Old 10-28-2012, 06:37 AM   #1
birddogone OP
birddogone's Avatar
Oddometer: 26
BMW style plug won't work with Triumph
I just got a new to me 2006 Tiger and have dicovered my BMW power plugs won't work with the Tiger's factory plug. They look the same but the BMW is slightly larger.
Thanks for any help,
Rod
birddogone screwed with this post 10-28-2012 at 06:50 AM
birddogone is offline   Reply With Quote
Old 10-28-2012, 06:50 AM   #2
Riot
Tiger Rider
Oddometer: 105
That's strange, I added an aftermarket powerlet plug where the factory second power outlet goes and it is exactly the same diameter as the OEM on the ignition.
I have a mate with a GS and we can use each others leads for charging etc ???
Riot is offline   Reply With Quote
Old 10-28-2012, 06:52 AM   #3
birddogone OP
birddogone's Avatar
Oddometer: 26
Never mind........I just tried again and pushed a little harder. I must be loosing my strength in my old age! Thanks for your response Riot.
Old 10-28-2012, 07:16 AM   #4
EggChaser
EggChaser's Avatar
Oddometer: 536
Just for reference the mini-plug used by both BMW and Triumph (and in some boat based applications) is a set standard as such for compatibilty the plugs and sockets should have the same dimensions
Standard is ISO 4165 http://en.wikipedia.org/wiki/ISO_4165
Plugs are often called
BMW Style
Hella
DIN (which is sort of incorrect as that is a German standards authority so it should also have a number)
Powerlet
EggChaser is offline   Reply With Quote
Old 10-28-2012, 07:55 AM   #5
victor441
victor441's Avatar
Oddometer: 899
Glad that worked out...BTW, i just bought a 2006 Tiger recently myself and made a right angle powerlet to cigarette adapter, works well for powering my GPS, etc and does not look too bad..used a powerlet plug wired to a CG cigarette socket
victor441 is offline   Reply With Quote
Old 10-28-2012, 04:56 PM   #6
birddogone OP
birddogone's Avatar
Oddometer: 26
Thanks for the replys fellas, I've spent about 3 full days go'n thru this machine make'n it mine. I have just two things I want to use the outlet for, my heated vest (BMW) and my trickle charger. I'm gonna post a few pictures soon. Sure do enjoy having a modern cycle after driving old ones for years.
Rod
Old 10-28-2012, 07:56 PM   #7
birddogone OP
birddogone's Avatar
Oddometer: 26
Hey Victor, That picture on your Avitar is me when I was about seven, I've not been right since......... :)
Times are GMT -7.   It's 06:27 PM.
