Old 05-09-2013, 07:01 PM   #1
Dadayama OP
Constant Adventurer
Dadayama's Avatar
Oddometer: 587
HELP Wheel Bearings.
Just changed my rear tire and the bearings feel rough and very much not smooth.
Here is my dumb question, because I do not know, I learn as I go.
Where do i get the bearings? Do not have a local dealer here in Oklahoma City, do I order online or is there some other option.
Looks like maybe there are three different bearings to replace, does that seem right to you all?
Ich Fahre Nicht Zu Schnell, Ich Fliege Nur Niedrig
Oklahoma Adventure Trail
YouTube
Dadayama is offline   Reply With Quote
Old 05-09-2013, 07:35 PM   #2
yety61
Global Vagabond
Oddometer: 1,198
Google is your friend.
Aftermarket bearing shops.
Online BMW dealers.
Lots of options.
Three bearings is correct.
I'd personally go for aftermarket bearing shops (cheaper).
Cheers.
yety61 is offline   Reply With Quote
Old 05-09-2013, 07:37 PM   #3
sieg
sieg's Avatar
Oddometer: 2,796
Local auto parts stores also.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 05-09-2013, 08:45 PM   #4
Dadayama OP
Constant Adventurer
Dadayama's Avatar
Oddometer: 587
A friend of mine called me and said the very same thing... go to a bearing shop or auto parts place or even an industrial supply...
I'll give a try when the sun comes up...
Thanks again
YouTube
Old 05-09-2013, 08:50 PM   #5
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,370
There's a BMW shop in Tulsa, Iron Lightening or something..
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 05-09-2013, 09:23 PM   #6
jengel451
1 Cool MotherF#$cker
Oddometer: 789
find a reputable bearing shop and bring in your old bearings/seals etc.
Try to get SKF or Timken's. SKF seems to be the better of the two lately.
jengel451 is offline   Reply With Quote
Old 05-09-2013, 09:32 PM   #7
ebrabaek
Oddometer: 4,712
Might also want to give Zach or Woddy, a call at woddyswheelworks.com Rather than me bore you to death, they will fill you in about the issue with too much bearing crush on the 8GS rear.
Erling
Old 05-09-2013, 10:25 PM   #8
Calgary06
Calgary06's Avatar
Oddometer: 160
I just finished replacing all of my bearings front and rear. The front didn't need it but I was on a roll...
I got my bearings from a transmission and bearing supply shop that was local to me. They had FAG bearings in stock so I went with them - turns out that is what BMW had originally installed. Don't forget to get the seals while you are there. Mine were shot. Which is probably why the bearings were bad. Luckily for us the seals and bearings are a very common and standard size.
To get them out I used this set from Motionpro (http://www.motionpro.com/motorcycle/partno/08-0269/) You really only the 20mm collet unless you have friends that will want to 'borrow' it. I fought the first one out of the sprocket hub with a punch and hammer prior to ordering the MP stuff. Heat, cursing and tool throwing was involved... Once I got the proper tool I pounded out the bearings in 4 or 5 whacks each quite easily. I highly recommend it.
Bearings I used were:
FAG 6204-C-2HRS C3
2 in the front and 3 in the rear
20x47x14mm deep groove sealed both sides.
I got two sets of seals so I can replace them more regularly.
The front has one 25x47x7mm and one 30x47x7mm.
The rear has two 30x47x7mm oil seals.
Sizes and diagrams were here under 'wheels'.
Hope that helps.
Have fun.
EEUC
Calgary06 is offline   Reply With Quote
Old 05-09-2013, 11:23 PM   #9
jengel451
Oddometer: 789
Wow, did a quick search, and found Woody's Vender thread about them. That was a good read and definitely something to keep in mind in the future.
Old 05-10-2013, 05:04 AM   #10
JRWooden
Oddometer: 4,232
Link?
If handy...
no coffee here ... I'm brain-dead.
Old 05-10-2013, 09:01 AM   #11
jengel451
Oddometer: 789
Originally Posted by JRWooden View Post
Link?
If handy...
Do I have to do everything around here?
http://www.advrider.com/forums/showthread.php?t=505577
Old 05-10-2013, 10:13 AM   #12
1P8RIOT
1P8RIOT's Avatar
Oddometer: 378
seals
Don't for get to get new seals too unless you're better at getting them out in one piece than I am.
A ship in a port is safe but that is not what ships are built for. - Mom
'09 F800GS YEAH BABY!!!
1P8RIOT is offline   Reply With Quote
Old 05-10-2013, 01:26 PM   #13
Calgary06
Calgary06's Avatar
Oddometer: 160
My seals came out pretty easily. The center of them, that spin around the axle/spacers were quite ragged. The spacers fell out by themselves once I got the wheels off the bike. The new ones held the spacers pretty tightly. Perhaps that is a sign to check bearings and replace seals once the seals can no longer hold the spacers in position.
A question for others. One of the spacers, the smaller rear one, had a little groove worn in it where the seal rubs. Should I think about replacing the spacer?
EEUC
Old 05-10-2013, 05:00 PM   #14
LukasM
Oddometer: 5,386
When there is a groove it won't seal properly any more, so dirt and moisture can get in there and wear out your wheel bearings prematurely.
So replace them, ideally with a quality stainless set that will outlast the aluminum ones many times. Scheffelmeier Metall from Germany makes them and has very good international shipping rates.
Old 05-10-2013, 05:30 PM   #15
Calgary06
Calgary06's Avatar
Oddometer: 160
Thanks. I sort of figured I'd have to replace them.
I'll have a look for the scheffelmeier ones.
EEUC
Times are GMT -7.   It's 11:23 AM.
