09-20-2012, 01:15 AM
#1 |
Oddometer: 470
F8GS Foot Brake Lever Top Position
Sorry if this questions has been already raised. I did a search but had results with zillion possibilities.... However, think its in the nature of a forum that some questions may have been asked several times. Pls dont shoot me
After a short ride I tried to adjust the foot brake lever as it is far too low for offroad riding when I stand on the pegs. Unfortunately the pedal seems to be already in its top position as the lever touches its upper stop (I think thats the stoplight switch). Turning the spindle just reduces the pedals gap. Sure I can add a bracket on the pedal so that it gets higher but I'd like to have a possibility to lift and lower the lever as I am not always riding off road. I think the position of the pedal is standard but I can remember that when I installed the TouraTech crash bars that I had to take of the brake pedal and had to add a small bracket or plate, cant remember for what this was but am sure that this did not change the pedals original position. How did you solve the problem? Regards Steve |
09-20-2012, 03:48 AM
#2 |
Cosmopolitan Adv
I found that enlarging the Brake lever helps. Maybe try that if you can't lift the position
Keep the smile on your face! An Otter on the road: From Lille to Limoges in 12 Days An Otter on the road: I'm coming up so you better get this party started! |
09-20-2012, 06:02 AM
#3 |
Oddometer: 662
Grind down the tang on the back of the pedal arm where it makes contact with the brake light switch. Then adjust the connector to the rear master cylinder.
F650GS (Build Date 11/11) |
09-20-2012, 07:03 AM
#4 |
Frozen rider
Oddometer: 233
Putting Fastway pegs on "low boy" position has brought the relative height of the brake pedal up for me.
09-20-2012, 12:36 PM
#5 | |
Read Ride Reflect recycle
Oddometer: 145
Bend it
Works like a charm. Takes 10 seconds. And best yet - costs nothing.
Kyle twitter.com/ducumph 3Rrr = Read, Ride and Reflect 09 BMW F800GS 03 TTR 225 89 Kat GSX600F |
09-20-2012, 10:37 PM
#6 | |
Oddometer: 470
guys, many thanks for all your hints. Yo, I did already think about grinding the pedals stop down a bit but as this is irreversible I finally didnt do it.
However, thanks for the hint, seems its a good idea and does not cost me anything ![]() BR, Steve |
09-20-2012, 10:47 PM
#7 | |
Oddometer: 145
May I recommend the "no pliers" approach
Happy braking! Kyle
09-22-2012, 05:08 AM
#8 |
Oddometer: 58
I cut the stop off of the lever and brazed on a coupling nut about 1 inch long and then added a threaded stainless steel bolt and jam nut. Now I have complete adjustability. Works and looks great, I like to change the position depending on boots and type of riding.
Dave |
09-22-2012, 06:38 AM
#9 | |
Oddometer: 48
09-23-2012, 04:11 AM
#10 |
Oddometer: 58
sure, I'll take a pic and post today.
10-13-2012, 02:57 PM
#11 |
Oddometer: 470
