Old 06-25-2013, 01:02 PM   #5071
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,019
Let us know what Just Tanks says.I just contacted a guy in Sandiego,CA who makes racks and he just finished a prototype for a CRF250L tail rack,hopefully side racks to come soon he says,I use soft bags so I just need the basics with whatever Im riding,flat and hot pipe standoff.
What would you do if you weren't afraid?
Bobcat Goldthwait is my mentor.
8lives is offline   Reply With Quote
Old 06-25-2013, 01:09 PM   #5072
SAPB
SAPB's Avatar
Oddometer: 1,594
From lurking on the KLX forum, nobody beats Just Tanks prices. Unfortunately, the CRF is not on their radar yet. Our bike is sold out fast all over, so maybe they will wake up, and start filling the aftermarket with more stuff for our bike.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is online now   Reply With Quote
Old 06-25-2013, 01:09 PM   #5073
Wargasm
Wargasm's Avatar
Oddometer: 195
OI! is That an oldskoolsuzuki.com sweatshirt you're wearing?
Originally Posted by Buckshot77 View Post
Wargasm is offline   Reply With Quote
Old 06-25-2013, 01:32 PM   #5074
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,239
FYI, JustgasTanks is a distributor more than a manufacturer, the most comprehensive and helpful place to get all things tanks for sure, maybe they can send out requests to more makers if they are seeing a lot of interest for the LRP, but contacting manufacturers direct should do more good to get us a proper ADV sized tank. Nice shop too, they helped me get some obscure tank parts in a pinch before the Baja 1000.
Until then, MSR Dromedary bags are my method of choice to carry extra fuel when needed.
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider is offline   Reply With Quote
Old 06-25-2013, 01:49 PM   #5075
SAPB
SAPB's Avatar
Oddometer: 1,594
Inquiry answer said, "Yes, this should be out in a month or so from IMS".
Old 06-25-2013, 02:23 PM   #5076
Ed@Ford
Oddometer: 1,646
Kolpin vs Rotopax trivia:
Both are very thick plastic because they seal tight (have no vapor vent), and when gas is hot and shaken around, the light ends in the gas vaporize and create pressure....as much as 10 or 20 psi.
The mounting systems are similar but not interchangeable. The kolpin is plastic, Rotopax is aluminum and is robust and $$$. The bolt of the kolpin is 6mm, the rotopax is 5/16". The racetrack shaped hole of the rotopax is bigger than kolpin. I called the rotopax folks and got this info. I like the tool/emergency "box" rotopax makes....the lady at rotopax said it would fit over the kolpin mount but it would be sloppy fit....no problem if horizontal, but not vertical. I asked about layering a 1.5g kolpin on top of their emergency pack with the kolpin mount....she said I'd have to create an extender for the hold down, and if it tightened down well, she expected no problem.....but combining them any other way could be trouble.
In my case I had a kolpin that I used on my 2006 Husky TE610 with no issues because it took 3 years for the aftermarket folks to make a big tank for it....and it ended up crappy. Those same folks are developing a CRF tank.....and after having the tank off my crf to do the valves, and seeing how tight everything is on that tank installation.....I will say no thanks to an aftermarket gas tank for it.
Ed@Ford is offline   Reply With Quote
Old 06-25-2013, 02:52 PM   #5077
SAPB
SAPB's Avatar
Oddometer: 1,594
Ed, thanks for the insight. I think it is Tony who is waiting for his pre-ordered tank, see what he posts. Filling up has not been a problem, just thinking about future longer rides.
Old 06-26-2013, 07:01 AM   #5078
Lapchik
Tinkeritis posterboy
Lapchik's Avatar
Oddometer: 350
Whatever 250 I end up with I will probably try the Kolpin fuel pack jr,it's not perfect but for the price you get 1.5 gallons when you need it and it looks like because it's flat you can pile touring junk on it,and set it aside when not using it.Anyone have any thoughts on this?Big tanks are nice but spendy.
