View Results: Let's hear your experience with Valve Jobs
I installed BMW valves and had no problems 24 42.86%
I installed BMW Valves and had problems 3 5.36%
I installed SI Valves and had no problems 2 3.57%
I installed SI Valves and had problems 3 5.36%
I installed Swiss Intervalve Valves and had no problems 15 26.79%
I installed Swiss Intervalve Valves and had problems 1 1.79%
I installed Black Diamond Valves and had no problems 17 30.36%
I installed Black Diamond Valves and had problems 4 7.14%
I installed Moorespeed Valves and had no problems 2 3.57%
I installed Moorespeed Valves and had problems 1 1.79%
Multiple Choice Poll. Voters: 56. You may not vote on this poll
Old 10-25-2012, 01:41 AM   #16
Arkwright
Grumpy ole Git
Arkwright's Avatar
Oddometer: 114
Some of Ritchie Moore's are a bit tight in the collets which doesn't allow the valve to turn and keep the faces clean!
Duncan
R1200 GS (07)
R80 being Cafe Racered (82)
R80 G/S (81)
R100 GSPD (92)
Arkwright is offline   Reply With Quote
Old 10-27-2012, 09:47 AM   #17
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Thanx!
Les_Garten is offline   Reply With Quote
Old 10-27-2012, 10:30 AM   #18
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,747
Hmm! Have you got them in your engines Duncan or is that just heresay?
Rob Farmer is offline   Reply With Quote
Old 10-27-2012, 10:32 AM   #19
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,747
Actually the poll is not going to be accurate since most of us have several bikes yet can only make one selection. I have Moorespeeds in one engine, BMW in another and intervalve in a third. I've also had issues in the past but can't pick all the options.
Old 10-27-2012, 01:33 PM   #20
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Edit your post and post it inline Rob.
Thanx for the input!
Old 10-27-2012, 03:01 PM   #21
Arkwright
Grumpy ole Git
Arkwright's Avatar
Oddometer: 114
No Rob, not heresay, I don't deal in that, have dealt with one or two sets of heads with the problem. I believe Ritchie is aware.
Duncan
R1200 GS (07)
R80 G/S (81)
R100 GSPD (92)
Old 10-28-2012, 12:15 AM   #22
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,747
Poorly worded on my part there Duncan sorry. I wasn't trying to imply that you did. I just wanted to be aware of any potential issues.
my moorespeed valves are very good. just over 3,000 miles on them, have checked the clearances twice and haven't needed to adjust them yet. the engines remains very smooth and quick. very pleased.
Old 10-28-2012, 04:20 PM   #23
moorespeed
Oddometer: 64
I changed the collet groove detail on my valves when I did the first prototypes in 1991. to stop the valve rotating, as any engine builder worth his salt will tell you floating valves are a bad policy, its called evolution hardly any europen or jap engines use them, I had my first test set in a r100rt that did 70miles a day on the motorway they now have over 60000 miles on them and I inspect them every year. my valves are made for me by the same people that make them for cosworth, so you get a better product for less money bacause there is only me and the manufacture, where as when you buy your BMW valve the manufacture makes his profit then BMW AG then the shipping then BMW north America then the dealer, work it out,I could have valves made the same way for a fraction of the cost but why would I want to make an a product that is not as good, plus as soon as you start to use higher spring pressure and more revs the heads just drop off god knows I have seen enough.
moorespeed is offline   Reply With Quote
Old 10-28-2012, 07:28 PM   #24
Carl
Carl's Avatar
Oddometer: 768
Please verify:
  • The first test set of valves referenced in your post was installed in or around '91?
  • The first test set has over 60,000 miles of use to date?
  • What's inspected on the first test set every year?
Thanks, Carl
http://www.flyingtpot.com/
Carl is offline   Reply With Quote
Old 11-05-2012, 01:48 PM   #25
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
More Valvole's Please!
Old 11-18-2012, 11:08 AM   #26
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Bump for new Valve entries!
Old 12-08-2012, 08:54 PM   #27
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
I know there's more wanting to join this Party!
Old 01-28-2013, 09:54 PM   #28
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Maybe we've caught all we can.
Old 03-15-2013, 11:16 PM   #29
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
You knew I was gonna bump again for more valves!
<<This is my Airhead, there are many like it, but this one is mine>>
My "Orange Snappy Club" Membership Photo
Old 03-16-2013, 12:39 AM   #30
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,747
My Moorespeeds are still going strong and still haven't needed any adjustment.
My 100 PD has a valve issue. The valves and guides were done just before I bought the bike so have only done 25k. As soon as I find the time I'll pull the heads and see what make the valves are.
Times are GMT -7.   It's 06:25 PM.
