Old 06-06-2005, 01:40 PM   #1
Gerg OP
Cupcake
Gerg's Avatar
Oddometer: 8,342
Question '05 640 Adventure Tools Question
Ok, I was messing around trying to cut back on all the tools I haul around. I dumped out the tool kit to see what else I might need besides the "Honker Tire Irons". Surprise, there is no way to get the front axle off!
640 tool kit
That big honker on the left will do the rear axle but the front is MUCH larger.
Now compare that kit to the 950
Note the two large box ends in the middle, the smaller fits the rear axle, the larger fits the front. the "helper sleeve" is to the right of the two box end wrenches.
So, would you guys who have the '05 check to see if you have anything that'll fit the front axle in your tool kit? Did I get shorted or do we have to haul around a 10" cresent wrench (yeah, like THAT is light )
Gerg
Greg
Certified Ole Fart
Gerg is offline   Reply With Quote
Old 06-06-2005, 02:25 PM   #2
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,730
dunno gerg... my 02 has 27mm hex nuts both front and rear. looks like the same tool kit as yours... you got 2 bottle openers. nice those are a rare find.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 06-06-2005, 02:34 PM   #3
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,205
maybe KTM put the 950 front end on yer 640 and forgot to add the tool to the kit... naw, they wouldn't do that.
luckly you have both bikes and you can toss the 950 wrench in your 640 kit when you ride it eh?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 06-06-2005, 03:21 PM   #4
Loadedagain
making chips
Oddometer: 26,730
oh shit... i forgot about that. good call meat. gergle has the two disk front (950)... damn....
Old 06-06-2005, 03:22 PM   #5
Trevor S
Cap'n Flatulence !
Oddometer: 1,212
Yeah it's 32mm and no I did not get one with my 4 day old '05 640 Adv. See my thread "Christmas in June" where I mention that fact. My solution when I get around to it will be to cut the end of a 32mm spanner and weld it to the end of a tyre lever. I can't believe they give it to you for the "ninefiddy" but not the 640 Adv .. BLAH !
Trevor S screwed with this post 06-06-2005 at 05:01 PM
Trevor S is offline   Reply With Quote
Old 06-06-2005, 03:26 PM   #6
Loadedagain
making chips
Oddometer: 26,730
my guts tellin me they did not do it intentionally. i like your idea with chopping a box ender. another option would be to ring up a snap on dealer and order an "extra thin" wrench. they are super light... low torque, butt perfect for this job. may cost you a couple bucks, but shit.... you have 30g's worth of ktms in the garage so fuck it.
Old 06-06-2005, 03:57 PM   #7
Trevor S
Cap'n Flatulence !
Oddometer: 1,212
The third option is to see how much KTM want to charge me for the one from the ninefiddy toolkit, I have emailed the dealer and asked.
I would still probably hack it up to weld it to the end of a tyre iron anyway.
Old 06-06-2005, 03:58 PM   #8
braaap!
waiting for the big one
braaap!'s Avatar
Oddometer: 2,385
640 tool kit
Gerg
Checkout the other face of the large ring / hook spanner..... should have the required ring spanner welded on... is in my 04 kit kit and......
front removed with inc' tool kit spanner.
The only thing you don't get, is a drift to push the axle thru fork legs after loosening pinch bolts.... but I found a bit of stick that did the job
them again, maybe I got the 'special' 03/04 tool kit
braaap! is offline   Reply With Quote
Old 06-06-2005, 04:01 PM   #9
meat popsicle
Ignostic
Oddometer: 14,205
i use a allen wrench to motivate the front axle out. can't remember the size offhand. my axle has a hex hole for the wrench and you spin the axle with the wrench and it will come out.
Old 06-06-2005, 04:05 PM   #10
Loadedagain
making chips
Oddometer: 26,730
loaded built a nice little knurled aluminium drift with a step that fits inside the axle for that whackin job. wonder if he should market that?
Old 06-06-2005, 04:20 PM   #11
Gerg OP
Cupcake
Gerg's Avatar
Oddometer: 8,342
Nope. that's too small. The front is about 32 or 34 MM. It's huge. Compare the wrenches in the 950 kit (same back axle). I think the 950 front end went on for the 05's. Most of the bits are the same on my early '04 950 as on the '05 640.
The nut on the front axle will allow you to push the axle out about 20mm. That gives you enough room to grab it.(on the 05)
Gerg
Greg
Certified Ole Fart
Old 06-06-2005, 04:20 PM   #12
meat popsicle
Ignostic
Oddometer: 14,205
the allen wrench price point is maybe fitty cent... tough market
Old 06-06-2005, 04:23 PM   #13
Loadedagain
making chips
Oddometer: 26,730
tough market til you fuck up your axle and find out how much it costs
Old 06-06-2005, 04:31 PM   #14
braaap!
braaap!'s Avatar
Oddometer: 2,385
KTM would never fuggup the mix and match tools for different models.... would they?
Old 06-06-2005, 04:41 PM   #15
Gerg OP
Cupcake
Gerg's Avatar
Oddometer: 8,342
Yeah, you Ausies get all the good shit
That certainly looks bigger than the one I have. I'll bet they screwed the pooch on this one (or all the kits that made it to Amercia).
The bad part is the proper tool isn't listed in any of the parts books
I'd hate to think I'll have to buy an entire 950 kit to get what I need (or the Ausie kit like yours )
Gerg
Greg
Certified Ole Fart
Times are GMT -7.   It's 07:19 AM.
