09-20-2012, 04:30 AM
#1 |
super n00b
Oddometer: 21
Another R80g/s build, just slower
Hi Everyone
I've allready started the rebuild of my 1981 R80g/s, but with the amout of hours I've allready put in I feel I should share some of it, even if it is only to see my own photos. So here goes, this was my g/s in one piece 2 years back, it is in about 200 pieces right now. ![]() ![]() ![]() I needed to replace the oil pump seal as it started to leak too much, wich I left as it is quite a big job. So in the process of removing the gearbox I decided I might as well do the whole thing (complete motorcycle I mean), and an hour after my well thought trough plan... ![]() ![]() Ghilli screwed with this post 09-20-2012 at 07:55 AM |
09-20-2012, 12:22 PM
#2 |
out there & loving it
Oddometer: 486
Now, that's a way to enter Advrider!
Start looks good, can't wait to see the next steps.
[Sir Mix-a-lot mode] I like big tanks and I cannot lie [\Sir Mix-a-lot mode] |
09-20-2012, 12:39 PM
#3 |
Woodfire or Bust
Oddometer: 421
Nice start! Take lots of photos... I@ll be doing the same thing soon enough.
09-20-2012, 10:10 PM
#4 |
Oddometer: 44
Ghilli fortunately you are an engineer!!!
09-21-2012, 06:09 AM
#5 |
super n00b
Oddometer: 21
F.e.a.r
Even though I am one I still needed to overcome my three fears:
-Removing the gearbox -Disconnecting every single wire and cable -Removing the barrels and pistons -Welding to the frame Ok four ![]() ![]() Obviously I had to wash it in the kitchen. Ghilli screwed with this post 09-21-2012 at 06:30 AM |
09-21-2012, 07:20 AM
#6 |
Oddometer: 44
Cape Town
Ghilli daar is baie ouens in die Kaap wat jou kan help raam versterk. Goeie welders. There is a few guys in Cape Town that can help you with frame welding. With good experience. Send me a pm for more details. Stuur groete vir Koos. Send regards to your brother.
09-21-2012, 07:22 AM
#7 |
Oddometer: 44
See here
09-25-2012, 05:00 AM
#8 |
super n00b
Oddometer: 21
Frame
Re-enforcing the frame looks really nice, but its too late for me now. I just fixed up the original frame and made a center stand out of three retired ones. Got that powder coated with a few other parts, and it came out really well, relatively cheap too.
This is the subframe with a piece torn out that I repaired. ![]() ![]() I attached a new battery mount to the frame. ![]() ![]() And repaired the damage the center stand made, those plugs are important. ![]() Set up the frame to see if everything fits, before I need to bend any coated finished parts. ![]() And here is my center stand made from old dead ones. ![]() ![]() ![]() ![]() ![]()
09-27-2012, 06:11 AM
#9 |
super n00b
Oddometer: 21
Drive shaft
Next up was the driveshaft, I took the original and a slightly less worn out shaft and swapped the bell housing. This was probably unnecessary, but the road going thrust adapter definitely had less wear than the one one the g/s.
![]() The thrust adapter on the g/s lost that totally round profile and "sharpens" when it wears. ![]() ![]() This called for some high tech tools, so I made me a high tech tool. ![]()
10-01-2012, 05:08 AM
#10 |
super n00b
Oddometer: 21
Plating
Not a lot of photos, but I wanted to try and do DIY nickel plating on all the bolts that are "special". All the other standard bolts will be replaced by new stainless steel bolts.
![]() The plating came out very nice, I hope its durable as well. These are the plated rear shock bolts, the photobomb bolt on the left is a new stainless bolt, the unpolished plated bolts shines more than brand new bolts. I made those small spacers to reduce the hole size compared to the bolt, there was quite allot of play on the rear bolts. ![]() This is a spacer inside the bolt hole on the swing arm. |
10-01-2012, 07:41 AM
#11 |
super n00b
Oddometer: 21
Here's a cool photo for no reason whatsoever.
![]() This actually gives you a good idea of areas to avoid when installing a wiring harness, there really isn't enough space to just route it anywhere. |
10-02-2012, 07:06 AM
#12 |
super n00b
Oddometer: 21
Bad news time, I've seen this allot on the internot, now I have one as well.
![]() ![]() The hub is out of its wear limit and looks like someone forced it off and started a nice crack, I was riding like this without knowing I was about 10 seconds away from death all the time. |
10-02-2012, 12:28 PM
#13 |
Woodfire or Bust
Oddometer: 421
Nice post... just a question... how does one measure the wear limit?
10-02-2012, 12:38 PM
#14 |
Oddometer: 534
10-02-2012, 01:44 PM
#15 | |
super n00b
Oddometer: 21
Only problem is, this is the data for a 4 bolt hub and not the older 3 bolt, not sure if it is the same for both models. |
