10-26-2012, 03:59 PM
#661 |
Oddometer: 194
im not expecting 600 cc's wrth of power, i had a 1984 honda xl 125 S before, it was a great little bike. as long as it has 250 cc's worth of power i will be happy. i just really want somethen new, with the electric start, and fuel injection and cheap. and this seems to be the best bet, and i wont buy anything buy honda :)
1994 XR600R dual sport |
10-26-2012, 04:07 PM
#662 |
Lawn Nazi
Oddometer: 1,109
Can't say that I have heard any "piston slap" sound on mine. My mpg on first tank was 66.6 but am unsure dealer had it full to the neck or not.
10-26-2012, 04:55 PM
#663 | |
Oddometer: 35
10-26-2012, 05:01 PM
#664 |
Oddometer: 35
10-26-2012, 05:17 PM
#665 |
Oddometer: 242
Not dumb, sent PM
________ Semper Fi |
10-26-2012, 06:12 PM
#666 |
..this space for rent..
Oddometer: 2,196
Question for the collective: How does one remove the spring from the shock assembly on these bikes? The locking collars cannot be backed entirely off the shock as they can on the CRF230F. Looks like you'd have to unscrew the clevis. But how does one do that? Or am I missing something obvious?
Note: Interesting feature on these shocks ... the locking collar threads are not machined into the shock body itself. They are machined into a collar kept from rotating on the shock body with dogteeth. Almost as though the shock can be used for multiple models by just using a different collar. See the pictures below .... ![]() ![]()
- B Proud to be an inmate of AdvRider. |
10-26-2012, 07:07 PM
#667 |
Secondcreekrider
Oddometer: 8
I have noticed a bit of engine "knock" at certain RPMs. I don't know for certain what the sound is but assume nothing out of the ordinary. Just such a quiet bike so more engine noise less muffler is heard at certain speeds. No issues with MPGs.
10-27-2012, 02:11 AM
#668 |
Oddometer: 35
More cost cutting i see, least it'd be an easy fix if it stuffs up! and replacing/renewing the shock would be easy as too.
2004 XR250R- The Toy 2013 CRF250L- The Daily ![]() 1989 Cruiser- The Rig 1993 Barina- Sigh... |
10-27-2012, 06:36 AM
#669 |
Frostback
Oddometer: 280
Seat Concepts seat
Got my new Seat Concepts seat kit in this past week but haven't had time to install it yet, mostly because I think I might need a replacement cover.
If anybody else could set my mind at ease.. It seems that the rear portion of my cover doesn't have a 'tack strip' to staple through to the seat pan. Their doesn't appear to be much to staple through at all. See pics. Shows no 'tack strip' on rear portion, only on front half of seat: ![]() Same idea: ![]() From the top: ![]() Was your seat cover like this? Does it stretch that much to let you staple through it or is my cover a manufacturer error? Thanks in advance!
-Steve 04 FJR1300, 2013 CRF250L I have a job, I explore, I follow every little whiff. On/Offroad help when you need it - http://www.assistancelist.com |
10-27-2012, 07:16 AM
#670 | |
Crazy Diamond
Oddometer: 726
I'm sure some old XR shocks would fit and be a huge improvement. Having adjustable rebound and compression is always nice... It might even add some extra travel too.
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
10-27-2012, 07:32 AM
#671 |
Oddometer: 2,196
About 395 mm. Wanted to measure the compressed length but need to get the spring off.
10-27-2012, 07:49 AM
#672 |
Crazy Diamond
Oddometer: 726
Is that length from the center of each mounting bolts?
10-27-2012, 08:04 AM
#673 |
Oddometer: 2,196
Yep. Eye-to-eye.
10-27-2012, 11:11 AM
#674 | |
Oddometer: 725
Steve, The cover should fit fine. There is not supposed to be and extra flap sewn on the back. This is the first batch from the vendor and we will tweak the pattern for the next order. When you install this, first get the cover warm in the sun, or throw it in the dryer for a couple of minutes. Slip the nose over and pull it down into place, then tack it with a couple of staples. Now do the rear, make sure the cover is centered and pull it taught enough to get an overlap to staple into pan. Now you only need about 3/8 of an inch overlap, thats it. This will put the proper amount of tension on the cover. Now staple the 2 sides at the bend in the pan, where it meets the tank. From this point you can start stapling the rest of the seat. bundy
The 80`s..........ah yes...back in the days when men looked like women, women dressed like whores and the music F@#KING ROCKED! ![]() Check out http://seatconcepts.com/ , your ass will appreciate it! http://advrider.com/forums/showthread.php?t=621311 |
10-27-2012, 01:09 PM
#675 | |
Frostback
Oddometer: 280
