Old 09-15-2012, 11:20 PM   #1
TFB43 OP
TFB43's Avatar
Oddometer: 66
1200gs Factory Auxiliary light wiring kit on f800gs
I am wondering if anyone has used the 1200gs wiring harness kit on the f800gs? I have installed the rigid lights and have enough wire on the provided harness to wrap around the world. Done the search nothing comes up. Anybody?
TFB43 is offline   Reply With Quote
Old 09-16-2012, 07:04 AM   #2
Angryrican
know nothing all
Angryrican's Avatar
Oddometer: 266
Since its it for the F800GS I would either fold and zip tie it or trim it to size just like I would with a universal kit
Angryrican is offline   Reply With Quote
Old 09-16-2012, 11:00 AM   #3
TFB43 OP
TFB43's Avatar
Oddometer: 66
Auxiliary OEM harness?
Ok I can do that but, i found on ascycles.com this part number 61128534525 that says its the auxiliary LED headlight wiring harness. Now looking on parts.bmwgroup.com I found this part 61128530338. WIll this part allow wiring of the factory 1200gs auxiliary lights?
The first part number i only found on a german website and it says it is no longer available. So my question stands. Looking for a more clean factory harness. Is there one?
Old 09-16-2012, 02:51 PM   #4
TFB43 OP
TFB43's Avatar
Oddometer: 66
Anybody?
Old 09-16-2012, 08:17 PM   #5
TFB43 OP
TFB43's Avatar
Oddometer: 66
Old 09-17-2012, 09:55 AM   #6
Astolfo
Wicked Slow
Astolfo's Avatar
Oddometer: 798
it works for me.
i can post pics of the handlebar
1995 R1000 GS 1998 R850 GS 1999 R1000Gs 2007 KTM ADV 990 2009 R1200GS
2012 F800GS White & Blue Trophy
2014 GSA
Astolfo is offline   Reply With Quote
Old 09-17-2012, 10:05 AM   #7
TFB43 OP
TFB43's Avatar
Oddometer: 66
Astolfo,
You have used the entire wiring harness not just the switch? If so, what did you have to do? Does it plug in somewhere? Does it connect to the battery? How much modification did you have to make for it to work?
Old 09-17-2012, 03:11 PM   #8
TFB43 OP
TFB43's Avatar
Oddometer: 66
https://plus.google.com/photos/11228...52091229273873
2013 F800gs Factory Aux Lights. Found the part numbers
Where would the wiring harness plug into on the 2012? Is it possible?
Old 09-17-2012, 06:42 PM   #9
TFB43 OP
TFB43's Avatar
Oddometer: 66
I didn't see anywhere you could plug the aux harness on the 12 800gs. Maybe the plug on the battery?
Old 09-17-2012, 06:43 PM   #10
TFB43 OP
TFB43's Avatar
Oddometer: 66
This thread is me having a conversation with.....me.
Old 09-17-2012, 06:47 PM   #11
ebrabaek
Oddometer: 4,712
Erling
Old 09-20-2012, 04:11 AM   #12
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
I moved an OE BMW auxiliary light switch from my '07 R1200R to my '09 F800GS, a perfect fit. The aux switch housing replaces the plastic on the forward side of the clutch lever's housing. The R1200R and R1200GS are identical in this respect, so your experience should be the same as mine reinstalling your R1200GS auxiliary light switch on your F800GS.
This may not apply to the 2013 F800GS with the new switchgear.
Fred
FredRydr is offline   Reply With Quote
Old 09-20-2012, 07:24 AM   #13
TFB43 OP
TFB43's Avatar
Oddometer: 66
Fred
Thank You Fred!
I am excited to get my wiring issue tidied up. The new 2013 F800 will not accept the switch for the r1200gs... But it will have a wiring harness designed specifically for it. You can view it on the Webetk bmw parts site. Since the part is so new techs are not sure of a retrofit. I have the r1200gs wiring harness on order. Going to look at it for a clean install. Also have the centek ap2 and wiring harness. Going to cost about the same, but the centek will give me the option to add other electric goodies. Purchased some posi tap connect stuff to get everything clean.
Old 09-23-2012, 11:44 PM   #14
TFB43 OP
TFB43's Avatar
Oddometer: 66
Thank You Fred!
Bad idea for the 1200 wiring harness... Hacked into the harness and found making one was the way to go. The 1200 aux switch worked 3 times before it stopped. It was so much fun taking all the plastic off and routing the wires, the best part was getting them all back on and the switch not working. now I make a toggle box took the petty covering off of the factory harness attached it to my wiring and zip tied it all. So I have the factory switch and my funny plastic box switch. I love wasting money
Old 09-24-2012, 09:41 AM   #15
TFB43 OP
TFB43's Avatar
Oddometer: 66
photo of new 2013 wiring harness.
[IMG]
[/IMG]
Times are GMT -7.   It's 01:52 AM.
