Old 09-10-2012, 12:57 PM   #1
huronbikes OP
Oddometer: 4
GT/T500 ignition died. Any subs?
I was pondering over how to deal with a Suzuki GT500 and its dead CDI / PEI / Caveman Transistorized Ignition module. Has anyone tried using a GM HEI module to trigger the coils on that bike, or any other sort of devious hackish substitution?
If you guys haven't seen it before, http://home.comcast.net/~loudgpz/GPZ...ZgmHEImod.html demonstrates building an ignition for the GPz 4s and the 750 twins, though both are 4 strokes and I'm not exactly sure what factors need to be accounted for when trying to duplicate this for a two stroke.
Alternatively, is there an aftermarket option that doesn't cost a butt and a nut?
huronbikes is offline   Reply With Quote
Old 09-11-2012, 02:08 PM   #2
Twin-shocker
Oddometer: 1,673
Try a 6 pin pit bike CDI unit...........get the wiring right and it may well work. The 5 pin type work fine on AC CDI systems.
Old 09-12-2012, 02:34 PM   #3
Andyinhilo
Andyinhilo's Avatar
Oddometer: 1,690
If you guys haven't seen it before, http://home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html demonstrates building an ignition for the GPz 4s and the 750 twins, though both are 4 strokes and I'm not exactly sure what factors need to be accounted for when trying to duplicate this for a two stroke.
The way i read it, it should work fine, one module per coil. The 4 cylinder setup would be the same since those bike are a wasted spark system (it fires at TDC every revolution).
"The rifle itself has no moral stature, since it has no will of its own. Naturally, it may be used by evil men for evil purposes, but there are more good men than evil, and while the latter cannot be persuaded to the path of righteousness by propaganda, they can certainly be corrected by good men with rifles."J. Cooper
Andyinhilo is offline   Reply With Quote
Old 09-13-2012, 07:26 AM   #4
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,267
what about the timing curve? ....i would assume the t500 cdi retards timing at high rpm. the hei just keeps advancing.......... could be a recipe for disaster - you may be able to use just about any cdi that works off the same pickup style (inductive i assume?) there's lots of cheap ones out there that have no timing curve, which might work.... ebay dc cdi and you might find a $10 unit that will work. the moped guys do it... if you can find one with a 2 stroke curve that would be much better..
current bikes
stainlesscycle is offline   Reply With Quote
Old 09-14-2012, 08:46 PM   #5
Tim McKittrick
Oddometer: 1,726
It looks like Boyer Bransden used to make an ignition for your bike but doesn't anymore- they still might be worth contacting for assistance:
http://www.boyerbransden.com/suzuki.html
I have also seen reports of folks using Powerdynamo with good results:
http://powerdynamo.biz/deu/systems/lists/suzuki.php
http://powerdynamo.biz/eng/systems/7201/72017main.htm
A little over $400
Tim McKittrick is offline   Reply With Quote
Old 10-14-2012, 07:49 PM   #6
mach1charlie
To old to fall off
Oddometer: 28
Hei
I did two HEIs on a kz1000, worked great
mach1charlie is offline   Reply With Quote
Old 10-15-2012, 06:05 AM   #7
anotherguy
anotherguy's Avatar
Oddometer: 6,387
Try Ignitech. Reasonable prices and good support even though it's a Czech company. Look at the CDI-P2 for your bike.
you don't see luggage racks on a hearse..........act accordingly
Old 10-15-2012, 10:18 AM   #8
killfile
49/50
killfile's Avatar
Oddometer: 353
A little over $400
Powerdynamo is great because it replaces everything electrical for running, but the Czech craftsmanship leaves a LOT to be desired. My rotor didn't have anything that looked like a proper timing mark. Managed to get it running, but it confirmed my suspicions that there was no mark in that location!
Gallery MotoSF & Neoedo
killfile is offline   Reply With Quote
Times are GMT -7.   It's 12:06 AM.
