Old 10-18-2012, 06:26 AM   #91
hardwaregrrl OP
ignore list
hardwaregrrl's Avatar
Oddometer: 7,288
I'm lucky......the guy that is the new service manager went on a back road ride with his mom and sister back in '09. From Alabama to keystone CO for the womens motorcycling festival. I met them with my buddy at a hotel 5 hours from the festival...then 2 years later I meet him at the HD dealership. He's very patient and just an all around good guy. They all think I'm nuts there as I routinely jump the curb to get a good parking spot as none of their customers can park their bikes. Albatross coming in for a landing.
I haven't asked yet, but I don't think it will be a problem.
hardwaregrrl screwed with this post 10-18-2012 at 10:31 AM
Old 10-18-2012, 08:40 AM   #92
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 47,579
Wicked
Originally Posted by Kai Ju View Post
Just tell them that you're riding a wide angle pushrod V twin
Che!ck out my super custom - - twin
Uncle Pollo is offline   Reply With Quote
Old 10-18-2012, 03:28 PM   #93
hardwaregrrl OP
ignore list
Oddometer: 7,288
well, there goes that idea.....the exhaust sensor is too large for the muffler. Stock muffler, no way to take the tip off to get the sensor past the cat. bummer.
Old 10-18-2012, 08:20 PM   #94
Les_Garten
Les_Garten's Avatar
Oddometer: 727
You talkin' about the HD Dyno?
Les_Garten is offline   Reply With Quote
Old 10-19-2012, 04:36 AM   #95
Uncle Pollo
happy cachiporra
Oddometer: 47,579
If your jetting is yoo rixh it will run but suck gas like crazy
I had a pilot 3 sizes too big and the needle in the wron place and moleage was 40% worse.
Old 10-19-2012, 06:30 AM   #96
hardwaregrrl OP
ignore list
Oddometer: 7,288
No, HD dealership is 50 miles away from me but the tuning shop I picked up the jets from has one and they showed me the sensor.
Uploaded from the Photobucket iPhone App
So I'm shooting blind here. I went from an Q2 to a P2 needle jet
Q2 on the right P2 on the left
, and 20 to a 25 pilot jet, put the needle back to the middle clip position.
The bike will not start with choke, but will start with a little throttle. Had this problem before. This was last night so only got a little ride in....but what is the pilot circuit telling me with that info? I have the air screw 1 1/2 turn out and apparently you cannot change them on the TM series carbs.
The left needle jet was black on the tip.
What is that telling me? thanks for everyones help....I may just get an extra splitter and swap these in before race time...
Old 10-19-2012, 01:06 PM   #97
Uncle Pollo
happy cachiporra
Oddometer: 47,579
ignition in good condition?
Uncle Pollo screwed with this post 10-19-2012 at 01:08 PM Reason: second thought
Old 10-19-2012, 01:19 PM   #98
hardwaregrrl OP
ignore list
Oddometer: 7,288
Not sure exactly what you're asking?? Timing is spot on, bike ran fine with bings, I wanted some cheap "omff" hence the flatsides.
Old 10-19-2012, 05:11 PM   #99
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
That carbon on the needle jet would suggest blow back past valves. They may be too tight/burned.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 10-19-2012, 08:19 PM   #100
hardwaregrrl OP
ignore list
Oddometer: 7,288
Nope, just had the heads done this summer, and just adjusted valves.
Old 10-19-2012, 09:23 PM   #101
Les_Garten
Les_Garten's Avatar
Oddometer: 727
Have the new carbies been popping and spitting any?
Old 10-20-2012, 06:13 AM   #102
Uncle Pollo
happy cachiporra
Oddometer: 47,579
Are the sparkplug wires new?
I had a dead cylinder ... I had spark .... but no go and the left cylinder spark plug looked dipped in coffee grounds.
It was the wires ... new wires were ordered ... after I ordered the bing rebuild kit .
lesson ... measure the resistance of your wires.
Old 10-20-2012, 06:25 AM   #103
oldroadie
Two wheel addict
Oddometer: 468
I'm having this same problem and in my case I think it's telling me the pilot is too large and I'm not getting enough air. I'm going to take the old fashioned approach and concentrate on getting the idle/starting circuit right before I start on the needle jet/jet needle main jet juggling.
oldroadie is offline   Reply With Quote
Old 10-20-2012, 06:59 AM   #104
hardwaregrrl OP
ignore list
Oddometer: 7,288
Yeah, this is the info I was looking for. I had to choke the bings, but not the mikunis so not sure if I should add more air via the screw or get an even smaller pilot jet. I'm afraid going smaller that a 20 is too small and may starve it....I forget if air screw in adds more air or takes it away.?
Old 10-20-2012, 07:21 AM   #105
hardwaregrrl OP
ignore list
Oddometer: 7,288
wires are not new, but just tested all caps and wires, it's usually the caps that go bad and not the wires.
@Les....no spitting or popping. No exorcism needed.
Times are GMT -7.   It's 06:04 AM.
