Old 11-10-2013, 04:22 PM   #571
Trl Rdr
Big Red Bird
Trl Rdr's Avatar
Oddometer: 2,062
The aluminum bar sucks the heat out on the left while the plastic throttle tube acts like an insulator on the right.
OR you want to run the driving light facing on coming traffic at a lower setting than the ditch side light off the same pot.
Sent from my DROID RAZR HD using Tapatalk
2 XR650r(s) 2001 & 2002 Plated
GL18HPM9 Titanium (Gold Wing)
CRF230F for the tight shit!
Baja Mexico Trail Ride Report
Big Bend Ranch Drive and Ride Report
Trl Rdr screwed with this post 11-10-2013 at 04:29 PM
Trl Rdr is offline   Reply With Quote
Old 11-10-2013, 04:35 PM   #572
Lounge
Lounge's Avatar
Oddometer: 411
I want oncoming traffic to see me.
Why spend $250+ on a fancy do everything fuse block when you can put an inline potentiometer on the feed wire to each side, adjust it once and be done??
Honestly, I'm impressed by how well the crowd input has been received. This device already has more features than 95% of it's users will ever utilize and CC presses on.
CC - don't put so much into it that you price yourself out of the market.
Looking forward to seeing a production unit.
My apologies to the meek and the Earth they will not inherit.
Lounge is offline   Reply With Quote
Old 11-10-2013, 04:37 PM   #573
craftycoder OP
Motobrain PDU
craftycoder's Avatar
Oddometer: 2,334
Originally Posted by Trl Rdr View Post
Say I have grip heaters, but the throttle side runs hotter. Can I set 2 outputs to run together on a pot but offset with voltage output?
You would need to use two inputs and outputs for that to work. One pot could be connected to both inputs though.
craftycoder is offline   Reply With Quote
Old 11-10-2013, 04:42 PM   #574
craftycoder OP
Motobrain PDU
Oddometer: 2,334
No single problem you might have will likely be economically solved with Motobrain. Motobrain solves SO MANY problems that I think a lot of people will save money with it when all the little bits and bobs of a custom electronics solution are added together.
craftycoder screwed with this post 11-10-2013 at 06:02 PM
Old 11-10-2013, 06:01 PM   #575
etingelefunts
retem-odo
etingelefunts's Avatar
Oddometer: 815
Why spend $250+ on a fancy do everything fuse block....?
To have room for expansion.
Even today's cars are more advanced than the Apollo Space vehicles (think Saturn V rockets)
This sort of technology actually SIMPLIFIES creativity.
Nice thing about THIS gizmo, is YOU control the level of technology, and know exactly how to fix it in a pinch... win-win !!
Less pondering. Simply march ahead, to the ends of this majestic planet.
etingelefunts is offline   Reply With Quote
Old 11-10-2013, 06:51 PM   #576
yosso
yosso's Avatar
Oddometer: 977
Piece it all together and spend more or get the Motobrain and spend less with a (hopefully) more robust solution than the pieced together solution.
Honda ST1300/2000 Suzuki DRZ400E/Ducati 750 Monster re-work Blog
yosso is online now   Reply With Quote
Old 11-10-2013, 09:40 PM   #577
Lounge
Lounge's Avatar
Oddometer: 411
Keep what I said in context - the person I sent that to was referring to independently controlling his heated grips.
Old 11-10-2013, 10:28 PM   #578
Lounge
Lounge's Avatar
Oddometer: 411
Keep what I said in context - the guy wanted to control his heated grips independently which can be done for about $6.
But if you want to get into a shit slinging contest, I could go with a fuseblock ($84 per your example) and an Arduino (~$15) for less than $100. Actually, add a 3 axis controller (~$8) to my list so I can turn off my blinkers automatically when I come out of a turn and to add a motion sensing alarm to my bike.
Of course I'll wait for a production MB - looking forward to it.
Old 11-11-2013, 04:41 AM   #579
yosso
yosso's Avatar
Oddometer: 977
Merely pointing out what I had researched for my solution, which would be off the shelf solution, not a hacked together solution (albeit a cool solution using an Arduino).
Not trying to throw rocks or sling fecal matter. :-)
Have a great day.
yosso screwed with this post 11-11-2013 at 04:49 AM Reason: rephrased reply.
Old 11-11-2013, 05:18 AM   #580
etingelefunts
retem-odo
Oddometer: 815
...plus labor... oh and if that is the only upgrade he will ever contemplate, then why is he here reading this? Just wondering out loud
You sling all that "shit" ONTO your own bike, so we can have something to point at as the tedious status quo.
Old 11-11-2013, 07:28 AM   #581
Lounge
Lounge's Avatar
Oddometer: 411
...labor?? ... cut 2 wires, solder pots, heat shrink, adjust pots - done.
I'm putting an Arduino on a custom 78' R100/7 that I'm building - be happy to show it to you when I'm finished. I was waiting on the MB and still may go MB if the production run hits the streets in the next few months.
Anyway - I'm done - back to our regularly scheduled program.
Keep us posted CC - nice work.
Old 11-11-2013, 07:53 AM   #582
craftycoder OP
Motobrain PDU
Oddometer: 2,334
Will do. Things are going perfectly. Next job is updating the iOS software for iOS7 and the new features. My new thermal camera is coming tomorrow which should tell us if there are any hidden problems we cannot see on the boards. Next, it will be time to do some serious testing both on the road and in the lab while the next new form factor prototypes get built up. Then, the long hard process of building a market for this starts. Unless I can make these things by the 1000 they will make little sense to build.
Old 11-11-2013, 08:54 AM   #583
yosso
yosso's Avatar
Oddometer: 977
Did the Pace podcast guys ever get back with you regarding a demo unit?
Old 11-11-2013, 10:05 AM   #584
craftycoder OP
Motobrain PDU
Oddometer: 2,334
I don't think so. If they did, I missed it.
Old 11-12-2013, 08:34 AM   #585
tdcarter
tdcarter's Avatar
Oddometer: 79
You are going to control 50w or 100w driving lights with a pot? Heated grips.. maybe.. but I want to see where you mount the pot and what melts next to it.
Ohh.. maybe you are using them new high techy fangled HID's... pot one of those and post up a video when you turn it on please.
tdcarter is offline   Reply With Quote
Times are GMT -7.   It's 11:35 AM.
