Old 01-31-2013, 03:12 PM   #16
Paul_Rochdale OP
Paul_Rochdale's Avatar
Oddometer: 150
The latest information on this is as follows -
The bike is entirely dismantled (or if you are a Merrycan 'disassembled'). I have begun to fabricated some fillets to strengthen the frame, copying them from images and making cardboard templates. A whole afternoon sawing and filing 4mm steel resulted in on pair of fillets. I visited a local blacksmith today and bought some 3mm steel so the remaining fillets will prove easier to make. The same blacksmith put me in touch with another engineering firm with supplies of aluminium sheet. I've bought on eBay an 'Alpos' alloy topbox which will be fine for my needs although it's not the strongest example I've seen. The base is probably 1mm aluminium and has splits from all of the mounting holes so I'll stick a sheet of 2.5mm alloy across the base to strengthen it. The same blacksmith has also put me in touch with an ace welder and powdercoater so a productive afternoon. Pics to follow.
Paul_Rochdale is offline   Reply With Quote
Old 01-31-2013, 05:16 PM   #17
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,695
"Now I almost certainly won't be riding off road, it's not a part of motorcycling which really interests me, but I want a strong, tough, reliable and comfortable touring bike. 99% of the time I ride solo...."
not riding off road, then don't waste the time and money reinforcing the frame as it's not needed. Spend the money on gas and a drive shaft rebuild, possible an alternator upgrade, if running heated gear.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 01-31-2013 at 06:48 PM
Old 01-31-2013, 05:37 PM   #18
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,498
100% correct.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-31-2013, 09:46 PM   #19
Ron Seida
Adventman
Ron Seida's Avatar
Oddometer: 1,256
Exactly! Upgrade the charging system, maybe add a Nippondenso starter, as they are much more efficient running and somewhat lighter than the Bosch or Valeo your bike currently has. Definately invest in a good heated jacket, like Gerbings or Warm and Safe. Forget the vests, get one with full sleaves and heated collar, you can thank me later. After owning one, i wouldnt even think about travelling on a bike without one. Wire a Heattroller onto your dash to give you full adjustment. Make sure your heated grips are working. Put some Progressive springs in the forks and update the rear shock... dont cheap out here! Good suspension is crucial to having a good trip, and not breaking stuff on your bike, not to mention your body ;) Most importantly, continue reading this forum and learn from us! Horizons Unlimited is another good place thats a little more geared to travellers like yourself, and also based a little closer to home. You could probably meet up with a couple of people in your area. Most importantly, in the end do it your way!
"¿Qué sería de la vida si no tuviéramos el valor de intentar algo nuevo?"
Van Gogh...
"Your the only guy i've met driving a BMW who isn't an asshole."
D. Irwin...
Ron Seida is offline   Reply With Quote
Old 02-01-2013, 03:34 AM   #20
hoss18
hoss18's Avatar
Oddometer: 123
Do it dont do it, the decision is yours. I have an R80G/S and I dont ride mine hard enough to tell if the frame mods make a lot of difference but its nice to know that its stronger than anything I can throw at her. The subframe mod I feel is necessary but Im a heavy load all by myself Here is my mod for the subframe.
BMW - a love hate relationship
hoss18 is offline   Reply With Quote
Old 02-01-2013, 04:13 AM   #21
chasbmw
Oddometer: 2,212
Back then I went RTW on standard airhead road bikes, two up with camping gear (pre GS days). Quite a lot of the roads out side of Europe and north America were pretty rough, but a set of standard Craven panniers worked fine with only a little bit of remedial welding required in Ecquador. Australia included a lot of dirt roads, some rough.
Spend your money on the toughest suspension you can find and does not mean Ohlins. Plus decent panniers. Modern tents are very lightweight and I still enjoy sleeping under canvas, even if I eat out.
Charles
1971 Commando Fastback
Old 02-01-2013, 11:01 PM   #22
pommie john
pommie john's Avatar
Oddometer: 1,448
That looks a very nice and sensible mod. Very neat.
Paul, you know you're quite close to Jim Cray who is a bit of a BMW guru. he's in Faversham.
Next time you're in the Little Gem, have a pint for me
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 02-01-2013, 11:16 PM   #23
robtg
Oddometer: 665
Originally Posted by Jim Day View Post
The red areas are the frame mods I've seen. They are pretty standard. The back one is just a section of 1/8 plate, and the point there is it strengthens the connection point of the swingarm, The forward rod or tubing strengthens the connection up top. One each side for both. Make sure the top one is easily removable bolt in place for maintenance.
