Old 09-13-2012, 06:04 PM   #1
Les_Garten OP
Les_Garten's Avatar
Oddometer: 683
S Fairing Copper Grommets
I just got a Factory New S Fairing.
It has those copper grommets holding the dash on.
I want to pull that dash off to paint the fairing.
What's the best procedure for drilling them out and putting them back?
Les_Garten is offline   Reply With Quote
Old 09-13-2012, 06:21 PM   #2
bikerfish
flyfishandride
Oddometer: 970
I've always just masked the dash off.
bikerfish is offline   Reply With Quote
Old 09-13-2012, 07:06 PM   #3
Les_Garten OP
Les_Garten's Avatar
Oddometer: 683
I'd like to get it separated to do it.
Old 09-13-2012, 07:41 PM   #4
DaveBall
DaveBall's Avatar
Oddometer: 919
Usual method to remove is either a drill or dremel. You will need to hold the opposite side with pliers or something, as when you get about 1/2 way thru they usually start to just spin.
When putting it back on, you can either get replacment rivets, or as many have done, you can use short black plastic nuts and bolts. I used the black plastic screws on 2 that I have done, as well as on an RS and a couple of RT fairings. I like using the nuts and bolts because I can take it apart a lot easier if I need to repaint again, or to remove the dash to modify for some reason.
DaveBall is online now   Reply With Quote
Old 09-13-2012, 07:50 PM   #5
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 912
Go to "Tips and tricks" post 644 http://www.advrider.com/forums/showt...169507&page=43
__________________________________________
"There's a fine line between a skinning and a shearing"
RecycledRS is offline   Reply With Quote
Old 09-13-2012, 08:10 PM   #6
Les_Garten OP
Les_Garten's Avatar
Oddometer: 683
Originally Posted by RecycledRS View Post
Thanx guys, I put these posts in my build links folder to keep when I get to that part. Looks kinda lika a PITA.
Old 09-13-2012, 08:12 PM   #7
Les_Garten OP
Les_Garten's Avatar
Oddometer: 683
You use the screws to hold the winshield, fairing, and dash all together?
Old 09-13-2012, 10:04 PM   #8
Beamer Bum
Beamer Bum's Avatar
Oddometer: 177
If they are copper rivets, you can cut them off with a pair of dikes. I mean diagnal cutters, not lesbians.
Cut halfway through,than rotate dikes 90 degrees and cut the rest of the way through. They will drop right out and you won't widen or damage the holes.
Working for my next trip
http://advrider.com/forums/showthread.php?t=721872
Beamer Bum is online now   Reply With Quote
Old 09-14-2012, 06:31 AM   #9
Les_Garten OP
Les_Garten's Avatar
Oddometer: 683
I've been cutoff by a few dykes "mid-pickup" if you know what I mean!
Thanx! The idea of drilling all those does sound a might bit tedious.
Times are GMT -7.   It's 07:47 PM.
