Old 09-17-2012, 10:54 PM   #1
sh1bby69 OP
sh1bby69's Avatar
Oddometer: 527
'79 BMW R100RT and Sputnik
Hey guys! Pretty soon I'll be receiving my '79 BMW R100RT and will be mounting it to a Sputnik sidecar. So hopefully this will be my build thread. I'll be ordering a DMC Subframe to mount the sidecar and the Sputnik already has upgrade mounts per Jay. Got the sidecar for a steal same with the bike. I'm going to go through the bike and give it a basic tune up. Then take my time mounting the sidecar.
A quick question though...Since the bike has a full fairing, will that have to come off to mount the subframe and also mount the sidecar?
The Bike
Info from PO: full fairing , Krauser bags, dual front disc brakes, single disc rear brake, clock and voltmeter, very complete tool kit. Since it was new, things that have been added...floorboards, dual plugs put in heads, transmission rebuilt [about 11000 miles ago] the seat replaced with a "day long" Mayer seat, Luftmister trunk added.
The PO
The Tub: Sputnik with 19" Snowflake wheels (Cast Iron I believe) and disc brakes. DMC mounts as well.
'79 BMW R65
'03 KLR650 Sputnik Sidecar
sh1bby69 is offline   Reply With Quote
Old 09-18-2012, 05:00 AM   #2
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,184
Yay- airhead build!
The ladies used to check me out...now they just keep an eye on me.
MotoJ is offline   Reply With Quote
Old 09-18-2012, 01:02 PM   #3
Biebs
BMW Airhead
Biebs's Avatar
Oddometer: 536
Thumb Good start - Keep the pictures and progress coming!!
You will have to remove the right side fairing lower that goes around the cylinder to access frame for front DMC subframe.
Biebs is offline   Reply With Quote
Old 09-19-2012, 01:38 AM   #4
sh1bby69 OP
sh1bby69's Avatar
Oddometer: 527
Thanks! I should be receiving the bike on Wednesday. Can't wait! Going to go through the bike to make sure the brakes are good and running strong. Then I'll place an order in to Jay for a subframe and what not!
'79 BMW R65
Old 09-21-2012, 02:01 PM   #5
sh1bby69 OP
sh1bby69's Avatar
Oddometer: 527
Got the bike in! Starts up right away! Is leaking what looks like from the drain plug and also from the forward portion of the drive shaft. This weekend I think I'll get working on it.
Debating if I want to keep the fairings or make it naked.
'79 BMW R65
Old 09-21-2012, 07:48 PM   #6
tony the tiger
yeah - what he said...
tony the tiger's Avatar
Oddometer: 10,470
I've seen a few with the lowers removed - guess it depends on when / where you intend to ride it. mine, the left side gets a bit hot (lowers intact)
Tony
Your signature contains too many lines and must be shortened. You may only have up to 5 line(s). Long text may have been implicitly wrapped, causing it to be counted as multiple lines.
tony the tiger is offline   Reply With Quote
Old 09-21-2012, 11:48 PM   #7
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,098
Looks like it's gonna be a cool build.
Good luck with it.
What are the two gauges above the speedo and tach?
Eric B
'06 R12GSA/Hack & '10 R12GSA
An armed society is a polite society. Manners are good when one may have to back up his acts with his life. Robert A. Heinlein
BeeMaa is offline   Reply With Quote
Old 09-21-2012, 11:55 PM   #8
Awfers
Oddometer: 76
Good luck with it.
I think one is an oil temp gauge, the other a clock.
Awfers is offline   Reply With Quote
Old 09-22-2012, 12:21 AM   #9
sh1bby69 OP
sh1bby69's Avatar
Oddometer: 527
Good luck with it.
The two gauges are a voltmeter and a clock.
'79 BMW R65
Old 09-22-2012, 02:37 PM   #10
Ivan Rider
Ivan Rider's Avatar
Oddometer: 603
When I mounted a sidecar on my Daughter's R100RT I made a hole through the lower right fairing for the upper strut. You don't have to remove it. Measure several times before you cut the hole. I had to make an oval hole as I missed the first time.
'78 BMW R100/Ural sidecar, '99 Ural Patrol
'03 BMW R1200CLC Solo & Ural sidecar Rig
'06 Honda Big Ruckus Solo & Sidecar Rig,
'08 Ural Retro, '10 Ural ST Solo
http://www.flickr.com/photo s/ivanrider/
Ivan Rider is offline   Reply With Quote
Old 09-25-2012, 10:09 AM   #11
jaydmc
Oddometer: 1,059
We usualy take the lower fairing off however you can cut holes in it to work. We have an RS in the shop right now that we have the mounts on but will not be able to install the sidecar until late this week as there are 3 others ahead of it for this week.
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jaydmc is offline   Reply With Quote
Old 09-25-2012, 04:09 PM   #12
sh1bby69 OP
sh1bby69's Avatar
Oddometer: 527
I wish mine was near 3 weeks of completion! I still havent had the chance to go through the bike.
Would you suggest the sidecar have an independent master cylinder for its brake or have it tapped into the bikes MC?
Sent from my Galaxy Nexus using Tapatalk 2
'79 BMW R65
Old 09-25-2012, 09:57 PM   #13
WU7X
The Old Fart
WU7X's Avatar
Oddometer: 2,036
I have an '82 R100RT, naked, towing a Squire ST2 sidecar. Original torsion bar frame on the car. Also has EML leading link front end and rear Icon shocks. I think you will really love your setup! The bike has more than enough power to get you into trouble. I envy your disc brake on the car.
Best of luck with the buildup. You may want to rebuild the carbs if it's been sitting for any length of time. I rebuilt my 40mm bings using the Bing DVD as a guide. It will walk you right through the process easy peasy.
Keep the pics coming!
"Seika" - 2013 DL650 + DMC M72D Sidecar
"Gracie" - 1983 R100RT 60th Anniversary Edition
"Dusty" 2011 Adventurized 4Runner
Adventure is worthwhile." ~ Aristotle
Airhead #14449
WU7X is offline   Reply With Quote
Old 09-25-2012, 10:35 PM   #14
sh1bby69 OP
sh1bby69's Avatar
Oddometer: 527
Do you mind posting a pick of your bike?
'79 BMW R65
Old 09-28-2012, 08:21 AM   #15
WU7X
The Old Fart
WU7X's Avatar
Oddometer: 2,036
Try this page: http://www.advrider.com/forums/showt...94734&page=306 #4579.
If you need anything special, I'll have to run out with the iPhone and put one up with Tapatalk.
Airhead #14449
Times are GMT -7.   It's 10:58 PM.
