Old 05-25-2013, 09:12 AM   #4846
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,249
Originally Posted by kiwi5 View Post
Where is the idle screw and what direction did you turn the screw?
Originally Posted by RayMurdock View Post
It's hidden behind some factory paint - some pictures or article on this mod would be nice (hint to self).
Would this be the screw you increased the idle with?
Originally Posted by Lost Rider View Post
Yesterday while removing the radiator to take in for repairs I poked around a little and it seems like there's a set screw on the throttle body you could adjust to bring the idle up a bit if you keep having the bike stall. Maybe that would help and something to consider it if still happens after the first service.
From page 153
http://www.advrider.com/forums/showt...23409&page=153
What's better than an LRP?....
TWO LRP's!!!
ADV FF Brandon stopped by last week for a beer and to chat, ( and help me wrench on a bike, thanks!) here's a couple photos of the bikes, and a comparison of handlebars with KX High/ROX risers and OEM.
Nice meeting you Brandon, love the black trim on your bike and I'm looking forward to riding once I heal up!
You sure weren't kidding when you said we have similar plates!
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider screwed with this post 05-25-2013 at 01:18 PM Reason: photo and link added
Lost Rider is offline   Reply With Quote
Old 05-25-2013, 12:26 PM   #4847
RayMurdock
Oddometer: 19
Thumb
Thank you very much - nice bikes btw!
RayMurdock screwed with this post 05-25-2013 at 12:37 PM
RayMurdock is offline   Reply With Quote
Old 05-25-2013, 01:16 PM   #4848
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,249
Cool, glad you confirmed it since I hadn't actually touched that screw, I just thought it could help solve some folks stalling issue or was at least a good place to start without doing things that could have negative effects.
LostRider.com
Old 05-25-2013, 01:43 PM   #4849
kiwi5
Oddometer: 383
Turn the screw clockwise to increase idle? Or have I got that backwards?
kiwi5 is offline   Reply With Quote
Old 05-25-2013, 02:32 PM   #4850
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,249
Yeah, loosen nut then turn set screw clockwise, or tighten to increase idle. You'll probably need to hold the set screw with allen key while tightening the nut back up. At least that how I've done it on similar FI bikes and why I noticed this on the LRP back in January when you were having stalling issues.
It shouldn't take much turning to slightly increase the idle, maybe RayM can give more details about the LRP since I've only done it on other bikes.
LostRider.com
Old 05-25-2013, 03:50 PM   #4851
Boismj03
Boismj03's Avatar
Oddometer: 39
Ejk controller
I have a CRF 250 L EJK fuel controller. $175 shipped
I also have I a stock tail light assembly if any one is interested.
I've sold the bike.
That is not the way I would do it!
Boismj03 is offline   Reply With Quote
Old 05-25-2013, 06:07 PM   #4852
Vspec
Vspec's Avatar
Oddometer: 160
Emperor Racing skidplate install woes
Tonight will doing a dry run of installing my Acerbis MULTICONCEPT X-PRO Handguard Kit (I should have gotten white instead of black ), I also tried to install my Emperor Racing skidplate but ran into the following issue:
The rear mounting bracket needs to slide between the engine case and some frame gusset but it looks like the bracket (alu flat bar) is too thick and will need some serious convincing:
I will call them Monday but I was wondering is anyone here already installed one and if they rant into the same issue?
*Re-Edit*
Figured it out, the key is to insert it perpendicularly to the ground and then drop it back so it rests parallel to the ground.
Vspec screwed with this post 05-25-2013 at 06:54 PM
Vspec is offline   Reply With Quote
Old 05-25-2013, 09:50 PM   #4853
gnath9
gnath9's Avatar
Oddometer: 271
gnath9 is offline   Reply With Quote
Old 05-26-2013, 04:40 PM   #4854
kiwi5
Oddometer: 383
Laugh
HaHa! I had the same "challenge" fitting my emperor racing skid plate!! I finally installed the bar by inserting it from the top side. Good to know I am not alone in my mechanical issues !!!!
Old 05-26-2013, 05:31 PM   #4855
Vspec
Vspec's Avatar
Oddometer: 160
I face palmed myself once I figured it out, logical yet not obvious at all. I wished the instructions would tell you how to insert the bar. Otherwise I can tell it will take any abuse I give it.
Old 05-26-2013, 05:35 PM   #4856
Harcomo
Oddometer: 120
I don't recall having a problem when installing my Emperor plate and I'm usually not good at figuring out puzzles! All I know is it's an awesome skid plate....the quality is top notch!
Harcomo is offline   Reply With Quote
Old 05-26-2013, 11:11 PM   #4857
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,249
Wink LRP Roots.
LostRider.com
Old 05-27-2013, 07:22 AM   #4858
tilliejacques
tilliejacques's Avatar
Oddometer: 407
{video by Lost}
awesome video!
did you feel like the guy in the Bourne Legacy movie?? although I understand the 250L had a stunt double in that...
thanks for the effort it took to do the cool vid!
11 Husky TE250
08 Beta Rev3 125
tilliejacques is offline   Reply With Quote
Old 05-27-2013, 01:14 PM   #4859
RayMurdock
Oddometer: 19
Adjusted it yesterday - very easy. Should be done once warm, needed quite some rotations. Did few hours of testing: no stalling anymore
Old 05-27-2013, 04:27 PM   #4860
kiwi5
Oddometer: 383
Interesting that it needed multiple rotations- I will test it out on the CRF250L we have at work first. Then I will go back to mine and clip together the O2 sensor before starting to adjust it. Then I can test to see if I can feel the difference between O2 connected or disconnected. It certainly runs better disconnected now (as the team at EJK recommended).
Times are GMT -7.   It's 02:55 AM.
