Old 11-21-2012, 06:18 AM   #1021
Ed@Ford
Oddometer: 1,662
Originally Posted by SAPB View Post
Guerilla, an impact driver will get those screws out, it converts the downward hammer tap into turning motion while at the same time insuring that the bit stays in the screw. This one is "brand C": http://www.sears.com/shc/s/p_10153_1...32-196072104-2
I bought a similar but more compact impact that uses normal 1/4" hex bits from Harbor Freight.very inexpensive...plenty stout to do what you need....however the sears one is robust enough for bigger jobs....BUT if you haven't buggered the screw head, take your phillips, put it in the "+", and smack it a couple times with a hammer....50% of the time that will shock the threads enough come unstuck.....replace them with socket head screws
Ed@Ford is offline   Reply With Quote
Old 11-21-2012, 06:31 AM   #1022
Guerillah
Guerillah's Avatar
Oddometer: 103
Originally Posted by goondock View Post
Hey Guerilla, I second this post above, that is the exact tool I used to get mine off. i was shocked as to how tight those suckers were in there.
Originally Posted by Balkan Boy View Post
Don't push it with a Philips screwdriver.
They are JIS screws. I also couldn't undo them with a Philips but they came right out with a fifth bit (left to right) in this picture.
Same on the Kawasaki.
Thanks guys! I will give it a try today with an impact and the correct bit, luckily I didn't damage the heads.
Guerillah is offline   Reply With Quote
Old 11-21-2012, 06:38 AM   #1023
Ed@Ford
Oddometer: 1,662
Yup...Balkan Boy is correct...they are not EXACTLY phillips...and the "+" is more shallow....for quick and dirty, you can grind (file) off the tip of the phillips to make sure you have a good bite in the +.....but trying a couple of smacks won't hurt...because if the bond is broken, it'll be loose enough that you don't bugger the +
Old 11-21-2012, 09:01 AM   #1024
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,962
I see a group buy on that kit in the near future.
If it don't have tits, spark plugs or gun powder, it don't interest me. ---Moose Dog
If you don't organize your tools, you're a terrible person.---Aghartha
You twatwaffles who enjoy fucking duffelbags full of deer antlers, simply stay out of the thread. ---Hardware02
I'm ignorant, but happy---steyr_scout308
STANIMAL is offline   Reply With Quote
Old 11-21-2012, 09:17 AM   #1025
strongbad
Oddometer: 486
Thanks for the link to the JIS article.
strongbad is offline   Reply With Quote
Old 11-21-2012, 09:46 AM   #1026
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 341
Jealous of the wera tools
EEKAMOUSE is offline   Reply With Quote
Old 11-21-2012, 10:26 AM   #1027
ramz
Professional Trail Rider
Oddometer: 2,019
You won't believe how expensive Wera tools are:
Sears
http://www.sears.com/shc/s/v_10153_1...2-00000cc221e4
Chads Tool box
http://chadstoolbox.com/05347180001-...-imperial.aspx
ramz is offline   Reply With Quote
Old 11-21-2012, 10:38 AM   #1028
ramz
Oddometer: 2,019
Central Hobbies sells a nice set of 4 JIS screwdrivers for $17.99. I've had my set for 18 months and use it on all the screws that have a JIS dot on the head - they work great.
Japanese Industrial Standard Screwdriver Set (4), Item #:CHMJSDS
Unit price:$17.99 USD (Plus $8 shipping).
http://centralhobbies.com/Tools/jis.html
Old 11-21-2012, 11:15 AM   #1029
STANIMAL
SUPPORT THE SECOND
STANIMAL's Avatar
Oddometer: 2,962
Sears
Chads Tool box
Makes Snap On seem inexpensive.
Old 11-21-2012, 12:46 PM   #1030
Guerillah
Guerillah's Avatar
Oddometer: 103
Got it off guys, thanks for the advice. I couldnt find JIS bits locally so I tried my luck with a regular phillips head and an impact gun, worked like a charm.
Old 11-21-2012, 01:49 PM   #1031
Harcomo
Oddometer: 120
I like them, definitely free'd up some weight, difference isn't hugely noticeable but can surely be felt (as far as power). It was popping a bit after install of just the exhaust components. Once I added the fuel controller is when it opened up. I also did the airbox mods and filter mod that can be seen on bestdualsports.com . The 13 tooth front socket was also a big boost to the gearing, tons of fun in the dirt at this point. I need some better tires than stock though as they kind of suck in the sand.
How would you compare the FMF pipe's sound compared to the stock system? I've just heard a clip or two on the internet and it's hard to tell how loud it really is. I would like a new exhaust on mine but I don't want something that is obnoxiously loud to others.
Harcomo is offline   Reply With Quote
Old 11-21-2012, 03:43 PM   #1032
Guerillah
Guerillah's Avatar
Oddometer: 103
I would say this video is accurate of the sound, I did the muffler and header at the same time so i can't tell you how it would sound with the muffler alone.
http://www.youtube.com/watch?feature...v=WveN79a7Z2g#!
At cruising speeds, it isn't loud (actually quite nice) but definitely gets loud as you crank the throttle. I should have used my dB meter to take measurements... sorry!
I'll try taking a video on Friday with audio gain control turned off (so that it doesnt try to amplify the sound).
Guerillah screwed with this post 11-21-2012 at 03:57 PM Reason: Added more info
Old 11-21-2012, 04:32 PM   #1033
Little General
Oddometer: 28
Hey guys, I haven't logged on here in years since I sold my KLR 650. I've been looking at dual sport bikes for a couple months. I thought I wanted a Kawasaki KLX 250 with the 17" wheels with the on-off road tires on it. Saw one on ebay and it looked cool. Then I ran across the Honda . I've had a few different bikes in the last 10 years, always seem to buy what my friends were riding. Older guys, cruisers, younger guys, rockets, but all my early years ( 6-18 yrs) I rode a SL-175 then a MR 250 Honda. Went with my dad when I turned 16 to buy a 1980 Honda XL250, but he would not let me buy it. Now I'm 48 and I can buy it if I want. So, I went to my local Honda dealer and the owner used to work for me when he was a kid. Anyway, he had 1 left out of 4 he ordered. i asked why he orderd so few and he said the dealers were afraid the bikes would be a flop, boy was he wrong. He said dealers are calling from all over the east coast offering him $500 over his cost to let them have it. I didn't ask how long it takes to get more or if he had more on the way. I really just stopped to look at one in person and as it turned out, the owner wants some work done at his house and early next year we are going to trade a bike for particle payment against my labor.He says Honda offers him an end of year deal where he gets credit against Hondas like a bonus. He said he will get me a bike as part of his bonus, maybe even a white one. But I like the red a lot. I hope you guys keep working on your bikes making them better so when I get mine all the bugs will be worked out.
Little General is offline   Reply With Quote
Old 11-21-2012, 04:35 PM   #1034
Harcomo
Oddometer: 120
OK, thanks! A video would be great if you can make one. I'm sure other's would appreciate it also.
Old 11-22-2012, 05:08 AM   #1035
Ed@Ford
Oddometer: 1,662
http://japan.webike.net/HONDA/CRF250...model&p.m=6335
$$$$$ Farkles for CRF from Japan. Especially interesting are the different styles of racks and attachment methods.
Times are GMT -7.   It's 05:53 AM.
