Old 09-11-2012, 04:33 AM   #1
rosiethestarfish OP
Oddometer: 10
dr650 countershaft oil seal issue
Hi guys,
This is my first post so be gentle. I recently bought a dr650 se 2009. I am currently having a major issue with the countershaft seal. I have read multiple threads from both adv rider and thumper talk. The impression I get is this typically happens on earlier model bikes. So far I have fixed this problem three times. The first time I simply glued it back in..the solution lasted less than 5 k. The next time I used better glue and I also centre punched (reccommended in another thread). The seal has since popped out again.
I have run out of ideas. I am hoping someone has had a similar problem and has found a successful solution. I am really worried about this. Its not a slow leak, when the seal goes all the oil comes gushing out of the bike and all over the back end of the bike. It will only be a matter of time until I cook the engine.
rosiethestarfish is offline   Reply With Quote
Old 09-11-2012, 06:33 AM   #2
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,097
I've used adhesive silicone on fork seals that wanted to work out of place.
Clean and dry the seal/counter bore with a drying agent like brake clean.
A light smear on seal and bore, press seal in by hand... wait 24 hours or more before use.
next.. be gentle
OldPete is online now   Reply With Quote
Old 09-12-2012, 05:15 AM   #3
greer
Oddometer: 3,771
Have you over-filled the oil? 2 quarts/liters is all you need. Seems like I read over-filling might be part of the problem. Good luck and let us know how it goes.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 09-12-2012, 06:04 AM   #4
wos
Oddometer: 1,690
There was a thread up in Canada I think. A couple had the same problem with a newer model of that engine. They found that the factory had messed up the case machining on some of these motors and an oversized seal was available. Maybe you could get your dealer to call the suzuki tech line.
wos is offline   Reply With Quote
Old 09-13-2012, 04:37 AM   #5
greer
Oddometer: 3,771
More reading:
http://drriders.com/topic1190.html
http://drriders.com/topic4128.html
http://drriders.com/topic2395.html
Sarah
'08 DR650
Old 09-13-2012, 03:13 PM   #6
LukasM
Oddometer: 5,415
Not an uncommon problem on the DR.
Bergdonk made a retainer plate for the seal, check towards the end of his thread:
http://www.advrider.com/forums/showthread.php?t=646076
Old 09-13-2012, 08:53 PM   #7
rosiethestarfish OP
Oddometer: 10
Thanks for the info guys. I saw the retaining plate, great idea. It does seem odd to me that Suzuki dont offer a plate as an after sale part or that one of the accessories providers dont make one. All good I will contact berg and see if he is willing to make another. Thanks guys
Old 03-04-2013, 11:35 AM   #8
HAPPYTRAILSINC
single track rider
HAPPYTRAILSINC's Avatar
Oddometer: 1,006
OK GUYS,we have a new 2012dr650 w/loose counter shaft seal here in the shop!
bike came in leaking oil on left side-filled w/oil and started-instantly found leak-c/s seal popped out- popped back in only to come right out due to the oil pressure
so i called the answer man at suzuki~
here is the answer directly from "steve wolf"-suzuki's western service advisor!
has says the problem cames from a too tight of chain running @ high speeds warps/distorts the cases thus ovalizing the c/s seal hole!
if it still under warranty suzuki will replace the cases
HAPPYTRAILS
Scott
I am in not associated with happy-trails.com
I am the original happytrails
HAPPYTRAILSINC is offline   Reply With Quote
Old 03-04-2013, 02:12 PM   #9
wee-twin
Oddometer: 201
Has been talked about and solved in the DR650 thread. If covered under warranty, have Suzuki take care of it. Regardless of if Suzuki fixes it or not, procycle has manufactured a counter shaft seal retainer. Installing the retainer is cheap insurance either way. If under warranty, Suzuki has admitted the seal seat was overmachined on some bikes.
wee-twin is offline   Reply With Quote
Times are GMT -7.   It's 11:05 AM.
