View Results: Which is more reliable for Airheads ... electronic ignition or points?
BMW Airhead electronic ignitions are super reliable. Leave it alone 21 31.82%
BMW Airhead electronic ignitions are junk, replace with aftermarket electronic ignition 4 6.06%
BMW Airhead electronic ignitions are junk, replace with beancan w/points 7 10.61%
BMW points & Condensers are reliable. leave it alone 29 43.94%
BMW points & Condensers are junk. replace with aftermarket electronic ignition 5 7.58%
Voters: 66. You may not vote on this poll
Old 06-23-2014, 06:52 PM   #166
_cy_ OP
Oddometer: 6,359
Originally Posted by Skyshadow View Post
damn you make it sound so dang easy to have points.....the truth is
I can change my oil and adjust my valves in the amount of time it takes what you are suggesting to get back on the road with points......and this is on a naked r80g/s. If I add the lower PD fairing....add another 10 minutes.
I don't know...I am just not seeing the benefit yet when a person can simply carry a spare bean can.
LOTS of folks have trouble chasing down issues related to dead and/or intermittent electronic ignitions.
you are one of the few that has problems getting a points ignition to work properly.
when that happens a phantom ground needs to be checked with a meg ohm meter like Fluke 1520.
find a mechanic that has one .. they are not that uncommon.
this is assuming you've already done the easy replacement parts route. especially using known to be good parts.
the usual complaint for points ignition is not getting it running properly ... it's the upkeep points require vs electronic no maintence at all
Fluke 1520
old Biddle Meggers comes up all the time for cheap. old timers prefer the crank versions when megging larger armatures.
paid all of $25 for mine at a flea market .. works just as good if not better than the Fluke 1520.
_cy_ screwed with this post 06-23-2014 at 07:18 PM
Old 06-24-2014, 08:59 AM   #167
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,607
The stock electronic ignition failed on me during a road trip and left me stranded. The ICU failed--likely because I forgot to replace the heat sink paste during my rebuild. Several days of 100+ degree traffic in Mexico was as hard on the bike as it was on me I guess.
It was easy to troubleshoot, you undo the 3-pin connector and ground out certain pins to determine which component failed, and I found a spare ICU from a Volkswagen Jetta for $25 at a local parts shop. Fired right up and I was off and running.
When I got back from the road trip I picked up a rebuilt points-can from Datchew for cheap. I didn't mistrust the electronics but I liked the idea of an old-school, mechanical system. If you don't like old-school mechanics you probably shouldn't be riding an airhead anyways. I've lived with the points for 40 or 50k miles and I've been pretty happy with them.
I didn't switch the 5k electronic plug out for the 1k points caps but the bike ran fine on them for tens of thousands of miles. The greater resistance caused some juice to leach through the insulator where the wire from the condenser goes through the can to the points though. It melted the resistor once and a blob of molten plastic fell down on the points killing the bike. I scraped the plastic off, wrapped the wire in electrical tape where it passed through the can, and I was off again.
I'm on my 3rd set of points--once I replaced them when they didn't need it and once they were burned up. I probably could've sanded the points and they'd have worked but I had a spare so swapped it. Still on the original condenser.
I had a new set of Bosch points fail on me the day after I installed them when one of the contacts fell off. The stories of the newer parts being poorly made might be true. I'm running a set of off-brand points made for some car now and they've held up fine for 10k or so.
I can't complain about either set-up. It was never cold-natured or finicky about idling/accelerating with either one.
I've got an Enduralast alternator and I'll likely get their crank-mounted electronic ignition once they get the bugs worked out. I'll keep my points can installed though.
Anyways, there's my two cents after having put a lotta miles on both.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 06-24-2014, 09:59 AM   #168
supershaft
because I can
Oddometer: 9,116
I have always cleaned and re-applied heat sink paste to ICU's when I have them off for whatever reason. (Almost always for something other than replacing the ICU.) Regularly re-applying heat sink paste as scheduled maintenance? I have been around SO many ICU's that never had that done including my own that I find it hard to believe it would make any difference. Fixing a bad ICU with heat paste? I haven't seen that many ICU's go bad but heat sink paste wasn't the issue with bad ICU's I have found.
Old 06-24-2014, 10:58 AM   #169
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,607
Well for whatever reason it definitely died at about 40k miles\25 years. I remember there being a discussion about the paste and I know I didn't get to it before the trip.
Old 08-08-2014, 03:57 PM   #170
japhyRIDER
Oddometer: 6
Originally Posted by bgoodsoil View Post
I've got an Enduralast alternator and I'll likely get their crank-mounted electronic ignition once they get the bugs worked out. I'll keep my points can .
