Old 05-20-2014, 03:25 PM   #991
Steigs
Oddometer: 126
Originally Posted by craftycoder View Post
LOVE the isolators!
Can't wait til this thing is ready to go.
Steigs is offline   Reply With Quote
Old 05-20-2014, 09:12 PM   #992
craftycoder OP
Motobrain PDU
craftycoder's Avatar
Oddometer: 2,335
I worked out PWM adjusters for each output channel.
craftycoder is offline   Reply With Quote
Old 05-21-2014, 01:21 PM   #993
satur9
angry black guy
satur9's Avatar
Oddometer: 539
awesomeness
I drank the koolaid again.
Well, it took a lot of work to be the ass that I am
And I'm real damn sure that anyone can, equally easily f*ck you over ...(modest mouse).
satur9 is offline   Reply With Quote
Old 05-21-2014, 01:43 PM   #994
craftycoder OP
Motobrain PDU
Oddometer: 2,335
Originally Posted by satur9 View Post
awesomeness
It works nicely too. Video below.
Old 05-21-2014, 03:11 PM   #995
dwoodward
dwoodward's Avatar
Oddometer: 5,735
I presume there's some sort of security on the app & unit, so random inmates can't screw up your bike at a rally?
Not that anyone would do that. maybe. If everyone liked you.
dwoodward is offline   Reply With Quote
Old 05-21-2014, 03:20 PM   #996
craftycoder OP
Motobrain PDU
Oddometer: 2,335
Security has architected in but remains untested. You will set the password and then have to use it from then on. I expect it to be easy to setup.
Old 05-21-2014, 03:28 PM   #997
lmychajluk
Oddometer: 2,100
Wouldn't the bluetooth security cover that? On that note... How would one activate the pairing process from the device?
Sent from my SM-G900P using Tapatalk
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 05-21-2014, 04:39 PM   #998
craftycoder OP
Motobrain PDU
Oddometer: 2,335
The normal way for your device (check your owner manual :P). The security I plan to implement is a password based form of standard BT security. You will get to select your own password though rather than the standard system where I select the password for you or make it the same for all devices.
Old 05-21-2014, 05:01 PM   #999
Buster452
Buster452's Avatar
Oddometer: 243
How would you handle multiple devices in an rv or boat situation? Separate disconnect and pairing sessions or connect to multiple named devices with and active device selector on your screen? Maybe slide left/right to access different devices?
"If you don't know where you are going, any road will get you there." Cheshire Cat
Buster452 is offline   Reply With Quote
Old 05-21-2014, 08:10 PM   #1000
DRjoe
DRjoe's Avatar
Oddometer: 5,236
Would like to know also.
When doing fit outs multiple units will be used so an easy way of programming multiple units easily and quickly would be nice would be especially great if when two or more are used together any inputs could be used to switch any output and not be just limited banks of 8.
Old 05-25-2014, 02:34 PM   #1001
craftycoder OP
Motobrain PDU
Oddometer: 2,335
You just pick the unit you want to look at from the drop down in the upper left of the screen. No big deal.
Old 05-27-2014, 08:33 AM   #1002
dwoodward
dwoodward's Avatar
Oddometer: 5,735
Yeah, for the software, but he also wants to be able to use an input on one unit to switch circuits on other units. For example, Input #1.1 (board.input) turns on circuit 1.1, 1.2, 2.3, and all of board 3.
Extra programming aside, I do not see that as a desirable feature; it's going to make things more complicated than tying together inputs from three boards, for what I suspect will be a relative minority of installations.
Old 05-27-2014, 08:52 AM   #1003
craftycoder OP
Motobrain PDU
Oddometer: 2,335
We are not doing that. The input wires carry no current. They have 1MΩ input impedance. You can run a piece of telephone wire if you like so moving signal around is just too easy to introduce the complexity and unreliability of radio to the system.
Old 05-27-2014, 07:14 PM   #1004
bpeterson
I just tweeted it
bpeterson's Avatar
Oddometer: 1,067
I'm digging this concept a lot and look forward to your pricing & launch. good luck, you've done a ton of work!
-b
'14 KTM 350 EXC-F, '04 GS Adv, '02 DR-Z 400S
bpeterson is offline   Reply With Quote
Old 06-03-2014, 06:36 PM   #1005
craftycoder OP
Motobrain PDU
Oddometer: 2,335
Production samples of Motobrain boards from a fabricator in Asia are shipping in the next few hours. I've already received PCBs samples of the heavy duty power boards from a couple of suppliers in Asia as well and they are getting close. Some are great but too expensive, some are the "right" price but are missing on the quality side of things. I am still working those details out but suffice to say, things are progressing nicely. I'll post a report on how the boards turned out when they arrive at the lab.
PDUMCU26OP+PCB[1]
Times are GMT -7.   It's 01:44 PM.
