Old 11-10-2012, 09:52 AM   #1
blaster11 OP
Are you a Sheeple?
blaster11's Avatar
Oddometer: 4,689
Send a message via Skype™ to blaster11
Trying to identify a clamp
OK, I will try to describe this as best I can. It is a two piece clamp made of metal which clamps on tube or pipe, so a round hole in center typically with two bolts which screw the two halves together. If you look at the clamp from the side it has a square outside shape with the hole in the center for the pipe or tube. The part which clamps around the tube/pipe is smooth and not serrated. Hopefully my description is good enough. Oh and if you know where to buy them that would be helpful as well.
Bruce
IBA # 46755
Adventures of Blaster and Dorito
blaster11 is offline   Reply With Quote
Old 11-10-2012, 10:01 AM   #2
Ratski
Ratski's Avatar
Oddometer: 564
It seems that you are looking for shaft collars. Lots of variety to choose from.
Try here -----> http://www.mcmaster.com/#shaft-collars/=k3srfu
1983 Honda CB650SC Nighthawk
1984 Honda GL1200A Goldwing Aspencade, a work in progress
1996 KTM 300 EXC Plated
Ratski is offline   Reply With Quote
Old 11-10-2012, 10:04 AM   #3
GreaseMonkey
Rhymes w/piecejunkie
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 4,767
What size tube are you wanting to clamp? 1/2" or 3", etc? Also, do you want it to be metal or reinforced plastic? A grainger or McMaster catalog might have some choices, but there are also items made for mounting antennas that can work depending on your budget and what size you need.
GreaseMonkey is offline   Reply With Quote
Old 11-10-2012, 10:29 AM   #4
RalphyDo
Oddometer: 308
What are you trying to use them for? I think I know what you are looking for but cannot remember the propername for them.
RalphyDo is offline   Reply With Quote
Old 11-10-2012, 11:28 AM   #5
blaster11 OP
Are you a Sheeple?
blaster11's Avatar
Oddometer: 4,689
That's the concept but they need to be square rather than round on the exterior. I will be bolting flat stock on the flat edge that's why I need the square one's.
I don't have the exact measurement but somewhere around 1 1/4" hole in center. I am looking for the metal ones.
I can't think of the proper name either.
Bruce
IBA # 46755
Old 11-10-2012, 12:51 PM   #6
GreaseMonkey
Oddometer: 4,767
Here is one place that calls them "Super Duty Saddle Clamps":
Unfortunately they only have 2" listed as being the smallest:
http://www.dxengineering.com/search/...d=super%20duty
And they are also somewhat spendy. If you can live with plastic, they make a "Resin Support Block" in a ton of sizes:
And the 1 1/4" ones are less than $5:
http://www.dxengineering.com/search/...pport%20blocks
Hope that helps you!
Old 11-10-2012, 12:59 PM   #7
GreaseMonkey
Oddometer: 4,767
Oh also I had the thought that if you needed a quick and half assed version of this you could just purchase 2 muffler/exhaust clamps and use the base plates:
Old 11-10-2012, 02:40 PM   #8
RalphyDo
Oddometer: 308
Something like this? Obviously these are not exact but close?
http://ubmachine.com/shockssquare.html
Times are GMT -7.   It's 11:03 AM.