What bugs need working out with these?
japhyRIDER is offline   Reply With Quote
Old 08-08-2014, 08:30 PM   #171
_cy_ OP
Oddometer: 6,359
nothing wrong with enduralast charging except it's a less desirable permanent magnet system.
several folks having problems with eduralast ignitions
http://www.advrider.com/forums/showthread.php?t=924786
Old 08-09-2014, 03:58 AM   #172
beemerphile
beemerphile's Avatar
Oddometer: 1,919
That is one opinion. Some se the PM system as more desirable because they charge at lower engine speeds and there are no brushes to maintain (or fail). The parts count and complexity of the system is less and the heat producing element (the regulator / rectifier) is removed from the already hot timing chest. A spare R/R is inexpensive and easily carried as spare. Much lighter and less space than all the spares for a Motorola style system.
ΜOΛΩΝ ΛΑΒΕ - Lee
Unreconstructed Southerner living in Occupied Georgia
beemerphile is offline   Reply With Quote
Old 08-10-2014, 07:03 AM   #173
RaystheBMW
1986 R65
RaystheBMW's Avatar
Oddometer: 171
My ignition flaked out several times, i.e., stalls and after a minute starts up again. While trouble shooting, I pulled the ICU and the original paste had turned to dust. It was never renewed and I figured the ICU might have been permanently damaged. But I cleaned it up, applied new heat sink paste, and it hasn't missed a beat in 2 years now. Still I bought a replacement module, just in case.
RaystheBMW is offline   Reply With Quote
Old 08-10-2014, 08:32 AM   #174
supershaft
because I can
Oddometer: 9,116
Probably just about how this urban legend got started.
Old 08-11-2014, 10:38 AM   #175
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,607
this is a bit of a tangent since this thread is about about ignition but where are you seeing inexpensive R/Rs? All the one's I'm looking at are over $100. I've seen some used ones at ~$60 but that's still pretty spendy. It'd be nice to have a spare but EME wants $140 for theirs.
Old 08-13-2014, 06:18 AM   #176
Global Rider
Alps Adventurer
Global Rider's Avatar
Location: Canada & the Alps - N 46° 31.714' E 010° 27.212'
Oddometer: 3,809
I'm still running on my original ignition components and alternator on my 1990 R100 GS.
Other than renewing the heat sink compound on the ignition module, they all seem to work fine and are reliable.
All the best,
Alex
Euro & North American Travel & Technical Stuff for the R1150 GS & Adventure
Euro & Alps Motorcycle Tours - Priced Right, How to go about
Great spirits have always encountered violent opposition from mediocre minds.....A. Einstein
Global Rider is offline   Reply With Quote
Old 08-13-2014, 06:48 AM   #177
_cy_ OP
Oddometer: 6,359
that's pretty outstanding service and testimony to just how rugged original charging and ignition systems were. but it's now 24 years later ...
how many miles does your 1990 R100GS have and under what conditions was it stored under?
what's the charging voltage at idle and 3k rpm?
_cy_ screwed with this post 08-13-2014 at 06:56 AM
Old 08-13-2014, 11:07 AM   #178
Global Rider
Alps Adventurer
Oddometer: 3,809
For its age, low mileage (I have other bikes), but the systems have seen plenty of heat cycles. Stored in my garage and well maintained.
I am about to install one of my LCD voltmeters as I have on my oilhead BMW and car, so I can't recall V numbers, but I have never had a charging issue while operating within the design limits. Batteries (FLA) have lasted 9 years considering sporatic use.
All the best,
Alex
Old 08-13-2014, 03:40 PM   #179
_cy_ OP
Oddometer: 6,359
there's a common misconception that the original charging system doesn't put out enough wattage when their airhead's battery goes dead. when in fact the problem of sluggish charging can be traced to low charging voltage, NOT a lack of output.
sure stock alternator may only put out 280 watts or less. but our airheads don't have the same overhead modern bikes do.
duh .. if you take out more AH than you put back into battery ... at some point that battery will not start your bike. as you know if charging voltage is too low, the rate that amps gets pushed into battery goes down accordingly.
Old 08-27-2014, 06:31 PM   #180
patrkbukly
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,214
Sparkplug question
seems obvious but thought I would be sure….
If you switch from a 1993 electronic ignition to a 1978 points beancan you change to the green coil run the wire yada yada good to go…BUT….
What will those original 1993 electronic ignition sparkplugs do differently from the points beancan?
So in other words, the plugs must be changed as well correct?
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is online now   Reply With Quote
Times are GMT -7.   It's 07:46 AM.
