10-17-2012, 05:59 AM
#61 |
OH.THAT'S GONNA HURT
Oddometer: 3,814
Not sure if a color tune will fit in plugs, but using one of those will let you see the spark and then you can tune by color of the spark, a bunsen blue is just about right, orange is to rich.
2004 BMW R1150RS 1984 BMW R80G/S (wrenching index) 2003 Suzuki DRZ 400S (TAT Prep) One More DRZ does the TAT (Ride Report) |
10-17-2012, 07:42 AM
#62 | |
Oddometer: 683
10-17-2012, 07:44 AM
#63 | |
Oddometer: 683
I was wondering about this as well last night. I have HS40's on mine, as well as some RS40's. The difference is the addition of an R, for instance: So an HS with rollers is an HSR A TM with Rollers is a TMR You would most likely be interested in TMR's. The HSR's start at 42mm, they're Hawg Carburettors |
10-17-2012, 07:47 AM
#64 |
+/- V TDSPP
Oddometer: 19,910
TMR.. Arr arrr good to know, thank you. I heard hearsay they were easily twice as expensive (like 800USD/pair) but didnt rub themselves raw, and wear out the body.
What to do... What to do... |
10-17-2012, 07:50 AM
#65 | |
Oddometer: 683
Not to mention, at least for the HS's, that the freakin throttle springs are monsters to hold. |
10-17-2012, 08:04 AM
#66 |
More tacos than you
Oddometer: 5,114
Same for the VMs I'm using. I only managed to hook up one of them so far and it's already equal to the pull effort of both bings. The addition of the second carb could prove too much. It could also have to do with the Venhill throttle grip I'm using though.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
10-17-2012, 08:10 AM
#67 | |
Oddometer: 683
10-17-2012, 08:14 AM
#68 |
More tacos than you
Oddometer: 5,114
VMs don't have that option. Only one place for the spring to go: inside.
10-17-2012, 08:17 AM
#69 |
Oddometer: 683
10-17-2012, 08:33 AM
#70 | |
Oddometer: 327
If you give me the dimensions of your springs I could check with the Dello springs. |
10-17-2012, 08:34 AM
#71 | |
Oddometer: 1,025
Throttle pull
My VM 38s are a lot easier to pull than the Bings. Mind you, I did make my own throttle cam, or I should say that I modified the stock /7 cam to allow the throttle to fully open. What kind of throttle are you using ? |
10-17-2012, 08:35 AM
#72 |
More tacos than you
Oddometer: 5,114
That's entirely possible. I haven't checked yet. I appreciate the offer, but I can't measure them at the moment because they're with my bike up in Seattle. I'm down in Mexico. Sorry.
10-17-2012, 09:00 AM
#73 |
Oddometer: 683
Sorry to participate in derailing the thread. Just one more throttle spring post.
I went to these guys a few minutes ago and they'll make me some custom springs for my Mikunis. http://www.springsfast.com/custom.php p.s. I will put some input into the OP though. Not sure why you are so resistant to the AFR gauge. I had a colortune at some point and found it pretty useless for tuning, other than maybe idle mix. You could find one(Innovate AFR) for a good price used on Fleaby. Use it to "PERFECTLY" tune your bike and sell for probably what you have in it and use it for practically free. Innovate is the one you want. They have a tail pipe sniffer, which may work on your bike. I would weld a SS bung in my headers, but the sniffer may work for you depending on the exhaust you have. Then you would have the Best HP and the Best Gas mileage. You wouldn't leave anything on the table. I would think with those 32's, you would have killer stump pulling torque and awesome mpg if done right. |
10-17-2012, 09:01 AM
#74 |
Von Hochstaden's son
Oddometer: 44,978
mikuni vm32-33 both sides :\ 5000 feet altitude/ 140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide 35 mpg around town riding like a asno |
10-17-2012, 09:18 AM
#75 |
More tacos than you
Oddometer: 5,114
Hmm. Maybe I hooked up the throttle using the 'fast action' side of the cam rather than the normal side. I'll have to check it again.
EDIT: I checked the specs and the thottle takes up 36mm of cable in either 68 or 80 degrees of rotation depending on which setting you use. I'm not sure how that compares to the stock BMW throttle though.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. Airhead Wrangler screwed with this post 10-17-2012 at 09:40 AM |
