09-14-2012, 10:45 AM
#16 |
Geeser
Oddometer: 2,169
+1 couldn't agree more
IBA #42016 CDR 2012 Nova Scotia 2011 Taking Molly to Atlantis Labador Newfoundland Nova Scotia 2010 Trail of an Assassin Alaska 2009 follow the ride on spot |
09-14-2012, 10:50 AM
#17 | |
Oddometer: 218
Guys. Am I missing something here. Only 23,000 miles on the wheel bearings? Wheel bearings should not fail for at least 200,000 or more miles. Just kidding. if you really take the time to think about all the abuse this bike has been through, it really is a testament of not only how good of bike the F800 is, but how great it is that we live during a time when we are actually able to own a vehicle that can take this abuse. And I'm talking about most motorcycles, not just this BMW. Glad I was not riding back in the '40's!
'09 BMW 1200GS Adventure, '09 Vstar 950 '09 Honda Rebel, '77 CB750A, new garage (in planning) Need more room for more bikes. |
09-14-2012, 11:38 AM
#18 |
Kilroy was here
Oddometer: 436
Are you serious? The 2013s have been out for a few weeks. If you're really concerned about issues youll need to wait. If you've read these forums youd see there are two people who have problems with the seats falling apart.
09-14-2012, 04:36 PM
#19 | |
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,969
09-15-2012, 12:16 PM
#20 |
Oddometer: 170
Don't know about "common" since it's a new (2013) release for me but...
1. Seat seam split about 300 miles (http://www.advrider.com/forums/showt...php?p=19601324) 2. Fork seal leak (noticed at 1000 miles by dealer for my first service [HEY! I got it on 9/1 so two weeks ago...]). Unfortunately, there are not any in the CONUS, and about 5 sets in DE. They tried to clean it up as best they can until they get the fork seals - and no, it's a different/larger fork plus there's potentially a different tool required to change it up. 3. Highway Dirt Bike guards don't want to fit. It appears the bar ends have changed for the 2013 lineup. They're not only a different screw, but counterbored (instead of counter sunk) and longer by about 1/2" 4. With the BMW headlight protector in place, the headlight can be wiggled up and down. Not loose, just weird as I'm used to those things being locked down - solid. The other problem is that I'm starting to spend a lot of money, again. Motooverland skid/bash plate & top rack, Alt-Rider crash bars (which bend, and there's no exact match for "powder coat black" I'm aware of), Pivot Pegz (which help a lot!), TouraTech folding clutch lever extension (size 13 boots), folding/extendable brake/clutch levers, BMW headlight protector, Lamin-X headlight protector, Touratech rack, RAM mount for the Montana GPS, RAM mount for the GoPro, HDB protectors and top clamp, etc. But yeah, 1000+ miles and the gas mileage is good, it's smooth (enough) on the highway, no complaints about the comfort on the seat, works well in the twisties, falls over and survives stream beds w/ baby head rocks (Anakees suck horrible in the loose). So far... great bike. PatrickM screwed with this post 09-15-2012 at 08:20 PM Reason: Post dealer updates. |
09-16-2012, 09:37 AM
#21 |
Oddometer: 18
ABS and ASC problems
I just picked up my new 2013 F800. When you shut the ASC off the light comes on to indicate that its off but if you hit even the smallest pebble the motor goes to 1000 rpm and stays there. I cant even get it up a gravel driveway. I've almost crashed it twice because of this. I cant get the ABS to shut off at all. Can these features be programmed out of this bike all together?
09-16-2012, 11:22 AM
#22 | |
Cosmopolitan Adv
![]() Did you push the ABS button long enough when the bike wasn't rolling so that the like stop blinking (I think like the ASC)?
Keep the smile on your face! An Otter on the road: From Lille to Limoges in 12 Days An Otter on the road: I'm coming up so you better get this party started! |
09-16-2012, 11:49 AM
#23 | |
its Ground Zero
Oddometer: 574
But, I have a broken ABS sensor, on my 2010. Blinker Cancel doesn't work, and ABS doesn't work. I have NO IDEA what might happen on the 2013, but you could try unplugging one of your ABS sensors.
XOVERLAND.COM Our vendor thread HERE Season 1 Done!! HERE 6 Full Episodes Free on our website!!! If you like it, "Like" us on FaceBook 2010 F800gs (Mine) 2011 F650gs (Wifes) |
09-16-2012, 12:54 PM
#24 | |
its Ground Zero
Oddometer: 574
But first off I would get back down to the dealer and have them check it out. Sounds like something isn't right.... Ryan
09-16-2012, 04:05 PM
#25 |
Oddometer: 18
well I removed the rear wheel sensor and the bike runs great but I lost my speedometer. I guess I need to remove the front sensor instead. At least I can ride the bike till I get it back to the dealer.
09-16-2012, 04:13 PM
#26 | |
Oddometer: 2,969
odd.... I've got 20k miles without a rear abs sensor and I've always had the speedometer work...maybe a change for 2013?
09-16-2012, 05:51 PM
#27 | |
its Ground Zero
Oddometer: 574
My rear is busted off as well, for about 11k miles, like I said, only thing that doesn't work is the blinker cancel. The only advantage I see to removing the front is that the Odometer seems to be calibrated for the rear wheel, so it is slightly off on the mile count. Speedo seems to be fine, but odo is off. And the factory non-ABS bikes have the rear sensor only. What is your experience with that Motorfiets?
09-16-2012, 06:05 PM
#28 | |
Oddometer: 2,969
I will say however that I have a 18" rear now and it seems to have made my accuracy better |
09-16-2012, 08:43 PM
#29 |
Oddometer: 2,825
Ditto...... After my 18 inch rear install...... Speedo and gps are now the same..... As mileage is accurater as well....
Erling |
09-17-2012, 05:31 PM
#30 |
Oddometer: 18
I put the back sensor on and removed the front. My speedo works now and I can get my ASC and ABS light to stay on instead of blinking. I see there is a plug right behind the steering stem can I unplug my sensor there?
