09-13-2012, 07:01 PM
#16 |
Oddometer: 44
I like "Simple Green" to clean of the oil residue. For the heavy stuff you might want to get a plastic scraper so you don't damage the aluminum.
09-13-2012, 09:07 PM
#17 |
PRJ
Oddometer: 1,415
My bike also came without the centre nut for the tappet covers, luckily the thread was OK and I simply took a length of threaded bar (8mm ?) screwed it in untill it bottomed against the head and sawed it off at the correct length. The nuts are quite expensive and the torque is so low I suspect they are largely cosmetic, the two back nuts do the job quite well on their own. Someone will definitely chime in calling for my head on a platter for this heresy
09-13-2012, 10:02 PM
#18 |
four-stroke earth-saw
Oddometer: 657
I use kerosene and a paintbrush to clean off the porous metal surfaces. Then some simple green or equivlent to remove the rest of the kerosene. I like the buffing option though, those alloys look beautiful.
Buy it, use it, break it, fix it. |
09-13-2012, 10:55 PM
#19 | |
Oddometer: 9
I've heard that simple green is corrosive to aluminum, any problems with doing this? |
09-13-2012, 11:17 PM
#20 | |
clown shoes
One thing I have always had succes with is simple green. It's not really the fastest way but has consistently been the safest least abrassive approach. I can say with a certain amount of confidence that I have no / zero data supporting my claim except for my own experience using it on 3 bikes now.
09-14-2012, 06:41 AM
#21 |
Oddometer: 180
Simple green has a corrosive agent in, get the aviation version that doesn't have that agent.
09-14-2012, 08:50 AM
#22 | |
ShadeTreeExpert
Oddometer: 5,216
I've been lucky with the two sets of heads I've used over the years. One set still has the original threads and the other has nuts behind the threads to fix them. Either system works as a repair. To make the added nuts behind the threads repair a proper sized nut is thinned with a grinder so it is thin enough to fit in the small space the stud would reach if it is long enough. Red Locktight it in place with the stud. It never has to come out. You usually need a longer stud for this repair.
Never memorize something you can look up. ---Albert Einstein |
09-14-2012, 09:03 AM
#23 | |
the thread-killer
Oddometer: 4,297
09-14-2012, 10:40 AM
#24 |
PRJ
Oddometer: 1,415
09-14-2012, 11:36 AM
#25 |
ShadeTreeExpert
Oddometer: 5,216
I have run my bike with only the two small nuts in the back or the larger center cap nut in front and didn't get any leaks. But I didn't leave it this way for very long. Wirewrkr says they are not cosmetic. So I'll keep using them.
09-14-2012, 12:16 PM
#26 | |
Oddometer: 311
09-14-2012, 01:17 PM
#27 |
Oddometer: 916
That center nut is quite handy, in that allows you to install the valve cover and it's two dollops of oil quickly and center torque the cover into place. Once sealed up you can then can sip your cold beer and do the somewhat finicky install of them two tiny washers and nuts.
09-16-2012, 01:47 PM
#28 |
Oddometer: 137
Pb blaster and scotch brute pads works pretty good too, but it's gonna take ALOT of elbow grease on mine I think.
11-19-2012, 11:33 PM
#29 |
Oddometer: 9
Ok, quick rundown on what is planned for the bike.
Swap to a modern USD front end. I've seen successful swaps using GSXR front ends done before, does anybody have any information regarding a swap like this?While I was putting the swingarm back on the frame in order to take it to my fabricator, I realized while doing so that the swingarm may not be properly aligned, which would be important in lining up the mounts for the rear shock. Any tips on how to align the swingarm/rear wheel? Should I focus on the front end swap first in order to be able to align the front and rear wheels before the swingarm modification? |
11-20-2012, 02:26 AM
#30 |
Oddometer: 148
Have you heard the term RTFM?
