Old 05-04-2013, 08:14 PM   #4621
G19Tony
G19Tony's Avatar
Oddometer: 418
Originally Posted by NesquikNinja View Post
Nearly 3000 miles on her now. Needs new tires!
Having a blast thought. Saved a turtle on a day ride the other day- poor little fella was hard side down in the middle of the road.
Good job on the turtle rescue.
Everybody needs a hand up after an off sometimes.
BMW F800GT, Hodaka Dirt Squirt, Honda CT70, Honda Grom, Zongshen RX3
G19Tony is offline   Reply With Quote
Old 05-04-2013, 10:45 PM   #4622
Saleendude07
Oddometer: 10
I installed the ekj programmer on my bike today. When I turn the key on it flashes green and red which mean something is not fully connected or not properly connected. I've checked it twice now and it seems to be correct. Does the bike need to be running in order for this programmer to show the proper lights?
Saleendude07 is offline   Reply With Quote
Old 05-05-2013, 02:27 AM   #4623
mtntrails
Oddometer: 470
Crf300l? Crf300m?
http://www.visordown.com/motorcycle-...ing/22716.html
mtntrails is offline   Reply With Quote
Old 05-05-2013, 03:41 AM   #4624
SAPB
SAPB's Avatar
Oddometer: 1,615
Originally Posted by g19tony View Post
good job on the turtle rescue.
everybody needs a hand up after an off sometimes.
+1
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 05-05-2013, 04:12 AM   #4625
G19Tony
G19Tony's Avatar
Oddometer: 418
Originally Posted by mtntrails View Post
Bringing out a 300 wouldn't be enough to make me switch. A 350/450? I'm there!
Old 05-05-2013, 05:44 AM   #4626
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Originally Posted by RayMurdock View Post
While searching for street orientated tires i came across some tubeless tires like the bt45 - perhaps stupid but these will never work right because of the air leaking spokes?
There's no reason you can't run a tube in a tubeless tire, the BMW F800GS and R1200R Classic come with tubes with tubless tires stock and I have run countless ones myself. That's the cheapest method.
You could also send your wheels into Woody's Works Works and have them sealed so you can go tubeless, with your location that might not be the most cost effective though.
The Shinko 705 makes for a great inexpensive long lasting "street" tire is you're looking for something like a 90/10 tire.
Lost Rider screwed with this post 05-05-2013 at 05:50 AM
Lost Rider is offline   Reply With Quote
Old 05-05-2013, 06:57 AM   #4627
Buckshot77
Buckshot77's Avatar
Oddometer: 42
All good...flashes red and green because there is power to the injector but no signal... Start it, the red goes away and the green scroll lights start up..
You got it!
Buckshot77 is offline   Reply With Quote
Old 05-05-2013, 08:18 AM   #4628
Saleendude07
Oddometer: 10
Awesome! Thanks for the reply. FedEx delivered everything but the muffler yesterday, so I am kind of dead in the water now
Old 05-05-2013, 08:37 AM   #4629
Buckshot77
Buckshot77's Avatar
Oddometer: 42
No problem,
U can try it out without it,just change settings to 1.5,1.5,3 and leave change points the same to tune it for stock exhaust....works great you'll really get to see what that tuner does without your muffler then change it back when you add the muffler.
I've played with mine a bit and its awesome..just the tuner alone has my vote for best bang for your buck mod!
Old 05-05-2013, 08:40 AM   #4630
Chris S
Oddometer: 194
I am running Slime in my CRF but tubeless is the way to go.
I have experimented over the years and sealed off the spokes in my Tenere wheels one time but didn't do a very good job (on the front at least):
http://adventure-motorcyclingh.com/2...ubeless-tyres/
I think the way this adv-er Cyb, did it was better:
http://cyb.smugmug.com/gallery/72508...979239&k=UFqYE
I also fitted Tubliss to my GS-R last year:
http://adventure-motorcyclingh.com/2...ubliss-liners/
Worked fine but would not do Tubliss again for travelling as keeping 100psi in the liner can be a bit of a reach (actually 80 will do).
Prefer simple spoke sealing.
I believe Woody's don't do 21s? - I know Tubliss didn't sell them in the UK at the time.
I get a feeling 21s can be problematical - diameter vs width - or maybe just safety?
Also, it's important your rim has the 'safety lip' alongside the well inside (graphic in links above). I changed a tyre on my CRF the other day (3000 miles from the OE tyre?!) and it doesn't have them so spoke sealing not such a good idea - but Tubliss will work without 'safety lip' rims.
Chris S screwed with this post 05-05-2013 at 09:23 AM Reason: clarified
Chris S is offline   Reply With Quote
Old 05-05-2013, 08:57 AM   #4631
SAPB
SAPB's Avatar
Oddometer: 1,615
I believe Woody's don't do 21s? - I know Tubliss don't. I get a feeling 21s can be problematical - diameter vs width - or maybe just safety?
Here's a 21: http://www.amazon.com/Neutec-Tubliss...=TUbliss+21%22
Old 05-05-2013, 09:41 AM   #4632
Ed@Ford
Oddometer: 1,662
Originally Posted by Buckshot77 View Post
No problem,
Thanks...this is good info to know ( 1.5,1.5,3 ) for the stock exhaust. So...is this the same as EJK modifying NOTHING...or is it a bunch of ZEROS = modifying nothing?
Ed@Ford is offline   Reply With Quote
Old 05-05-2013, 10:10 AM   #4633
Turk
'Bab Man
Turk's Avatar
Oddometer: 118
Oh er missus!! I'm loving this bike more & more everyday!! 7 CRFs out today...me in action
Second one was a bit sketchy!
Turk is offline   Reply With Quote
Old 05-05-2013, 10:19 AM   #4634
SAPB
SAPB's Avatar
Oddometer: 1,615
That looks fun, how did the suspension handle the landing? I came down wrong in loose sand on the front, and was surprised I didn't loose it. It was fairly low speed, though, 2nd gear.
Old 05-05-2013, 10:53 AM   #4635
Chris S
Oddometer: 194
... So...is this the same as EJK modifying NOTHING...or is it a bunch of ZEROS = modifying nothing?
I think zeros = nothing.
1.3/1.5/3 is what Dobeck recommended to me changing back to stock pipe and airbox and it runs fine once warm - now average 73 mpg.
Times are GMT -7.   It's 09:58 AM.
