike MAY work better with it removed, apparently the difference is noticeable. If you don't "feel" a decent improvement then clip it back in. It is very easy to unclip it and clip it back so you should try! If your bike works better with it unclipped then you may want to tape the loose end to the frame to protect it. Oh, the other comment made by the tech team at EJK is that the 02 sensor is there mainly to assist in complying with EPA regualtions. Now I really want to un-clip it!!!
kiwi5 screwed with this post 04-09-2013 at 06:05 PM
Old 04-09-2013, 06:54 PM   #4268
kiwi5
Oddometer: 385
Don't torque that bashplate too tight!!!
I was just inspecting the CRF250L we have at work and noticed that the BB Bashplate was bolted on wayyyyyyy too tight. The mechanic cranked on the two front bolts so tight that the tabs on the frame have bent and it looks like hairline cracks on the tabs as well! My attention was drawn to this because I noticed some rust on the left side tab, so the motto is: don't torque those bashplates on too tight. Now I will have to get our local engineering firm spot weld these tabs and paint on some rustproof paint. I will be very careful when I install the bashplate on my bike that's for sure!
Old 04-09-2013, 07:28 PM   #4269
Harcomo
Oddometer: 120
EJK Tuner
I've never messed with the O2 sensor on my bike......maybe I'll try it unclipped someday when I get bored.....seems to run fine with it still attached. I bought the EJK with the intentions of installing a full FMF exhaust. I started out with the FMF slip-on muffler and decided it was too loud for me and put the stock muffler back on but I'm still running the EJK programmer. One nice thing about the EJK is that you can return the EJK to stock fueling without uninstalling the unit should you decide you want optimum fuel mileage for a trip, etc. You just set the FUELING modes (green, yellow, red) all to light setting 0.5 to revert back to stock. It only takes a minute or so to do this.....how cool is that? Then you want to pump more fuel for more power off road......just reset whatever settings you were running previously. The only drawback for me is I have to remove the seat to get to it but that's no big deal.
Harcomo is offline   Reply With Quote
Old 04-09-2013, 08:29 PM   #4270
kiwi5
Oddometer: 385
I was not aware of the "return to normal" function! Very cool. So far my fuel efficiency has not changed enough for me to want to revert back however. I am horrified of messing with the EJK settings but someday I might try...... We have a FMF Q4 slip on that was installed on the CRF we have at work, nice weight savings- VERY LOUD. I'm glad I got the EJK and not the slip on for my bike.
kiwi5 screwed with this post 04-09-2013 at 08:35 PM
Old 04-09-2013, 09:44 PM   #4271
carlclaflin
Oddometer: 249
Originally Posted by xjon View Post
Pic of where my CRF got me today...
are you a HAM? just wondering, with the antenna towers behind. i live in so.cal for number of years. if so what your call sign? mine is KG6PMD.
carlclaflin is offline   Reply With Quote
Old 04-09-2013, 10:40 PM   #4272
xjon
Pedantic Bastard
xjon's Avatar
Oddometer: 387
No HAM here...
But I do love Bacon!
Antennas are on top of Saddleback Mtn. Just needed some mega dose of radiation.
06 1200GS (since day 1)
13 CRF250L (3/2013)
xjon is offline   Reply With Quote
Old 04-10-2013, 03:29 AM   #4273
Harcomo
Oddometer: 120
I am horrified of messing with the EJK settings but someday I might try.......
Then try this demo.....just press the Mode and the Plus (+) and Minus ( - ) buttons to make adjustments....works just like the one on the bike.
http://electronicjetkit.com/demos/HPcurve.swf
Harcomo screwed with this post 04-10-2013 at 08:54 AM Reason: spelling
Old 04-10-2013, 07:00 AM   #4274
G19Tony
G19Tony's Avatar
Oddometer: 418
Wolfman side racks, on the way!
BMW F800GT, Hodaka Dirt Squirt, Honda CT70, Honda Grom, Zongshen RX3
G19Tony is offline   Reply With Quote
Old 04-10-2013, 11:04 AM   #4275
SAPB
SAPB's Avatar
Oddometer: 1,619
So, looking at the pictures on the site, looks like the rear seat bolts are used. So that means you can't keep the Manrack, I'm thinking. Also, there appears to be a mounting point near the passenger foot peg. Actually if you don't have them yet, you may not know. The top rack seems to make it necessary to drill holes through the fender like the Flatland.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB screwed with this post 04-10-2013 at 11:22 AM
SAPB is offline   Reply With Quote
Times are GMT -7.   It's 09:21 AM.