I've never had any problems with my rotopax, they have about 20000 miles on them between the LRP and the Versys
http://www.youtube.com/watch?v=J6iXt...Ra3wXR&index=4
http://www.youtube.com/watch?v=ApoHC_FFD0A
Lapchik is offline   Reply With Quote
Old 06-26-2013, 07:23 AM   #5079
8lives
Dharma Bum
8lives's Avatar
Oddometer: 2,019
Thanks all for the good info on Kolpin and Rotopax,I had forgotten all about Rotopax,fuel is alway a issue for all of us,its not hard to wander around 100 miles and while there is gas along the way there are times when it's nice to go 200 miles or more and not think about it,my DR350 had a bigger tank good for 175 miles and it worked well,but as stated before I don't need the range all the time so an extra 1.5 gals for less than 100$ is just right.For now I'm the Tanker on the trail with the KLR.
Old 06-26-2013, 08:08 AM   #5080
G19Tony
G19Tony's Avatar
Oddometer: 416
Another 3-4 weeks is the last I heard. I'm not in a hurry, I want it to be right the first time. I had good luck with the IMS tank on my KLR250. I'm setting the bike up for touring. I have the Wolfman side racks with Rotopax adapters. I recently received the 2 gal fuel and water containers. With the new tank, I'll have 5 gallons aboard. I don't want to have to sweat fuel. I have that Rotopax storage container too. It will fit on the Manracks perfectly, and I can stack stuff on it. I'm getting ready for a ride with my brother next month I'll get pictures of the setup on here soon.
BMW F800GT, Hodaka Dirt Squirt, Honda CT70, Honda Grom, Zongshen RX3
G19Tony screwed with this post 06-26-2013 at 08:13 AM
G19Tony is offline   Reply With Quote
Old 06-26-2013, 09:41 AM   #5081
SAPB
SAPB's Avatar
Oddometer: 1,594
Gas at about 6.2 lbs per gallon, plus the weight of the Rotopax. I know on the rear rack it sticks out further, and the side racks are probably just slightly back from were a passenger's weight would be. I've not ridden two up on the CRF, but on any bike, it's going to make the front feel light. Still better than running out in the boonies. Not sure what the minimum capacity is recommended for something like the TAT. I've figured I'm good for maybe 35 miles after the fuel thing starts blinking. That's conservative for around town riding. I reset the trip A to zero when the blinking starts. Of course, your not going to get very good mileage in 2nd gear.
Old 06-26-2013, 08:32 PM   #5082
Buckshot77
Buckshot77's Avatar
Oddometer: 42
Your not helping my decision to go buy a new bike,you may hear from my wife when she finds out you can jump these things,she was never happy with my Evil Kenevil antics on my YZ250 cause I wipe out.
Lol,they can handle it.
Listen to that smack.
http://youtu.be/5VkyTOmYP8w
Buckshot77 is offline   Reply With Quote
Old 06-26-2013, 08:35 PM   #5083
Buckshot77
Buckshot77's Avatar
Oddometer: 42
8 Lives & Buckshot:
jumping that poor crf onto gravel with no elbow or knee protection? No wonder your wife is on your ass!
Lol, my wife???. That's the klr owners wife naggin
Gravels the soft stuff
A wipe out in the gravel hurts lots less than a wipeout on pavement,and I don't wear full mx gear there either.
I'd look fn hilarious flyin down the highway wearin full mx gear on my softail.
If I don't dress like I'm at the starting gate of an mx race on one of my hd's why would I to ride the L
Do you wear your neck brace on the highway?
Buckshot77 screwed with this post 06-26-2013 at 08:47 PM
Old 06-27-2013, 01:37 AM   #5084
Sharkfan22
Oddometer: 24
Anybody else fitted the Yoshi RS-4 slip on and had troubles with it scrubbing on the back tyre?
I have the pirelli MT21 in standard width and it seems to scrub on the exhaust.
Sharkfan22 is offline   Reply With Quote
Old 06-27-2013, 02:23 AM   #5085
Turk
'Bab Man
Turk's Avatar
Oddometer: 114
Whats the deal with the rear shock from Thailand? Anybody else tried one yet?
Here's another snap of my LRP...
Turk is offline   Reply With Quote
Times are GMT -7.   It's 03:46 AM.