You have got to be kidding.
robtg is offline   Reply With Quote
Old 02-02-2013, 02:16 AM   #24
Jim Day
full manic mechanic
Jim Day's Avatar
Oddometer: 914
I KID YOU NOT!!! ha ha ha
There's a bunch of German guys doing these frame mods, I'll see if I can scrounge up some pics, but it's been a while since I looked at them. The drag for me is I do not speak German so it's always hard to find them online.
.......time passes
So I couldn't find the website I wanted but I did find some pics on a old hard drive of mine, but none with the longer cross brace.
These first few are from one guy who I believe is German, He does incredible frame mods and custom builds. He used to have a website, but I couldn't find it any more.
Here's some pics of one of his:
You can see the plate they put in front of the swingarm to minimize stress and prevent cracking.
Here's some other bikes with that same modification. It's pretty standard I've seen it all over the place.
PersonallyI find that mod kind of ugly but that's the way they do it and it does make sense. So that's the one mod I'll look around some more and see if I can find some pics of the frame cross braces.
Jim Day screwed with this post 02-03-2013 at 05:21 AM
Jim Day is offline   Reply With Quote
Old 02-03-2013, 04:34 AM   #25
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,498
Frame Brace
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is online now   Reply With Quote
Old 02-03-2013, 05:38 AM   #26
Jim Day
full manic mechanic
Jim Day's Avatar
Oddometer: 914
Originally Posted by gsd4me View Post
Nice Bike!!! I've seen that cross brace as well. It makes a lot of sense especially on a road bike where most of the pressure on the frame comes from the drivetrain. Personally if I was going to go with that brace I'd install the little swingarm plate I pictured above but instead of making it pointed I'd make the top wider, square, with a hole for mounting that brace. That way you get the benefits of the plate and a strong mounting point for the cross brace. I've also seen a top cross brace that supports the upper sub-frame mounting area. It would not be necessary on a road bike but I suppose that one does make some sense for off road use since that mounting point is being worked by the more intense demands on the rear suspension.
Jim Day screwed with this post 02-03-2013 at 06:37 AM
Old 02-03-2013, 11:43 AM   #27
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 1,473
You mind telling me a bit more about this bike, turbo & injectors??
Orange...cause it makes me look like I know what I'm doing!
Crisis management is offline   Reply With Quote
Old 02-03-2013, 01:42 PM   #28
Paul_Rochdale OP
Oddometer: 150
I would like to but it's been closed for two years with no sign of anyone wanting to buy the place. I know Jim Cray pretty well as eighteen years ago he rebuilt the engine of my R100/7. He is also going to check over my R100GS-PD engine too. I finally decided on making fillets along the lines of HPN and Dogbytes mods. This will strengthen the frame as I wanted but won't go the diagonal brace route as it's not necessary for the sort of riding I've planned. I shall re-use the existing Hagon monoshock - they will rebuild them for about £90 - as it still looks as if there's life left in it. Thanks for all of the tips and, as was said, I shall be doing it my way. I shall be speaking to a local custom bike builders about welding/bronze welding the fillets I've made.
Old 02-03-2013, 03:15 PM   #29
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,498
Owned and built by South East Queensland BMW repairer Ray Peake. He`s had it for over 25 years and has over 290,000Km on it, very reliable.
It doesn't get used much these days as he also has a much improved what was originally an R80 GS/PD and more recently an R65 mono w/- 1070cc kit and FI .
I think he pretty much built the FI injection himself, along with everything else on the bike; 18 inch front wheel, wider rear wheel, rear disc, etc, etc. The longer you look , the more modifications you see.
He's done a few good specials over the years, as well as bringing sad, (mostly airhead GS`s) back to life with the upgrades they need to be more reliable.
David Hunn:
gsd4me screwed with this post 02-03-2013 at 03:24 PM
Old 02-03-2013, 03:55 PM   #30
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,498
All very good advice. Back "in the day" it was well known in Oz that the /5, /6, and /7 subframes were weak and a Craven rack helped beef things up.
Hyperpro is the rear suspension I would choose over anything, these days.
David Hunn:
Times are GMT -7.   It's 11:43 PM.
