Old 04-21-2013, 07:34 PM   #4441
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,249
Originally Posted by Ed@Ford View Post
LOST RIDER...RE: Multiple Master Links. I wouldn't worry about multiple masterlinks if installed properly. Most of the new clip style masterlinks almost need a press to get the side plate on. After the clip is on properly, put a very slight bit of press...but in the opposite direction to PINCH the clip tight in it's groove. Then add a bit of 0.025" SS safety wire around the narrow part of the side plate and the clip. It won't come loose any time soon!
sounds good in theory, I do know how to install one, but the issue I've had is with putting lots of miles on a chain, in just one trip I've worn out the clips from them rubbing on the chain guides/sliders and then had them come off. A safety wire around a chain link wouldn't last on my bike. I've lost a clip-on a couple times, once while in the Yukon which wasn't very convenient.
We all have our ways and opinions, while having a clip on master link come off isn't a major concern, I've run tens of thousands of miles with them, failure has happened and for me using a crimp on makes most sense - there's zero chance of that link coming apart or wearing out. I treat my bikes as a racer would because of the frequent far from civilization places I like to ride. You won't see a race bike with clip on master links, ever.
Chances are for most folks if installed right there will be no problem, but like I said by running 2 you're doubling your chances of some that either by being installed wring, or wearing out, or when just the right rock hits in just the right spot can fail.
For someone on the east coast where it's nearly impossible to get too far from help, sure, go for it and run two master links, carry a spare and don't worry about it, chances are it will be fine, I just wont tke that chance anymore based on my experience. I understand wanting to experiment with gearing, go for it, I just have to share my opinion with the dangers I see from what I've seen instead of blindly telling people something is OK to do. You are right, I wouldn't worry about it too much if installed properly.
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider is offline   Reply With Quote
Old 04-21-2013, 07:37 PM   #4442
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,249
Originally Posted by Copperhead88 View Post
I did not cut the end off of the throttle I just more or less drilled out the end cap to the same diameter as the ID of my bars. Im pretty sure they are the wrong size inserts
OK, you'll need to trim the throttle tube something like in my photos to use any handgaurd on the bike, the insert/bolt is going to pull the guard against the bars, that's where the strength comes from. You need the throttle tube to rotate freely and not touch the guards. Good luck and feel free to ask more questions when you get soem new guards, if I can help I will.
LostRider.com
Old 04-21-2013, 07:45 PM   #4443
NesquikNinja
Oddometer: 330
Serviced my shock linkage and swing arm today. Pleasantly surprised by the condition of everything inside and how easy it was with the manual.
Originally Posted by Sparrowhawk View Post
More stuff will clutter your life and make you poor. More adventure will richen your existence. Make do and make tracks.
NesquikNinja is offline   Reply With Quote
Old 04-21-2013, 07:52 PM   #4444
Okie03
Oddometer: 4
Disc Brake Guards
Another question for you gentlemen, have any of you found rear & front disc brake guards? A buddy of mine ordered some off of CRFSonly, but they ended up not fitting correctly. Appreciate the help!
Okie03 is offline   Reply With Quote
Old 04-21-2013, 08:18 PM   #4445
Copperhead88
Oddometer: 16
ok, that makes sense. Id rather not buy new bars right way, what are some other options for good looking handguards? I have a really big issue with the majority of run of the mill handguards in terms of looks.
What about the zeta handguards with the turn signals in them. Are they any good. Will I sacrifice my visibility to other drivers at all?
Copperhead88 is offline   Reply With Quote
Old 04-21-2013, 10:05 PM   #4446
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,249
I'll defer to others about brands I haven't used, I will say that i understand the need to like the looks of stuff you're buying, but for me function/protection over form takes precedence, there's nothing cool looking about a bike that is broken and immobile on the trail so try to get something to serve it purpose first and might look pleasing to you.
Barkbusters and Cycra probends are brands I've used in the past, and broken.
good luck.
