Old 06-08-2005, 07:38 AM   #1
Airhead OP
More human than human
Airhead's Avatar
Oddometer: 2,099
Question Electric output on LC4?
So, I just purchased a 2000 LC4 enduro. I am considering putting more powerful bulbs in the headlight and adding some aux lighting...but I'm not sure how much juice the thing puts out. Anyone know, or have an educated guess? I don't have the manual yet...so I thought I'd ask here first. I'd hate to go hanging a whole bunch of expensive lighting all over it just to find out it can't power the stuff...
'05.5 KTM 950 Adventure
2008 KTM 450 EXC-R
All Orange, Baby!
Airhead is offline   Reply With Quote
Old 06-08-2005, 07:42 AM   #2
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Basically it's 200 watts, but that's at max rpm. Probably figure you've got 8-10 amps to play with under "normal" conditions....
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 06-08-2005, 08:16 AM   #3
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
Flanny went thru this with KTM:
Originally Posted by Flanny
Here is my original post on KTM talk from a while back...
I had some correspondence from one of the electrical engineers at the KTM factory about this.
Basically 200W is MAXIMUM output. So you would get about 16amps at full RPM. At cruising speed (5500rpm), you are down to about 13.5 amps. The battery needs about 3amps to maintain good strong charge, so you want to keep your TOTAL amperage to less than 10 amps. Even then, at idle or cruising around town you are down to 11amps, and so if you had 10amps TOTAL, you would only have 1amp left for the battery.
So...bottom line. Add up all your loads, and keep it down to 10A total, and turn off the extras in town to manage load. (ie don't sit at a stop light iding with your heated grips on "give-it-to-me", and your 100W driving light balring)
Your headlamp alone is 55w = 4.6amp. Heated grips are another 3.5 amps, and roadbook/GPS/Accessory lighting=1 amps or so. So on my bike I basically have 9amps load, or 1 amp left for otther stuff. Also, in a subsequent e-mail, the engineer said that the accesory leads, and all lamps are on 1-10amp fuse, so you'd be running the risk of blowing fuses with too much more load.
Here is the engineers message.
Mr. Flannigan
I am responsible for the electric system of our bikes . I hope , I can
answer your questions .
To my information , the Adventures used on in the globerider story had stock
headlamps . For an other Adventure for an australien rider we made some
minor electrical modifications , like output for GPS and for charging
notebook battery .
Generator performance :
The generator / regulator output depends on engine rpm . Please see table
below
1500 rpm 9 A
2000 rpm 11 A
3000 rpm 13 A
6000 rpm 14 A
10000 rpm 15 A
Battery charge :
On a long trip your average rpm maybe around 4000 to 5000 rpm giving around
13 A generator output . Please make sure , that your power consumption is
less , around 10 A , to have some current for battery charging .
Wiring harness :
Our harness is made to minimum outside dimensions and we use small wire
sections .Other bike makers may consider KTM harness as too small .
With higher load , you may run into voltage drops problems . Voltage drop
can cause some problems :
* Bad light output , because lamp performance highly depends on
voltage
* Bad battery charge
Fuses :
The purpose of fuses is to protect the harness in case of short circuit .
Typical reason for short circuit is when wires are mechanically damaged .
Fuse rating has to be matched with wire section .
If you overload fuses with your higher capacitiy equipment , they may blow
and you will replace with a stronger fuse .
The problem of stronger fuses is , that in case of short circuit , they may
not protect the small wire section . The wire may blow before the fuse .
Couplers and switches :
Couplers and switches on KTM's again are not overspecified . The just work
with standard load . With higher load , the may fail .
Conclusion :
If you know something on electricity , you can try . Test your system before
you start your trip and be prepared to run in one or the other problem
listed above .
If you have no idea on electricity , please do not change the system !
If you have further questions , please do not hesitate to came back to me .
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 06-08-2005, 08:25 AM   #4
Airhead OP
Airhead's Avatar
Oddometer: 2,099
Thanks...that was very helpful!
2008 KTM 450 EXC-R
All Orange, Baby!
Old 06-08-2005, 08:28 AM   #5
meat popsicle
Ignostic
Oddometer: 14,247
yeah, flanny was one helpful dude. too bad he was tempted to the dark side...
Old 06-08-2005, 09:13 AM   #6
Airhead OP
Airhead's Avatar
Oddometer: 2,099
I guess another way to ask this is...
Has anyone successfully increased the light output on their LC4?
2008 KTM 450 EXC-R
All Orange, Baby!
Old 06-08-2005, 09:21 AM   #7
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Uncle Creeper stuck a 35W HID (TrailTech?) on his. He's happy....
Creep.....chime in here:_________________________________
Chris
1943 BSA M20WD
Old 06-08-2005, 09:31 AM   #8
Airhead OP
Airhead's Avatar
Oddometer: 2,099
Creeper to the white courtesy phone...
2008 KTM 450 EXC-R
All Orange, Baby!
Old 06-08-2005, 09:35 AM   #9
meat popsicle
Ignostic
Oddometer: 14,247
there's a thread on that...
Old 06-08-2005, 12:14 PM   #10
Velocibiker
Adventure Antagonist
Velocibiker's Avatar
Oddometer: 1,164
Actually, the TT HID only draws 13W.
To increase visibility, I wired my Adventure lights so both are on when I turn on the high-beam.
A future (pennywise) mod is to convert the front signals so they act as running lights too.
The Trail Tech HIDs are the best option (currently) if you want to add light. A pair of 13W lights shouldn't overtax the charging system at cruising speeds.
If cash isn't an issue, replace all your lights with HID and LED and you'll have amps to spare!
Currently bikeless.
Velocibiker is offline   Reply With Quote
Old 06-08-2005, 12:38 PM   #11
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
My bad....big brain-fart....I knew that....
Chris
1943 BSA M20WD
Old 06-08-2005, 12:43 PM   #12
meat popsicle
Ignostic
Oddometer: 14,247
Old 06-08-2005, 05:28 PM   #13
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,711
Been running 2x55w driving lights hooked to my high beam for 2 years now, with no starting problems. That's 170w, or 14.1 amps. Numbers say it shouldn't work, as per the email above, but it does.
My only guess is that the engineer was being typical per his trade, that is, conservative. Most I've met are. But that's a wag.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 06-08-2005, 06:13 PM   #14
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
If someone said it would work and then it did not in your case... you'd be upset.
All parts have tolerances ... your alternator may put out more power than most. Or your lights are consuming less.
The next LC4 may only put out what the manufacture states. Or teh lights may consume more.
Being conservative means things are safe. Mostly.
Frank Warner is offline   Reply With Quote
Old 06-08-2005, 07:57 PM   #15
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,711
Hard to litigate that they're too safe.
Times are GMT -7.   It's 05:31 AM.
