Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 04-02-2013, 03:32 PM   #121
DropinParts
Ducatista
DropinParts's Avatar
Oddometer: 94
Originally Posted by deWog View Post
Changes from the 2012 to the 2013 model include -
- Skyhook (DSS) semi-active suspension on all S models (replaces electronic, but 'conventional', Ohlins units)
- Twin-sparks on each cylinder (more efficient burn and better low-revs fuelling, ie- "less lumpy" at low rpm)
- repositioned throttle injectors for improved (cooler) intake flow.
- taller, wider windscreen (biggest improvemnet , .....after Skyhook)
- slightly altered front cowl, new LED headlights (give a whiter, brighter light) also means lower current drain and that both headlights can now run concurrently with high beam (conventional halogen)
- the small cockpit storage is now "push-to-click" for open and close rather than the previously useless flimsy tab.
- new seat stitching (which has 'squared' edges and not as comfortable as the previous seat design)
- different rim style (10-spoke)
- ABS-equipped version now have linked front and rear brakes in 'Touring' and 'Urban' ride modes. (the front lever will bring on the rear brake)
- altered ride modes (eg: 'Enduro' switches off the ABS on the rear only)
I appreciate this info more than you know. Can I assume the difference in the 2010 through the 2012 are minimal? The stealer has a nice 2010, but since it was the first year for the 1200, I am concerned about those first year blues.
There are two roads in life, the twisty one is vastly more fun.
DropinParts is offline   Reply With Quote
Old 04-02-2013, 04:48 PM   #122
Croak
Croak's Avatar
Oddometer: 529
Correct, there's no real difference between 2010 and 2012 in terms of features, and all the bugs addressed in production on 2011 and 2012 models were also addressed (for the most part) under warranty on the 2010. Just make sure all the warranty stuff has been done already.
2003 Aprilia Tuono
2002 Triumph Sprint ST
2013 Kymco Agility City 200i
Croak is offline   Reply With Quote
Old 04-02-2013, 05:26 PM   #123
DropinParts
Ducatista
Oddometer: 94
Old 04-03-2013, 03:09 PM   #124
Flightar
Flightar's Avatar
Oddometer: 142
Here's mine...great so far
http://lowside343964.smugmug.com/Mot...20L-Side-L.jpg
http://lowside343964.smugmug.com/Mot...20R-Side-L.jpg
http://lowside343964.smugmug.com/Mot...S%20Dash-L.jpg
http://lowside343964.smugmug.com/Mot...%20front-L.jpg
Flightar screwed with this post 04-03-2013 at 03:48 PM
Flightar is offline   Reply With Quote
Old 04-11-2013, 03:37 PM   #125
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
Can someone update me on the latest on the issue with the coolant and the porous head problem. Are cylinder heads being replaced? Has the revised coolant solved the problem? I don't really know much about this, just heard some brief info about it and wanted to get better informed before considering a purchase. Thanks.
EJ_92606 is offline   Reply With Quote
Old 04-11-2013, 04:44 PM   #126
joef
joef's Avatar
Oddometer: 539
Just had my coolant changed, 2011 year and original owner. 9000 miles on the clock with the blue coolant and no issues. I think it was a few bad batches but nothing that Ducati will tell us just a lot of speculation. It seemed to be a big headache for the ones affected by it and I would worry about long term effects if I had cylinders, heads or a radiator replaced.
joef is offline   Reply With Quote
Old 04-12-2013, 09:06 PM   #127
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,617
EJ,
Definitely worth consideration if you're contemplating a used one, especially of the 2010-2011 vintage (there is a VIN range I believe of effected bikes). The newer and lesser the miles the better. A new bike I would not worry about whatsoever.
2015 BMW r nine T | 2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well
oalvarez is offline   Reply With Quote
Old 04-13-2013, 01:52 AM   #128
Moronic
Moronic's Avatar
Oddometer: 1,724
What's up, EJ? I had gained the impression you were jonesing pretty hard for a new waterboxer.
It appears Ducati has sorted out a lot of things with the 2013 version. The coolant thing looked like it was a bit of a lottery, but there have been several reports on various fora of both cylinder heads being replaced as a result of it.
AFAIK, no-one has reported that their cylinder head failed out of warranty and Ducati failed to make good on it. And if it had happened, you'd expect the disgruntled owner would get the news onto the net somehow.
OTOH, some reports of bikes spending weeks or months in the shop awaiting parts and labour. Thus much gnashing of teeth. But all those were eventually reported fixed.
Sorting out the S4Rs Ohlins shock: click here.
Moronic is offline   Reply With Quote
Old 04-13-2013, 11:39 AM   #129
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
I was...still am I guess, but enthusiasm is waning a little bit. Not sure I want to be a beta tester. On a whim, test rode a K16 and was impressed with that and have always liked the Multistrada although I have yet to demo one. Nothing wrong with my camhead GS but started getting new bike fever when the first bits of info trickled out on the new water boxer and I can't shake it I'm intrigued by the multi because you universally hear people say they LOVE the bike, whereas with the GS you often get comments like...it's a good all around bike and does everything well, etc...but you don't necessarily get the love in capital letters....so perhaps I need to take a ride and see.
Thanks for the info on the cylinder heads.
Old 05-04-2013, 12:13 AM   #130
Vicsplorer
Oddometer: 20
So, I'm debating picking one of these up. Just trying to debate saving the extra coin to the S version or just grabbing the standard version now.
Tough decision.....
Vicsplorer is offline   Reply With Quote
Old 05-04-2013, 02:44 AM   #131
deWog
Oddometer: 107
Easy: S.
deWog is offline   Reply With Quote
Old 05-04-2013, 09:26 AM   #132
Pampero
Verbose Adventurer
Pampero's Avatar
Oddometer: 710
Tough decision.....
If you want the panniers, heated grips and center stand, the suspension is pretty much along for the ride with a small premium paid for it. Or vice versa; buy the suspension and get the other stuff for free. Plus or minus.
A wag will come along shortly and explain how you can get soft bags, 30 dollar Chinese grips and that the center stand is a PITA, but there's really only one way to get the suspension if that turns your crank.
Pampero is offline   Reply With Quote
Old 05-04-2013, 10:21 AM   #133
slopaleorider
Oddometer: 9
Get the S
I had a standard ABS 2010 and it was a great bike, went in looking for an S but the price was right so I took the left over 2010 for about a $7k savings and Ducati gave me a free set of side bags, due to some reasons I can't discuss here I no longer have the 2010 and have a 2013 on order, this time I went with the S due to it only being about a $3k difference in price, the extra equipment on the S is worth the money. I would also suggest that you stay away from the early bikes, they have some issues that ducati could never get sorted out on mine. Needless to say I love the bike and am buying another because it is an awesome bike, just keep in mind it is not an offload machine. Jeff
slopaleorider is offline   Reply With Quote
Old 05-04-2013, 01:25 PM   #134
joef
joef's Avatar
Oddometer: 539
2011 S model still going trouble free and strong. I ride, no worries
Old 05-06-2013, 01:13 AM   #135
Vicsplorer
Oddometer: 20
Dealer has offered a 2012 standard at a price that is honestly pretty hard to pass up (will end up costing about the same, a grand or two more than the Tiger Sport)...
I'm not overly fussed re the bags or the suspension to be honest, I just like the bikes for the room (I;m a tall guy) and the engine.
Times are GMT -7.   It's 11:43 PM.