LostRider.com
Old 04-22-2013, 12:42 AM   #4447
billfires
Oddometer: 43
Auto-X, Lost, Ed, thanks for your thoughts. Initially I think I will try the 13 tooth counter sprocket with the stock chain and stock rear 40 tooth sprocket. I am trying to figure out what I will go to when they need to be replaced. I still only have about 500 miles on and have only done about 10% of those as two lane dirt. My only other experience with a chain on a full size dual sport was back in the early 1980's on a Honda SL350. Again, I reallt appreciate everyone's thoughts and hope to put some miles on as the weather warms up. Bill C
billfires is offline   Reply With Quote
Old 04-22-2013, 05:47 AM   #4448
Ed@Ford
Oddometer: 1,653
LOST & Others: My experience with chains is 99.9% with Honda XRs. Side wear/clip wear from the chain guide friction is quite rare, and the safety wire lasts for a year at a time (I re-do it annually). Since I had a freak chain fracture a few years back when a stick jammed in it....and all the associated towing/walking/pushing/shit cell phone service hassles...I now carry all the associated tools and hardware for chain repair. That total "kit" weight/complexity would certainly be no different with tools to do a pressed link over a clip link....so take your choice...either is good
carry
Ed@Ford is offline   Reply With Quote
Old 04-22-2013, 06:52 AM   #4449
dsn11487
dsn11487's Avatar
Oddometer: 52
Valve Adjustment
Yesterday I just completed half of my valve adjustment. As in now I need to go get shims to put it back together. My question is, both of the exhaust measurements were good, and were the same. However my intake clearance check gave me one valve that was super loose and one that was within the allowed tolerance. Is this normal? Should I be worried? I just found it odd and was curious as to other peoples experiences.
2005 FJR (the blue ones are faster)
2013 CRF250L
dsn11487 is offline   Reply With Quote
Old 04-22-2013, 10:02 AM   #4450
Lapchik
Tinkeritis posterboy
Lapchik's Avatar
Oddometer: 355
Can anyone give me some tips on installing my bar end mounted hand guards? Im not sure what to do with the throttle side. I read one review where the guy messes up his throttle when installing his guards but I didnt really understand why that happened.
Also, can I just slap on my old rox risers or do I need to modify the throttle and clutch cable setup in some way?
http://www.youtube.com/watch?v=i37CdTGQ294
I broke my throttle tube. I put a new throttle tube in, and cut the end cap off while it was still off the bike.
Lapchik is offline   Reply With Quote
Old 04-23-2013, 02:38 AM   #4451
ausspo
Oddometer: 17
Emperor Gear
Originally Posted by ausspo View Post
How much are the Emperor skid plates and rad guards?
Did you get them from a dealer in NZ?
What do you think of their luggage rack?
Thanks in advance
Yep bought the Emperor plate and radiator guard, really good quality stuff. Price was right too. Better fit and finish than any aussie gear out there right now.
ONE BEFORE ELEVEN, ELEVEN BEFORE ONE
ausspo is offline   Reply With Quote
Old 04-23-2013, 02:44 PM   #4452
willbeoutdoors
Oddometer: 11
i am going to grease the suspension linkages due to the comments about them not being lubed well. I have never done it before and hopefully wont run into problems. I am wondering about the swingarm bearings though, do they need to be greased right away too? taking the swingarm off seems like a lot to take apart and I don't want to do more harm than good. anyone?
willbeoutdoors is offline   Reply With Quote
Old 04-23-2013, 03:29 PM   #4453
gnath9
gnath9's Avatar
Oddometer: 270
I took my bike to a local race mechanic and he did what was called new bike prep. He did the steering tube bearings and both axle and wheel bearings the swing arm and suspension linkage for $125.00
I felt that was very reasonable considering how long it would have taken me to do all that.
gnath9 is offline   Reply With Quote
Old 04-23-2013, 04:23 PM   #4454
pandamanprod
pandamanprod's Avatar
Oddometer: 96
Anyone Have a CRFL BIG BORE kit OTHER than Rick Ramz?
Looking for any performance results or issues, did a search on this forum, could only pull up brief posts from last year, and some comments on rick site. Apologies if I just skipped over this.
pandamanprod is offline   Reply With Quote
Old 04-23-2013, 04:42 PM   #4455
kiwi5
Oddometer: 383
Yes, do the swingarm bearings as well. Pretty easy to do the swingarm bearings- I had our mechanic show me when he did this on our CRF250L at work. Basically the steps are: Remove chainguard (and mudguard covering rear shock if you want to see what is going on but not necessary), unscrew rear brake hose from swingarm to give you some play, take out top dogbone bolt and bolt that attached to bottom of shock (this will allow the swingarm to drop down), then remove the swingarm pivot bolt, at this point push the rear wheel and swingarm forward- this will give you the slack to remove chain, now pull rear wheel and swingarm back, the swingarm now drops down and you can wipe out the non-grease that is in there and pack in new grease. Re-assemble in reverse order and don't forget to grease the swingarm bolt. He did all of this in a matter of minutes. I will do mine this weekend. The linkages are pretty easy to do as well. Hope this makes sense.....now you have to figure out how to do the steering bearings! I'm going to have a mechanic do the steering bearings on mine...might be a step to far for me! NOTE: You will need some sort of bike stand to do this.
kiwi5 is offline   Reply With Quote
Times are GMT -7.   It's 06:55 AM.
