Old 09-06-2012, 03:56 PM   #1
hardwaregrrl OP
ignore list
hardwaregrrl's Avatar
Oddometer: 7,576
Mikuni on an R80 help
Hey all. Wondering if any one has base line jet settings for a 32 TM mikuni on an R80 St. Also if you have cable info that would be great too!! Tia
hardwaregrrl screwed with this post 09-06-2012 at 06:07 PM
hardwaregrrl is online now   Reply With Quote
Old 09-06-2012, 04:41 PM   #2
hardwaregrrl OP
ignore list
Oddometer: 7,576
They are flat sides. Not going above 6,000 ft
Old 09-06-2012, 07:23 PM   #3
hardwaregrrl OP
ignore list
Oddometer: 7,576
Anybody?
Old 09-06-2012, 07:37 PM   #4
ontic
Oddometer: 1,070
Sorry mate,
If it was a VM34, I would have sent you a PM.
What's the story? Do you have these carbs already?
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 09-06-2012, 09:14 PM   #5
Kai Ju
Kai Ju's Avatar
Oddometer: 1,891
+ on VM's
If they were VM's we could get you in the ballpark. No idea on the TM's
What did they come off of ?
Were they meant for an airhead ?
What jetting do they have right now ?
Come to think of it, I had a TM 38 on my Rotax powered Ninja 250 and it uses essentially the same brass that the VM series does.
So here goes:
These are the specs for VM38s on a '77 R100/7
Description Spec
Main Jet 210
Pilot Jet 25
Needle Jet 166 P-8
Jet Needle 6DH3
Slide Cut Away 2 This will likely be different since the TM is a flatslide
Main Air Jet 0.5
Needle Valve Ass'y 3.3
The other option is to call SUDCO and see if they have specs for what you got.
I made my own cables from the stock cables, take your time, measure three times before you cut anything.
Kai Ju is offline   Reply With Quote
Old 09-07-2012, 04:54 AM   #6
hardwaregrrl OP
ignore list
Oddometer: 7,576
Thanks! This at least gets me started.....the carbs are brand new. I'm sanding a floor for Nathan Mende of Boxerworks-service and he ordered these for me from parts unlimited in a bit of trade. I was assuming I'd have to make my own cables by grinding the barrel down on the existing cable. I know they're jetted very rich. out of the box..250 main 45 pilot. Needle jet 389 Q-2 jet needle 5FP17. Thanks for the help, I'm racing it again next weekend and am dumb enough to want these carbs on the bike for the rally.
So here goes:
Description Spec
Main Jet 210
Pilot Jet 25
Needle Jet 166 P-8
Jet Needle 6DH3
Main Air Jet 0.5
Old 09-07-2012, 05:13 AM   #7
ontic
Oddometer: 1,070
Next weekend! Sounds like you've got a busy week
I got a couple of these cable kits from Venhill, one for my throttle and one for my choke (because I have changed both the throttle and the choke and about to do the carbs)
http://www.venhill.co.uk/Cables_-_Co...SPILITTER.html
I don't have my mikunis yet, but these kits look like they'll do the job very well. 48mm stroke in the splitter- a bit light and plasticy compared to the bmw splitters, but I suppose it will work just fine.
Aside from all your jetting stuff, you may need to look into the stroke needs of your carbs and what your bmw splitter and throttle can actually provide. Airhead Wrangler helped me out pointing this out with a post of his somewhere a while back.
No point upgrading to mikunis if you can't open right em up
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic screwed with this post 09-07-2012 at 07:18 AM
Old 09-07-2012, 07:15 AM   #8
Kai Ju
Kai Ju's Avatar
Oddometer: 1,891
Stick with what you got.......
..........for right now at least.
A week is not a lot of time to make cables and get carbs dialed in.
Also, depending on what throttle you are planning on using, you may have to modify the gear mechanism to get it to open the slide carbs all the way. The stock setup on mine only gave me about 3/4 throttle. If need be I'll take a pic or two on how I modified mine to give you some idea.
Also, the exposed wire length will be too short to fit the slide so grinding the barrel won't be enough, you'll have to shorten the outer cable to effectively lengthen the inner cable.
Sorry, got to leave for work but pm me if you got questions about cables and such.
Old 09-07-2012, 11:28 AM   #9
supershaft
because I can
Oddometer: 9,116
They are brand new? Send then back and get bigger ones!
Old 09-07-2012, 11:51 AM   #10
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,522
On an R80? The little research I've done here seem to me that the 32 or 34 were the sweet spot for an R80 ... and the 32 provided more low end grunt ... which is what she is going for ...
Am I wrong?
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 09-07-2012, 12:04 PM   #11
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
Am I wrong?
Definitely if she won't be venturing above 6000ft and needs more air. I had 40s on my R100RS and up here at 7500ft that was great but I would have done 38s if I had still lived in Monterey at sea level for sure.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 09-07-2012, 12:04 PM   #12
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
BTW I want a set for my R80RT so when you do get a good idea of a baseline, let me know and I can calculate with i need to do up here at my altitude.
Old 09-07-2012, 04:34 PM   #13
hardwaregrrl OP
ignore list
Oddometer: 7,576
So I know it's a bad idea to be slapping these things on and racing a rally.....but I want to play with my new toy!! Hardest part was figuring out the cables. No one has cables for the R80 2-1.....weird. Anyway, I wandered into the back of Cycle Word in Athens GA and found some 4 wheeler cables that are going to work. Had to put a barrel on the end of the carb to get the appropriate free play, but the slides open all the way!! Yippie!!! Going to buy a bunch of jets tomorrow and try to get it dialed in....I know it's a fucking stupid idea.....but if I get it running right and it pulls, by golly whats the problem with racing it !? I'll post up some pics of the install and let you know where I land with jetting... I went with 32s because I don't want bigger I want a bit quicker acceleration, that's it.
@ontic: nice kit, Hans! I just got lucky.....hoping to post up what they are off of so anyone else doing this doesnt have to dig.
@Kai Ju: I just can't stand having a new set of mikunis sitting there.....call me crazy.
And Dean and Nathan did all the brainiac work.
hardwaregrrl screwed with this post 09-07-2012 at 08:41 PM
Old 09-07-2012, 06:11 PM   #14
supershaft
because I can
Oddometer: 9,116
Am I wrong?
More low end grunt than 32mm Bings? That could be done with 38mm Mikuni's. I would run 36's for a lot more low end and a lot more high end at the same time but that's just me. Stepping away from Bings you can have it all at once. It's easy to do when you start from such a low performer.
Old 09-07-2012, 08:48 PM   #15
hardwaregrrl OP
ignore list
Oddometer: 7,576
Welp.....the bike runs very nicely. I just got them on, hooked up and cables loosely adjusted. Didn't feel like taking a ride in the dark with these new guys. Here's a few pics of the cable mod.....had to turn the carbs in a bit more as the cable top was interfering with the HPN tank.
Here's the original cable assembly I stole the cables from.
And the other end.
And a quick video....please turn you volume down as I don't want you to get pissed at me for being loud.
Uploaded from the Photobucket iPhone App
Times are GMT -7.   It's 05:47 AM.
