Old 09-06-2012, 01:34 AM   #1
stege OP
Wonderer
stege's Avatar
Oddometer: 288
Coolant temperature gauge question
Was wondering how many bars do you people get. I'm always getting 4 bars, no less no more. The reason I'm asking is because I think my bike is running a bit hot and because I've never seen more than 4 bars not even when my radiator fan starts. Heard this might be a coolant bleeding procedure issue. Thoughts?
the older I get the faster I was
stege screwed with this post 09-06-2012 at 02:53 AM
stege is offline   Reply With Quote
Old 09-06-2012, 02:38 AM   #2
fiwi
Oddometer: 145
Why do you think it is running hot?.
My bike is always on 4 bars, hot weather, cold weather, fan on or off. I changed the coolant a couple of weeks ago. Thought I did everything correct. Started bike up to let idle for a while and it went up to 5,6,7 bars, then warning lights came on. Opened bleeder screw, released more air, topped up. It has now settled back to 4 bars .
fiwi is offline   Reply With Quote
Old 09-06-2012, 04:59 AM   #3
lakota
Geeser
lakota's Avatar
Oddometer: 3,097
Four bars was normal for mine. Had it go higher but only in stop and go traffic with the temperature hovering around 100F.
IBA #42016
my ride reports
follow my ride
lakota is offline   Reply With Quote
Old 09-06-2012, 07:32 AM   #4
Ride-a-lot
Oddometer: 165
I have 41K miles on my GS and have never seen the fifth bar. I thought for sure when I was stuck in crawling traffic and 100* that I would see it but never did. It"s fine with me if I never see the elusive rare fifth bar.
Tom M.
Salem Or.
'93 K1100LT '09 F650GS '08 TE-610
Ride-a-lot is offline   Reply With Quote
Old 09-06-2012, 09:48 AM   #5
grndzr0
its Ground Zero
grndzr0's Avatar
Oddometer: 598
I have 20k mi on mine. I have 100+F crawling up rocky nasty washed out roads slipping clutch and all, never seen the 5th bar.
Cooling system seems pretty rock solid on these guys.
Ryan
2010 F800gs (Mine) 2011 F650gs (Wifes)
grndzr0 is offline   Reply With Quote
Old 09-06-2012, 11:59 AM   #6
L.B.S.
Oddometer: 1,370
F800ST here (2009 model) 20K and have never seen more than 4 bars, stuck in traffic, hot summer day, fan on continuously.
The only thing it has always done from day one though, is piss coolant all over the lower fairing/frame/my boot, from the reservoir's lid if the fluid level is anywhere above the "low" mark on the container.
L.B.S. is offline   Reply With Quote
Old 09-06-2012, 03:37 PM   #7
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,345
I have. I was going up Pikes Peak, behind a looky-loo. The fan had some grit as we had just come off the CDR and was apparently stuck.
Anyhow, it went to 5 bars and the "oil" light icon flashes in yellow. When the next bar is up, the oil icon flashes red...this is also the time the overflow container pees all over.
Get off spin the fan by hand..refill the overflow container and away you go!
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 09-07-2012, 05:35 AM   #8
JRWooden
Oddometer: 4,256
It appears unanimous ... anything over 4 bars is trouble somewhere (fan / air in the system / ....)
One quick check for air trapped in the system that worked for me was (with the bike warmed up) to carefully "feel" your way across the radiator core - it should be uniform in temperature everywhere on the core - cold spots likely mean air in the system.
Here's the procedure I used to get the air out of my system:
http://www.advrider.com/forums/showpost.php?p=13698738&postcount=11
Damn I miss Joel ....
JRWooden screwed with this post 09-07-2012 at 05:54 AM
Old 09-07-2012, 12:07 PM   #9
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,712
+1 on that.
I passed my driving licence on a F650GS TWIN and it never made over 4 bars (and I think driving lessons are the worst thing that could happend to a bike)
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Old 09-07-2012, 01:50 PM   #10
stege OP
Wonderer
stege's Avatar
Oddometer: 288
Thanks guys!
Old 09-07-2012, 03:45 PM   #11
Mr B
Mr B's Avatar
Oddometer: 493
Got to add something here.
I punched a hole in my radiator a few years back, long story, did not see the tree and got speared!!!
Anyway I did not know I had a leak until maybe four or five miles later, when I got the warning and looked and saw the coolant temp with all kinds of bars.
I was able to put the stick back in the radiator, add a bottle of water and make the 36 miles home with only a few bars showing, engine ran cool even through the coolant level was minimal at best...Not sure how they designed this system but I think there is some sort of bypass as my engine never exhibited any of the "HOT" engine characteristics.
I guess what I am getting at is this cooling system seems to be spot on and somewhat rugged.....
bp
"For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return."
Leonardo da Vinci[/FONT]
Mr B is offline   Reply With Quote
Old 09-07-2012, 04:02 PM   #12
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,712
bp
Times are GMT -7.   It's 05:05 PM.
