Old 05-09-2013, 07:07 AM   #4711
MBRedline
Oddometer: 14
Yeah I pumped up to about 16 1/2 front and rear last night just to be on the safe side
Sent from my rooted XT912 running AOKP Aviator
MBRedline is offline   Reply With Quote
Old 05-09-2013, 07:12 AM   #4712
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,278
A couple more tips regarding not damaging the valve due to low pressures... when your tire is off next time, use a drill and elongate the hole in the wheel. And then when you reinstall the tube, don't put the nut down against the rim. Put it on, then screw the cap on, then back the nut up against the cap to stay tight. That way the stem can move around without slicing itself.
I need to do this on my KLX.. but I had already mounted the new rear tire before hearing about this tip. :)
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 05-09-2013, 07:58 AM   #4713
Chris S
Oddometer: 194
White Rim Trail
My L on the WRT on Tuesday - just about the best 150 miles I've ridden in years.
On the back was a new Maxxis Desert and tyres both at road pressures. To me the advantage of knobblier tyres means you don't have to reduce pressures:
As high as possible;
As low as necessary (to avoid flats).
Halfway round I was amazed to come across an 1150 going the other way (heading for the harder half). Fully loaded with gear and on Anakees... It rained that night; I wonder if he made it.
Chris S is offline   Reply With Quote
Old 05-09-2013, 08:25 AM   #4714
Ed@Ford
Oddometer: 1,683
White Rim....loaded 1150?....might as well have been driving a schoolbus. Been there on my XR400R...good to see the CRF had no problems.
Ed@Ford is online now   Reply With Quote
Old 05-09-2013, 12:32 PM   #4715
Brandon805
Get the camera
Brandon805's Avatar
Oddometer: 12
Went for a jaunt yesterday. Wow. I'm really enjoying the Q4 - even without the fuel programmer or the header. I do have the 02 sensor unplugged, and am sans emissions choke collar. Anyways, took off from home and enjoyed the Santa Monica Mountains after our fire. I was happy that I picked up the Butler motorcycle map for socal the other day, it pointed me in the direction of a few roads I didn't know about. A great ride I'll tell ya, and wrapped it up with a smoke break by the lake.
https://maps.google.com/?t=p&z=15&q=...54cbb885799e25
(You have to zoom out 3 times to view the full track)
I'll take the red one
During my ride I made a sweet noob mistake and fell over in a parking lot
My clutch-side handgaurd was bent in the spill, restricting my clutch lever's movement. I had to bend the handgaurd up further so I could use the clutch at all on my way home! Today i decided to make sure that doesn't happen again.
Brandon805 is offline   Reply With Quote
Old 05-09-2013, 12:39 PM   #4716
Vspec
Vspec's Avatar
Oddometer: 175
Originally Posted by Brandon805 View Post
Are those Acerbis Rally 3? How did they survived?
Vspec is offline   Reply With Quote
Old 05-09-2013, 02:00 PM   #4717
Brandon805
Get the camera
Brandon805's Avatar
Oddometer: 12
They're the Rally Pro X-Strong. The one that hit the ground (absorbing all of the impact and saving my clutch lever when I was out) only got bent. I was able to straighten with a vice this morning, good as new
Old 05-09-2013, 02:57 PM   #4718
Boismj03
Boismj03's Avatar
Oddometer: 118
CRF 250 L for sale in Boise
Crf 250 L for sale in Boise
http://boise.craigslist.org/mcy/3794877356.html
1st annual MU Adventure ride!
http://advrider.com/forums/showthread.php?t=1072012
Boismj03 is offline   Reply With Quote
Old 05-09-2013, 04:42 PM   #4719
Chris S
Oddometer: 194
CRF250L for sale in Phoenix
Crf 250 L for sale in Boise...
Well if that's permitted here then let me plug my own CRF-L
http://phoenix.craigslist.org/wvl/mcy/3790047569.html
(or let the mod's axe fall)
Utah story so far.
Old 05-09-2013, 04:43 PM   #4720
Boismj03
Boismj03's Avatar
Oddometer: 118
If its not ill pull it....
Utah story so far.
Old 05-09-2013, 06:18 PM   #4721
Vspec
Vspec's Avatar
Oddometer: 175
Why are you guys so far away
Old 05-09-2013, 09:01 PM   #4722
DirtyBlackIrish
DirtyBlackIrish's Avatar
Oddometer: 153
Nice!!!!
Semper Fidelis
DirtyBlackIrish is offline   Reply With Quote
Old 05-11-2013, 08:45 AM   #4723
frog13
frog13's Avatar
Oddometer: 1,371
Fly there, Ride back!......Still surprising that folks are selling mostly new bikes already.....I understand the bike being too tall for the guy's wife though......heck,I'm 5'09" and can't flat foot one.
frog13 is offline   Reply With Quote
Old 05-11-2013, 04:33 PM   #4724
Auto-X Fil
Oddometer: 703
I greased the swingarm bearings today. It took about half an hour start to finish. They were not packed with grease, but rather had a thin coat of a clear oil/grease on them. The whole assembly is so well sealed that I see no cause for alarm. If you put the swingarm pivot underwater regularly, maybe pop it open and put some marine grease on it. Otherwise, I think Honda knows what they are doing, and the lube is sufficient, if not traditional. I won't be opening the steering.
Auto-X Fil is offline   Reply With Quote
Old 05-11-2013, 09:05 PM   #4725
kiwi5
Oddometer: 385
Yeah, I am not to worried about greasing my steering bearings for the first year and I will be doing the swingarm bearings for peace of mind. The linkage bearings were a different story on my bike, corrosion had already started on one of the bolts and if I had waited another six months or so it would have been pretty ugly. Guys who ride offroad all the time grease all these bearings on a regular basis but for the casual gravel rider I would recommend doing all the linkage and swingarm bearings when you first buy the bike- then forget about it for a couple years!
kiwi5 is offline   Reply With Quote
Times are GMT -7.   It's 05:20 AM.
