Old 03-30-2014, 05:48 AM   #7936
vfrpaul98
Oddometer: 8
Crf gearing calculator
http://crfsonly.com/howto/gearing/mo...calculator.php
stock 14t counter/40t rear final ratio 2.857 60mph=6096 rpm
13t counter/40t rear final ratio 3.077 60mph=6564 rpm
14t counter/43t rear final ratio 3.071 60mph=6553 rpm
these specs all run the stock rear tire size of 120/80-18 and use the stock drive chain lenghth.
14t/43t works well for this 200 lb rider 50% on/off road.
Paul.
vfrpaul98 is offline   Reply With Quote
Old 03-30-2014, 05:53 AM   #7937
Ed@Ford
Oddometer: 1,600
Originally Posted by gnath9 View Post
R6realtor lives in Florida ... and has more Mods than most folks ....
DUH....yup...traveler6......
Ed@Ford is offline   Reply With Quote
Old 03-30-2014, 09:05 AM   #7938
SAPB
SAPB's Avatar
Oddometer: 1,556
Subframe failure detector
I guess if any of us have the right turn indicator melting, it's time to get to a welder.
http://www.advrider.com/forums/showp...postcount=6129
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 03-30-2014, 09:38 AM   #7939
travelR6
Oddometer: 157
Originally Posted by Ed@Ford View Post
R6 realtor:
Get a rack, tail trunk if you choose, Givi is a good brand but $$, tank bag, 13T countershaft sprocket, but understand speedo and odo will be wrong, maybe revise handlebars (I found them too low and too wide), I like heated grips, make sure you have appropriate tools to fix a flat tire. I've ridden bigger bikes in Austria, Bavaria, and Northern Italy....the CRF will be wonderful there!!
as i have to order most of the aftermarket parts from the US (in europa you can't even buy a service manual ), i try to keep the orders as minimal as possible because shipping costs to austria are quiet expensive :). already ordered skip plate, 13t sprocket, speedo healer, service manual, radiator guard and folding shift lever.
what do you guys think about clutch and enginecover protection from r&g? i figured it might be worth a look as those covers are quiet expensive to replace.
http://www.eiweiss-raceparts.de/raci...KEC0060BK.html
travelR6 screwed with this post 03-30-2014 at 09:47 AM
travelR6 is offline   Reply With Quote
Old 03-30-2014, 09:43 AM   #7940
Ed@Ford
Oddometer: 1,600
in #6246 on page 417 of aroud the world in 800 days is his fix....but he's got too much weight, too far back, all concentrated in the 4 vertical bolts of the subframe....the weight has lots of leverage to break the subframe in the picture
Old 03-30-2014, 09:48 AM   #7941
Ed@Ford
Oddometer: 1,600
Start with their bash plates first...the covers you point out are 4mm plastic....might not be robust enough
Old 03-30-2014, 10:39 AM   #7942
SAPB
SAPB's Avatar
Oddometer: 1,556
I know everybody likes pictures, and I don't post those. But if you were paying better attention, you would realize that that the service manual is available here free of charge.
Old 03-30-2014, 10:48 AM   #7943
battlecattle
Oddometer: 271
I was sooooo happy when that was posted. Mostly because I am a cheap bastard.
http://www.batlecatle.com/
2014 KTM 690 Enduro
2014 CRF250L - Totaled
battlecattle is offline   Reply With Quote
Old 03-30-2014, 11:05 AM   #7944
travelR6
Oddometer: 157
damnit, searched the whole day and could only find the user manual. but shouldn't be a problem to sell the book for a profit in europa, as there are no active sellers or crfsonly is so nice to cancle the order of the book before the ship the rest.
but thanks for the link, i really appreciate the pdf version
and yeah, i am a cheap bastard too
Old 03-30-2014, 11:41 AM   #7945
AriWiedaetschi
AriWiedaetschi's Avatar
Oddometer: 93
A very early start to the season 2014
22 degrees in March are really great
I want to die asleep like my grandfather...
....not screaming like his passenger
http://feldweg-streuner.blogspot.de
AriWiedaetschi is offline   Reply With Quote
Old 03-30-2014, 01:04 PM   #7946
isalas16
isalas16's Avatar
Oddometer: 38
Couple of mods installed
1.5" riser, pro taper handler bar, and denali aux LED lights incredibly bright at night
isalas16 is offline   Reply With Quote
Old 03-30-2014, 01:11 PM   #7947
Epy
Hen-teaser
Epy's Avatar
Oddometer: 275
Wet clutch, the plates get stuck together from non-use. Before you start the bike, put in 1st, pull the clutch, and rock it front/back, and you'll feel it break the plates loose. This same thing happens when it's running, and you shift from neutral to 1st, there's a little clunk. I think it's normal for it to be making a different noise in gear with the clutch pulled than in neutral.
Thanks, that seemed to help somewhat. The noise is more constant but quieter, and goes away quicker.
Epy is offline   Reply With Quote
Old 03-30-2014, 08:14 PM   #7948
Fishyhead
Eremikophobic
Fishyhead's Avatar
Oddometer: 3,142
Anyone break a Moose skid plate? I did after one ride...
Duy. You know, like the decimal system.
Spot shared page: http://share.findmespot.com/shared/f...FogjjtYMdOqF2n
Fishyhead is offline   Reply With Quote
Old 03-30-2014, 08:38 PM   #7949
Irish769
Wanna-be
Irish769's Avatar
Oddometer: 55
I have a friend in England that scored me a set of the R&G side covers for a lot cheaper than I could. It would have cost over $200 to order for shipment to The States. They fit perfectly and appear as if they would help considerably in a crash. There is a downside however: It requires removal of the right side cover for an oil change. If you have an aftermarket skid plate (e.g. - Flatland) it requires the skid plate removal to remove the right side cover. Not a deal killer but certainly adds time and effort to change the oil.
2008 Concours 14 (Traded)
2004 Yamaha Roadstar
1975 KZ 400
2013 CRF 250L
2014 BMW GSW
Irish769 is offline   Reply With Quote
Old 03-30-2014, 08:58 PM   #7950
Epy
Hen-teaser
Epy's Avatar
Oddometer: 275
Mine is still intact. Out of curiosity, did it break on those crappy looking plastic welds?
Times are GMT -7.   It's 03:26 AM.
