Old 08-12-2014, 10:25 PM   #1096
Craneguy
British Hooligan
Craneguy's Avatar
Oddometer: 1,027
Thought it was time to drop back in and congratulate you on your progress. I was the first comment here, and gave you the crappy kickstarter suggestion.
Anyway, I'm really glad to see you've gone the distance with this, and I'm definitely in for an "8ter" when they hit the market. I have two fuse boxes sitting in a drawer, but yours is the only one that seems appropriate for attaching to the box of magic wires that is the Multistrada. Plus it's awfully geeky and that's great!
Young enough to think I can. Old enough to know I shouldn't. Stupid enough to do it anyway
'13 Duc Multi GT, '10 Vstrom 1k, '10 705cc KLR
Craneguy is offline   Reply With Quote
Old 08-12-2014, 10:43 PM   #1097
EKinOR
Oddometer: 267
This looks like a great pot for pairing with the MotoBrain. IP67 rated and a 5/8" glove friendly knob. Only downside is price at $12/ea.
http://www.mouser.com/ProductDetail/...xFColnE8XlA%3d
- Eric
2002 BMW R1150GS
EKinOR is offline   Reply With Quote
Old 08-13-2014, 05:01 AM   #1098
craftycoder OP
Motobrain PDU
craftycoder's Avatar
Oddometer: 2,334
Thanks for sticking with me this long.
Good find.
craftycoder is offline   Reply With Quote
Old 08-19-2014, 09:45 AM   #1099
craftycoder OP
Motobrain PDU
Oddometer: 2,334
It looks like I should have units in hand about the second week of September. This video also shows how you might setup an air horn (or other high current load) with Motobrain.
Old 08-19-2014, 10:54 AM   #1100
tdcarter
tdcarter's Avatar
Oddometer: 79
Ready to produce!
Good news Crafty! Long journey and now coming to a big milestone.
Can't wait to have one to play and learn with.
2nd week of September I'll be in the middle of a 8k trip to California and back. So please let me know how I can make sure I'm in line for a unit. Come home and re-wire the bike; sounds like just what I need to ward off the post-trip blues.
On another note. The 15amp per channel. How solid/firm of a limit is that? Can it take a momentary surge higher?
Specifically I ask for a pair of HID's. I do believe they pull just over 16~18amp on cold start. But then settle down to 6 amp continuous.
Are you limiting (electronically) the channels to 15amps? So even if we try and draw more it won't let it?
tdcarter is offline   Reply With Quote
Old 08-19-2014, 11:03 AM   #1101
EKinOR
Oddometer: 267
Great news! Put me down for one!
- Eric
2002 BMW R1150GS
Old 08-19-2014, 12:39 PM   #1102
craftycoder OP
Motobrain PDU
Oddometer: 2,334
There is an analog current limiting circuit hard set at 24A. Above that and the output shuts off for about 1.4ms and turns on again. This is an analog current limiting circuit. This is different from the digital current limiting circuit that you set via the user interface. This is designed to prevent you from blowing the output transistor. The below image shows an output shorted to ground and turned on. The voltage spikes until it hits 24A and then turns off and repeats until the digital current limiting circuit decides that it has tried hard enough.
In real life, I've had no problem firing up HIDs. I have seen issues with igniting 10A halogens though (normal halogens are 55W or about 5A and present no problems). In order to fire up a 10A halogen you need about 70A to warm up the filament. This is more than Motobrain can accomplish without you doing something "special". You can use two outputs to ignite the lamp or you can use a "choke" in between the Motobrain and the lamp (shown below). This uses some magnetic field science stuff to reduce the current flow during the ignition sequence but then become low impedance once it is lit. If you use a choke, a diode also needs to be in parallel with the choke as a choke is really just an inductor and all inductors need a diode.
craftycoder screwed with this post 08-19-2014 at 01:22 PM
Old 08-19-2014, 02:23 PM   #1103
moto_dmitriy
que?
Oddometer: 102
BTW you have seen one of these right?
Also please put me down for 1 MotoBrain
moto_dmitriy is online now   Reply With Quote
Old 08-19-2014, 02:25 PM   #1104
craftycoder OP
Motobrain PDU
Oddometer: 2,334
I've got 4 oscilloscopes within arms reach right now.
Old 08-19-2014, 02:27 PM   #1105
moto_dmitriy
que?
Oddometer: 102
I was thinking in terms of mobile debugging, nudge, nudge, wink, wink
Old 08-19-2014, 02:34 PM   #1106
craftycoder OP
Motobrain PDU
Oddometer: 2,334
The ADCs and amps I've included in Motobrain are not fast enough to use as an oscope. That said, technology like I've created could be used to create a mobile oscope with your phone as the UI. I would be a bit surprised if that has not already been created by someone.
Old 08-19-2014, 04:20 PM   #1107
dwoodward
dwoodward's Avatar
Oddometer: 5,638
What, like this?
dwoodward is offline   Reply With Quote
Old 08-19-2014, 07:44 PM   #1108
craftycoder OP
Motobrain PDU
Oddometer: 2,334
Originally Posted by dwoodward View Post
What, like this?
Exactly.
Old 08-19-2014, 09:20 PM   #1109
tileman
tileman's Avatar
Oddometer: 882
Hi crafty.
Just looked back through a few pages and couldn't find a answer. I got an email via the kick-starter site. I got involved with that, do I need to let you know about interest or will I receive a purchase option via the original campaign?
I'm mid way through designing a nav tower and finding places for fuse blocks and relays etc but this will eliminate the need for all that, and more probably but my brain is going to take time to get around what this can do!!!!!
If ignorance is bliss, why aren´t more people happy?????
tileman is offline   Reply With Quote
Old 08-19-2014, 09:22 PM   #1110
tileman
tileman's Avatar
Oddometer: 882
Oh and what are the dimensions including hole centres for attachment?
Times are GMT -7.   It's 09:19 AM.
